jahboater
Re: New book by Brian Kernighan.
Wed Jul 28, 2021 8:52 am
Heater wrote:
Wed Jul 28, 2021 7:09 am
I have always wondered about C's bracketing system. For example why are those round brackets required around the condition in an "if" statement:
if (somethingIsTrue) {
I suspect it made things easier for the very early compiler because it looks a bit like a function.
jahboater
Wed Jul 28, 2021 10:24 am
The there is that use of round brackets when casting. For example:
int i = 17, j = 5;
   double d;
   d = (double) i / j;
Always seemed a bit odd to me. Not entirely clear to a novice reader, one has to bear in mind type coercions and operator precedence to see what happens there.
Yes, I prefer "d = double(i / j);", but maybe it was to make clear it was not a function, or not clutter the function namespace, or something!
A cast is an operator, not a function.
Heater
Wed Jul 28, 2021 10:54 am
Indeed so.
However "sizeof" is also an operator. But can be used as "s = sizeof char" or more usually "s = sizeof(char)". So why not "i = int c" or "i = int(c)"?
jahboater
Wed Jul 28, 2021 11:11 am
Indeed so.
Yes, good point. Inconsistent.
Maybe sizeof was added much later.
Heater
Wed Jul 28, 2021 4:56 pm
Sharkins wrote:
Wed Jul 28, 2021 4:20 pm
this book is not for everyone...
OK. What do you mean by that?
Which people do you think it is for? Which people do you think it is not for? For what reasons?
Personally I think anyone curious enough to be using a Pi and the PiOS operating system is very likely to be curious as to the origins of the tools we use. It's all interesting stuff.
ejolson
Wed Jul 28, 2021 5:03 pm
Indeed so.
My suspicion is the syntax of C and the way it's formatted was designed to be easy for the humans who were writing an operating system called Unix to read. I think much of the syntax reflects experience with other languages. As a result there are much easier languages than C to write parsers for. Arguably the task of writing parsers was a solved problem, at least at Bell Labs, by the time Unix came out.
Heater
Wed Jul 28, 2021 7:30 pm
Sorry I can't link to where I read this but is some discussion of the history of C it was stated that the language was created specifically for the task of making the Unix kernel portable. That is recreating in a portable high level language what existed as assembler. That features were added to C as and when that task required them. For example C did not originally even have "struct".
So I can imagine C grew in some organic way, building on what already existed. And so it seems natural to me that the final resulting language is not the best possible solution seen in retrospect.
I'm sure the task of writing parsers was already a solved problem. However there have been languages that can do all that C can do, whist at the same time being more consistent and easier to parse created since then. But that is with the benefit of hind sight.
jahboater
Wed Jul 28, 2021 7:45 pm
Yes, its well known. UNIX was rewritten in C and at the same time enhanced to be multi-user. Its all in that book!
Yes.
C obviously came from the typeless B (which had similar "if( expr )" syntax), with notes of the earlier BCPL and Algol68, possibly RatFor.
What I mean is, the reason for some of C's syntax oddities, probably goes back much further, long before C's inception.
Heater
Wed Jul 28, 2021 7:47 pm
That is my understanding of the history as well.
Thu Jul 29, 2021 9:07 am
Spammer, banned. For some reason this thread is like a honeypot for spammers, deleting posts on it every day. Must be some keywords in it that kick of some spammer system somewhere.
lurk101
Sun Aug 01, 2021 12:57 pm
emma1997 wrote:
Wed May 05, 2021 4:12 pm
For me all this ANSI, ISO, plus-plus BS to be avoided whenever possible.
I'm guessing your phone still has a rotary dial.
