anakin59490
Raspberry RFID UHF
Mon Jan 28, 2013 1:16 pm
is there a RFID reader (compatible with Raspberry) who can reads tags on a distance greater than 1 meter ?
Thank you
enzeneer
Re: Raspberry RFID UHF
Tue Feb 18, 2014 9:29 pm
How about this: http://www.cutedigi.com/sensor/id/cotto ... pc-g2.html
You would probably need the 8dBi antenna to go with it to increase the read range.
blindvia
Tue Apr 08, 2014 8:33 am
Could you please share more relevant resources or similar projects using this kind of UHF readers done with Raspi?
megrimm
Wed Apr 08, 2015 1:10 pm
Has anyone had success with this? I just tried with a student on Monday to get this (cottonwood long range rfid) working with the RPI without quick success....
we were working off these two posts but were having trouble:
http://learn.linksprite.com/rfid/how-to ... id-reader/
http://forum.linksprite.com/index.php?/ ... al-driver/
Anyone with tips?
m
tylerlindstrand
Tue Jul 14, 2015 5:01 pm
Has anyone had any luck with this? Would love to see a project with coding with the cottonwood and RPi.
itarian
Tue Dec 15, 2015 6:41 pm
I bought this Cottonwood kit:
http://www.soliddepot.com/index.php?mai ... cts_id=232
The AS399x reader module and the 8dbi antenna.
My reader was configured to use USB, which worked fine on windows but I was not able to read/write over USB on the raspberry pi. They included the 'debug' cable, and was able to follow the guide to flash the reader to do UART.
I now have the Raspberry Pi connected via UART, and after disabling the 'serial console' on the Pi, can attach a Python serial script to ttyAMA0, send and receive commands.
Writing the version command (string1 = "\x10\x03\x01") returns the version data as documented and writing the 'read card' string (string2 = "\x37\x05\x01\x02\x06") does return a string that looks somewhat IDish.
I think what I need now is to figure out how to clear buffers, read antenna strength, read frequency info, then tune it up to read ID tags to fit my application.
avanover
Fri Jul 01, 2016 11:05 pm
Were you able to pull tag data from the AMS module? I am looking to do something very similar. Any help would be much appreciated!
mtparvia
Mon Aug 29, 2016 8:55 am
Anyone has any success with this one? I am looking Python source to read RFID -tags with Cottonwood UHF reader?
I have now a following setup:
https://www.itead.cc/foca-pro.html
USB -> Foca Pro
Foca Pro GND -> Cottonwood GND
Foca Pro RXD -> Cottonwood TX0
Foca Pro TXD -> Cottonwood RX0
I have connected 5V external power to Cottonwood
I have also connected external RFID antenna to Cottonwood
Red light is blinking on Cottonwood
I have downloaded https://github.com/GuyLewin/pyAS3992 source and saved it to RPI
When I run example.py nothing happens.
What I am doing wrong ?
mtparvia
Mon Aug 29, 2016 12:59 pm
It seems that the problem is the baud rate, when changed it to 9600 it seems to work. Just need some tags to test if it works now.
arnauddesbois
Sat Aug 19, 2017 10:49 am
What was the results ? What maximum distance ?
thetangstr
Tue Apr 28, 2020 7:20 pm
I'm working on a project that needs a UHF RFID reader that can read greater than 1m as well. Were there any more development to this project/thread?
