scruss
Forth (Mecrisp Stellaris 2.5.6) for Raspberry Pi Pico
Thu Feb 25, 2021 6:23 pm
is here, apparently:
https://sourceforge.net/projects/mecrisp/files/
As there are some Forth-heads here, I thought I'd pass it on. I've had pretty much zero luck getting Mecrisp Stellaris to do anything useful on other ARM platforms. It's not particularly beginner friendly, and the documentation is … well, I'll let you decide.
Pronouns: he/him
bgolab
Re: Forth (Mecrisp Stellaris 2.5.6) for Raspberry Pi Pico
Thu Feb 25, 2021 7:35 pm
Found stack-based machines and RPN very interesting years ago. Requires different mind-set. But the produced code seems to be little bit unreadable. Particularly after a few months;)
Anyway worth trying.
HermannSW
Fri Feb 26, 2021 8:20 pm
Cool.
From CHANGELOG:
11.02.2021, Matthias Koch, Mecrisp-Stellaris 2.5.6
  - New target: RP2040 on Raspberry Pico board
Any idea how to avoid drifting right and get meaningful output in miniterm?
Welcome to minicom 2.7.1
OPTIONS: I18n
Compiled on Aug 13 2017, 15:25:34.
Port /dev/serial0, 21:16:21
Press CTRL-A Z for help on special keys
1234 u.4 1234 ok.
                 234 u.8 00000234 ok.
                                     17 const.  #17 ok.
                                                       blinky blinky not found.
HermannSW
Sat Feb 27, 2021 12:09 pm
bgolab wrote:
Fri Feb 26, 2021 8:26 pm
Try to review this:
https://stackoverflow.com/questions/528 ... s-expected
That is not helpful, because the commands in my miniterm get executed (u.4, u.8, ...).
It is just the missing carriage return that is a problem, linefeed happens.
scruss
Sat Feb 27, 2021 1:03 pm
You're using minicom, not miniterm, because:
Fiddle with your line ending settings: by the looks of things Mecrisp Stellaris is expecting CRLF but you're sending it LFs
Pronouns: he/him
drgeoff
Sat Feb 27, 2021 1:31 pm
Close but no cigar.
Mecrisp Stellaris is sending only LFs but minicom is expecting CRLFs.
https://unix.stackexchange.com/question ... -n-to-crlf
Return to “General”
