ebaruk
tracker-miner-fs.service
Wed Feb 24, 2021 3:22 pm
Every now and then I get this message below. What is possible to do in order to avoid receiving one.. :
localhost systemd[5542]: tracker-miner-fs.service: start operation timed out. Terminating.
Re: tracker-miner-fs.service
Wed Feb 24, 2021 6:44 pm
scruss
Wed Feb 24, 2021 8:27 pm
I couldn't live without Tracker, and it makes me sad to see the standard answer being "delete it".
Check /tmp/tracker-extract-files.1000 for problem symlinks. Sometimes Tracker finds a file that crashes its metadata miners. Unless you move or exclude that file path, it's keep crashing and sucking up lots of CPU time. This might be a way to get around it: no progress updates from gnome tracker - Ask Ubuntu
Tracker can be quite noisy even when it's working properly, so messages in the logs may not be a terribly bad thing. 100% cpu use, though, not so good.
Pronouns: he/him
ebaruk
Thu Feb 25, 2021 1:13 pm
If I check my "syslog"....This is what I get...
I would like to keep it and not to delete...but my system crashes for this reason(s)....
(after I used :rm -r ~/.cache/tracker) command
Feb 25 14:04:27 localhost systemd[5542]: tracker-miner-fs.service: Main process exited, code=exited, status=1/FAILURE
Feb 25 14:04:27 localhost systemd[5542]: tracker-miner-fs.service: Failed with result 'exit-code'.
Feb 25 14:04:27 localhost systemd[5542]: Failed to start Tracker file system data miner.
Feb 25 14:04:27 localhost systemd[5542]: tracker-store.service: Scheduled restart job, restart counter is at 3.
Feb 25 14:04:27 localhost systemd[5542]: tracker-miner-fs.service: Scheduled restart job, restart counter is at 18125.
Feb 25 14:04:27 localhost systemd[5542]: Stopped Tracker file system data miner.
Feb 25 14:04:27 localhost systemd[5542]: Starting Tracker file system data miner...
Feb 25 14:04:27 localhost systemd[5542]: Stopped Tracker metadata database store and lookup manager.
Feb 25 14:04:27 localhost systemd[5542]: Starting Tracker metadata database store and lookup manager...
Feb 25 14:04:27 localhost tracker-miner-f[299454]: Set scheduler policy to SCHED_IDLE
Feb 25 14:04:27 localhost tracker-miner-f[299454]: Setting priority nice level to 19
Feb 25 14:04:27 localhost systemd[5542]: Started Tracker metadata database store and lookup manager.
Feb 25 14:04:27 localhost tracker-store[299455]: Cannot initialize database: Could not open sqlite3 database:'/home/pihole/.cache/tracker/meta.db': unable to open database file
Feb 25 14:04:27 localhost systemd[5542]: tracker-store.service: Main process exited, code=exited, status=1/FAILURE
Feb 25 14:04:27 localhost systemd[5542]: tracker-store.service: Failed with result 'exit-code'.
Feb 25 14:04:27 localhost tracker-miner-f[299454]: Unable to get XDG user directory path for special directory &DOCUMENTS. Ignoring this location.
Feb 25 14:04:27 localhost tracker-miner-f[299454]: Unable to get XDG user directory path for special directory &MUSIC. Ignoring this location.
Feb 25 14:04:27 localhost tracker-miner-f[299454]: Unable to get XDG user directory path for special directory &PICTURES. Ignoring this location.
Feb 25 14:04:27 localhost tracker-miner-f[299454]: Unable to get XDG user directory path for special directory &VIDEOS. Ignoring this location.
Feb 25 14:04:27 localhost tracker-miner-f[299454]: Unable to get XDG user directory path for special directory &DOWNLOAD. Ignoring this location.
Feb 25 14:04:27 localhost dbus-daemon[5721]: [session uid=996 pid=5721] Activating via systemd: service name='org.freedesktop.Tracker1' unit='tracker-store.service' requested by ':1.36267' (uid=996 pid=299454 comm="/usr/libexec/tracker-miner-fs " label="unconfined")
Feb 25 14:04:27 localhost systemd[5542]: tracker-store.service: Scheduled restart job, restart counter is at 4.
Feb 25 14:04:27 localhost dbus-daemon[5721]: [session uid=996 pid=5721] Successfully activated service 'org.freedesktop.Tracker1'
Feb 25 14:04:27 localhost tracker-store[299464]: Cannot initialize database: Could not open sqlite3 database:'/home/pihole/.cache/tracker/meta.db': unable to open database file
Feb 25 14:04:27 localhost tracker-miner-f[299454]: Couldn't create new Files miner: 'Failed to load SPARQL backend: GDBus.Error:org.freedesktop.DBus.Error.NoReply: Message recipient disconnected from message bus without replying'
Feb 25 14:04:27 localhost systemd[5542]: tracker-store.service: Scheduled restart job, restart counter is at 5.
Feb 25 14:04:27 localhost systemd[5542]: tracker-miner-fs.service: Scheduled restart job, restart counter is at 18126.
Feb 25 14:04:27 localhost systemd[5542]: tracker-store.service: Start request repeated too quickly.
Feb 25 14:04:27 localhost systemd[5542]: Failed to start Tracker metadata database store and lookup manager.
Feb 25 14:04:27 localhost tracker-miner-f[299469]: Set scheduler policy to SCHED_IDLE
Feb 25 14:04:27 localhost tracker-miner-f[299469]: Setting priority nice level to 19
Feb 25 14:04:27 localhost tracker-miner-f[299469]: Unable to get XDG user directory path for special directory &DOCUMENTS. Ignoring this location.
Feb 25 14:04:27 localhost tracker-miner-f[299469]: Unable to get XDG user directory path for special directory &MUSIC. Ignoring this location.
Feb 25 14:04:27 localhost tracker-miner-f[299469]: Unable to get XDG user directory path for special directory &PICTURES. Ignoring this location.
Feb 25 14:04:27 localhost tracker-miner-f[299469]: Unable to get XDG user directory path for special directory &VIDEOS. Ignoring this location.
Feb 25 14:04:27 localhost tracker-miner-f[299469]: Unable to get XDG user directory path for special directory &DOWNLOAD. Ignoring this location.
Feb 25 14:04:27 localhost dbus-daemon[5721]: [session uid=996 pid=5721] Activating via systemd: service name='org.freedesktop.Tracker1' unit='tracker-store.service' requested by ':1.36270' (uid=996 pid=299469 comm="/usr/libexec/tracker-miner-fs " label="unconfined")
######################################################################################3
Any good advice would be more then welcomed
scruss
Thu Feb 25, 2021 3:11 pm
That might be part of the problem, because you're seeing:
Tracker needs the ~/.cache/tracker folder to exist, so if you remove it while the miners are running, it'll be unhappy.
Pronouns: he/him
ebaruk
Tue Mar 02, 2021 4:31 am
Let's say I would like to reinstall trackers back on my system and fix the issue trying to adjust my settings.. What would be
the correct way of doing it ?
Do You have some good link or guide how to fix this for good ?
https://www.linuxuprising.com/2019/07/h ... acker.html ?
scruss
Tue Mar 02, 2021 1:01 pm
Maybe something like:
sudo apt remove --purge tracker tracker-extract tracker-miner-fs
sudo apt install tracker tracker-extract tracker-miner-fs
and then never, ever delete ~/.cache/tracker while the system's running.
I'd maybe do this at the end of the day and let tracker have all night to index. It can make a computer unusable until it settles down.
Every other link I've seen is about removing it, so the only good link is the one I posted upthread.
Pronouns: he/him
ebaruk
Sun Mar 14, 2021 9:44 am
Thank You for the the help...I followed links below:
https://gist.github.com/vancluever/d34b41eb77e6d077887c
https://itectec.com/ubuntu/ubuntu-track ... ot-of-cpu/
https://bugs.launchpad.net/ubuntu/+sour ... ug/1826439
Besides standard suggestions, I also used:
METHOD 2:
Non-Invasive Disable Cheat Sheet
This disables everything but tracker-store, which even though it has a .desktop file, seems tenacious and starts up anyway.
However, nothing gets indexed.
tracker daemon -t
cd ~/.config/autostart
cp -v /etc/xdg/autostart/tracker-*.desktop ./
for FILE in tracker-*.desktop; do echo Hidden=true >> $FILE; done
rm -rf ~/.cache/tracker ~/.local/share/tracker
[/i]
Note that tracker daemon -t is for graceful termination. If you are having issues terminat-ing processes or just want to take your frustration out, tracker daemon -k immediately kills all processes. After this is done, tracker-store will still start on the next boot. However, nothing will be indexed. Your disk and CPU will be better for wear.
It works fine now and my CPU stays in normal rates without crashing...
scruss
Sun Mar 14, 2021 10:50 pm
But what's you've done is completely removed tracker. So it's no longer doing anything for you. Your files are no longer being indexed, so you can't do one-key search.
Pronouns: he/him
Return to “Ubuntu”
