crimson0ninja
This board requires newer software
Sun Jul 04, 2021 11:58 pm
I have a raspberry pi 4 4gb that has an image that i got from arcade punks on retro pie. i now have a second raspberry pi but its the 4 8 gb. i downloaded and etched the raspberry pi os on 1 sd and installed it. then i also downloaded retropie and installed it. i took the sd card out of the 4 gb and put in the 8 gb. now i get a message saying this board needs newer software. i made sure i did the upgrade with the raspberry os. what am i doing wrong?
terribleted
Re: This board requires newer software
Mon Jul 05, 2021 1:54 pm
probably needs an eeprom update.
sudo rpi-eeprom-update
(to see status)
sudo rpi-eeprom-update -a
(to automatically update)
see "sudo rpi-eeprom-update --help" for more info
i had a Trash-80 model 1 (circa 1980). upgrading from 4k to 16k of RAM, i thought "i'll never use this much RAM".
Now i have a computer with a million times that much memory. And i keep running out of it.
Not the computer....ME.
crimson0ninja
Thu Jul 08, 2021 7:44 pm
Thanks for the help.
girlintrouble
Thu Jul 08, 2021 11:21 pm
I had this same error when trying to install OSMC but not with installing Raspbian on same hw. Hmm strange :geek:
We all have to start somewhere…. :mrgreen:, thank you for your patience! :D
trejan
Thu Jul 08, 2021 11:31 pm
It isn't the EEPROM. You either need to manually update your image to the latest firmware + kernel or ask for an updated image. Ask whoever you got the image from for help.
Pi 4 8GB needs newer firmware than the older 4GB model which is why the bootloader is complaining.
trejan
Thu Jul 08, 2021 11:32 pm
Firmware + kernel on the OSMC card is too old.
girlintrouble
Thu Jul 08, 2021 11:49 pm
Ok I’m a newbie, your answer is a bit too cryptic for me, is there a more basic version of your reply please?
What can I do to fix it?
girlintrouble
Thu Jul 08, 2021 11:50 pm
(to see status)
Do I have to install raspbian, do this to update EPROMs then reinstall OMSC?
trejan
Fri Jul 09, 2021 12:36 am
It won't fix it. The error is the bootloader in the EEPROM complaining that the files on your card don't support that revision of the hardware. Updating the EEPROM isn't going to do anything to the card contents.
Best option is wait for the developers to release a newer image. OSMC doesn't have a Pi 4 release yet so there will be a lot of changes needed.
girlintrouble
Fri Jul 09, 2021 10:44 am
So are we saying if I was using the pi 4 2/gb or 4gb I may not have had this problem?
Seems from above there isn’t firm consensus about the issue….
trejan
Fri Jul 09, 2021 10:53 am
No. There is no Pi 4 build of OSMC.
Try upgrading the EEPROM if you want. It won’t fix it.
girlintrouble
Fri Jul 09, 2021 10:56 am
Ok thanks I won’t bother as you seem convinced. I’ll go with LibreElec as I was previously planning.
Thank you so much for the input.
It’s fun getting things wrong, at least you learn stuff
Also I hope the OP a didn’t mind my hijacking the post, personally I see little point in cluttering up forums with nearly identical posts.
