Whats a good way to stress test the processor on my pi 4? Looking to test the cpu fan
I have a PoE hat and I suspect the fan isn't turning on as it should. Whats a good way to make the cpu run hot so the fan should kick on?
Matt
Matt
Re: Whats a good way to stress test the processor on my pi 4? Looking to test the cpu fan
Try cpuburn:
This downloads, assembles, and runs cpuburn. For future runs, just do the last line.
This stress test does some NEON stuff on all four cores and (on 32-bit Raspberry Pi OS) will raise the temperature quickly.
To display the temperature:
and:
to see if the Pi4 has throttled back (reached 80C at some point) - it should always say 0x0
wget https://raw.githubusercontent.com/ssvb/cpuburn-arm/master/cpuburn-a53.S
gcc -o cpuburn-a53 cpuburn-a53.S
./cpuburn-a53
vcgencmd measure_temp
vcgencmd get_throttled
I normally use
that drives the CPU at 100%
then I can
when I'm finished, so is cpuburn better or does it really matter? In the end the CPU is at 100% either way?
Just interested, thanks
yes &>/dev/null &
yes &>/dev/null &
yes &>/dev/null &
yes &>/dev/null &
then I can
killall yes
I sometimes doDarkElvenAngel wrote: ↑Tue Mar 02, 2021 4:14 pmI normally usethat drives the CPU at 100%Code: Select all
yes &>/dev/null & yes &>/dev/null & yes &>/dev/null & yes &>/dev/null &
then I canwhen I'm finished, so is cpuburn better or does it really matter? In the end the CPU is at 100% either way?Code: Select all
killall yes
yes >/dev/null & yes >/dev/null & yes >/dev/null & yes >/dev/null &
"yes" is a simple integer load that's easy for the Pi CPU's to execute.
Cpuburn spawns processes to run on all four cores, all of which are automatically stopped when you type Control-C.
Cpuburn does some stuff with NEON which seems to raise the temperature very quickly.
NEON is quad issue so in theory it is doing four operations per cycle (on all four CPU cores of course).
Also NEON is SIMD so it is working with 128-bit registers.
On the first Pi3, cpuburn would crash the system in a few seconds.
As time goes on, Pi's have handled it better, and now with the Pi4, if there is a good heat sink, it may not even reach throttling.
cpuburn seems to run hotter in 32-bit mode.
Cpuburn sounds a little like a fork bomb for older Pi's. I'm going to have to do a test with both and see now how they compare. I appreciate your response.
Thanks to DEA for that yes trick.
Built-in functions are very important to me for a variety of reasons. Having to hunt down or, worse still, compile from scratch not so much. I have no idea what's going on but works like a charm cooking these puppies to the max.
Try typing "yes" alone on the command line, you will see how it works!
The repository has a stress package.
There is a python utility stressberry which uses this and performs comprehensive tests and plots graph of performance & temperature.
yyyyyyyyyyyyyyyyyyyyyyyyyyyikes!!! lol
Also explains what the NUL is for. Amazing something that simple can clog up CPUs like that. And now I've also learned how to trick other cores into action. And thanks for the ^C tip.
I recall writing a similar utility long time ago for MSDOS to 'force' positive replies. Deja Vu all over again.
If cpuburn is working as expected, the amount of heat generated and electricity consumed should be much greater than four copies of yes piped into null. It's true however that GNU yes and Linux pipes have been optimised in crazy ways, so maybe it's still a good stress test. I've got a USB power meter on the shelf that I've been meaning to try out for some time.emma1997 wrote: ↑Wed Mar 03, 2021 6:25 pmyyyyyyyyyyyyyyyyyyyyyyyyyyyikes!!! lol
Even if differences in power consumed don't directly correspond to heat, they might at least be interesting to report.
I would also be interested in the difference. IIRC somebody mentioned earlier cpuburn heats faster but it would be nice to quantify that. 2x? 10x?
I'd do it myself but unfortunately don't have internet or disk space to spare which is why I like this yes thing in the first place. I suppose a Pi loaded up with cooling fins or liquid nitrogen might show more difference but I don't have either of those either.
I'm planning to do these test I just don't have time till the end of the week. I want to see the differences between the two options. As I use yes for my tests I'd like to see if there is a noticeable difference.emma1997 wrote: ↑Wed Mar 03, 2021 7:09 pmI would also be interested in the difference. IIRC somebody mentioned earlier cpuburn heats faster but it would be nice to quantify that. 2x? 10x?
This is the source code it is very small:emma1997 wrote: ↑Wed Mar 03, 2021 7:09 pmI would also be interested in the difference. IIRC somebody mentioned earlier cpuburn heats faster but it would be nice to quantify that. 2x? 10x?
* Copyright © 2016 Siarhei Siamashka <siarhei.siamashka@gmail.com>
* Permission is hereby granted, free of charge, to any person obtaining a
* copy of this software and associated documentation files (the "Software"),
* to deal in the Software without restriction, including without limitation
* the rights to use, copy, modify, merge, publish, distribute, sublicense,
* and/or sell copies of the Software, and to permit persons to whom the
* Software is furnished to do so, subject to the following conditions:
* The above copyright notice and this permission notice (including the next
* paragraph) shall be included in all copies or substantial portions of the
* Software.
* THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
* IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
* FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL
* THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
* LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING
* FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER
* DEALINGS IN THE SOFTWARE.
* This program tries to stress ARM Cortex-A53 processor to generate as
* much heat as possible.
* WARNING: improperly cooled or otherwise flawed hardware may potentially
* overheat and fail. Use at your own risk.
* Compilation instructions:
* $ aarch64-linux-gnu-gcc -o cpuburn-a53 cpuburn-a53.S
* or
* $ arm-linux-gnueabihf-gcc -o cpuburn-a53 cpuburn-a53.S
* See http://ssvb.github.io/2012/04/10/cpuburn-arm-cortex-a9.html
* for more details.
#define LOOP_UNROLL_FACTOR 100
#ifdef __aarch64__
/* 64-bit implementation */
.cpu cortex-a53+fp+simd
.text
.align 2
.global main
.type main, %function
main:
stp x29, x30, [sp, #-16]!
#ifdef __linux__
mov w0, #84 /* _SC_NPROCESSORS_ONLN */
bl sysconf
mov w29, w0
cmp w29, #2
blt 1f
bl fork /* have at least 2 cores */
cmp w29, #4
blt 1f
bl fork /* have at least 4 cores */
cmp w29, #8
blt 1f
bl fork /* have at least 8 cores */
1:
#endif
movi v28.16b, #0xff
movi v29.16b, #0xff
movi v30.16b, #0xff
movi v31.16b, #0xff
adr x4, 9f
add x4, x4, #1
mov x1, #0
mov x2, #(64 / 4)
b 0f
.ltorg
9:
.rept 64
.long 0xffffffff
.endr
.balign 64
0:
.rept LOOP_UNROLL_FACTOR
uaba v8.4s, v28.4s, v29.4s
bne 1f
1: uaba v9.4s, v30.4s, v31.4s
ldr w0, [x4, x1, lsl #2]
uaba v10.4s, v28.4s, v29.4s
bne 1f
1: uaba v11.4s, v30.4s, v31.4s
ldr w0, [x4, x2, lsl #2]
.endr
b 0b
mov w0, #0
ldp x29, x30, [sp], #16
ret
#else
/* 32-bit implementation */
.syntax unified
.text
.arch armv7-a
.fpu neon
.global main
.align 2
.arm
main:
push {r4-r12, lr}
#ifdef __linux__
mov r0, 84 /* _SC_NPROCESSORS_ONLN */
bl sysconf
mov r4, r0
cmp r4, #2
blt 1f
cmp r4, #4
blt 1f
cmp r4, #8
blt 1f
1:
#endif
vmov.u8 q12, #0xff
vmov.u8 q13, #0xff
vmov.u8 q14, #0xff
vmov.u8 q15, #0xff
adr lr, 9f
add lr, lr, #1
mov r1, #(64 / 4)
mov r2, #(-64 / 4)
b 0f
.ltorg
9:
.rept 64
.long 0xffffffff
.endr
.balign 64
0:
vaba.u32 q8, q12, q13
bne 1f
1: vaba.u32 q9, q14, q15
ldrne r0, [lr, r1, lsl #2]!
vaba.u32 q10, q12, q13
bne 1f
1: vaba.u32 q11, q14, q15
ldrne r0, [lr, r2, lsl #2]!
.endr
b 0b
mov r0, #0
pop {r4-r12, pc}
#endif
"yes >/dev/null" is simply writing to the null device, it is not a pipe. File descriptor 1 is reopened for "/dev/null" by the shell before it starts yes.ejolson wrote: ↑Wed Mar 03, 2021 6:49 pmIf cpuburn is working as expected, the amount of heat generated and electricity consumed should be much greater than four copies of yes piped into null. It's true however that GNU yes and Linux pipes have been optimised in crazy ways, so maybe it's still a good stress test.
Yes doesn't know any different.
This looks like a pipeline, but each & starts the previous command in the background:-
So I suspect its doing (at least) 16 operations per clock cycle.
Another large part of the SoC real estate is the GPU. I sure someone could write code to exercise that!
Probably not the case here but what I've learned is source code is not always a good indicator of disk usage at all. I won a bet once by proving a 20 byte source file ended up taking 4gig disk space while a 1meg one compiled to only 5 bytes.
In my case it's also a matter of time needed to install and maintain these gadgets. With around 20 setups now between work and home, better to keep them as close to original image as possible. That and my tendency to start from scratch on every new release means the fewer extra steps and less fuss the better. Takes less than 15min now and don't want that to grow out of control.
Built-in functions will always take precedence over things that need installing or specially if needs compiling too. Over the years KISS policy has proven the key to managing all my OS stuff, Winders or Linucks.
The cpuburn-a53 source code is 5K, compiles to 12K that when stripped is 10K.
$ ls -l
total 8
-rw-r--r-- 1 ejolson users 5129 Mar 3 21:25 cpuburn-a53.S
$ gcc -o cpuburn-a53 cpuburn-a53.S
$ ls -l
total 20
-rwxr-xr-x 1 ejolson users 12128 Mar 3 21:28 cpuburn-a53
$ strip cpuburn-a53
$ ls -l
total 20
-rwxr-xr-x 1 ejolson users 9648 Mar 3 21:28 cpuburn-a53
Here are my measurements:
Test Amperes
idle 0.45 to 0.50
cpuburn-a53 1.01 to 1.06
yes >/dev/null 0.83 to 0.88
For reference my Pi pie chart program
viewtopic.php?t=227177
in stress mode obtains
Test Amperes
Prime Sieve 0.97 to 1.04
Merge Sort 0.89 to 1.01
Fourier 0.72 to 0.85
Lorenz 96 1.24 to 1.30
viewtopic.php?t=276089
How does stress-ng perform?
This seems to raise the temperature much higher than cpuburn on my 64-bit Pi4.
sudo apt install stress-ng
stress-ng --cpu 4 --cpu-method fft
The results for stress-ng isjahboater wrote: ↑Wed Mar 03, 2021 11:45 pmHow does stress-ng perform?
This seems to raise the temperature much higher than cpuburn on my 64-bit Pi4.Code: Select all
Test Amperes
stress-ng fft 1.12 to 1.17
Thanks for the testing results very interesting.
Thanks for these interesting results.
Looks like Lorenz 96 followed by stress-ng fft are the two best stress tests.
