mustafasei
update node.js problem
Fri Jul 23, 2021 5:52 pm
Hi
Your advise please for the problem below when try to install serial port node to RPI3
npm install node-red -node-serialport
npm WARN npm npm does not support Node.js v8.12.0
npm WARN npm You should probably upgrade to a newer version of node as we
npm WARN npm can't make any promises that npm will work with this version.
npm WARN npm You can find the latest version at https://nodejs.org/
npm ERR! URL is not defined
npm ERR! A complete log of this run can be found in:
npm ERR! /home/pi/.npm/_logs/2021-07-23T17_24_24_847Z-debug.log
I have node -v
v8.12.0
and
npm -v
7.20.1
I have searched on some forums and tried to get some commands to solve my problem but i got as below :
pi@pi:~ $ npm install node-red-node-serialport
bash: npm: command not found
pi@pi:~ $ sudo apt install build-essential git curl
E: dpkg was interrupted, you must manually run 'sudo dpkg --configure -a' to correct the problem.
pi@pi:~ $ apt-get install nodered
E: Could not open lock file /var/lib/dpkg/lock - open (13: Permission denied)
E: Unable to lock the administration directory (/var/lib/dpkg/), are you root?
pi@pi:~ $ sudo apt-get update
E: Malformed line 8 in source list /etc/apt/sources.list (URI)
E: The list of sources could not be read.
pi@pi:~ $ sudo apt-get upgrade
pi@pi:~ $
RonR
Re: update node.js problem
Sat Jul 24, 2021 12:32 am
You might consider installing the currently recommended version (14.x):
sudo curl -sL https://deb.nodesource.com/setup_14.x | sudo -E bash -
sudo apt-get -y install nodejs
mustafasei
Sat Jul 24, 2021 2:14 pm
Hi
I got as below :
## Installing the NodeSource Node.js 14.x repo...
## Populating apt-get cache...
+ apt-get update
Error executing command, exiting
pi@pi:~ $ sudo apt-get -y install nodejs
Reading package lists... Done
Building dependency tree
nodejs is already the newest version.
0 upgraded, 0 newly installed, 0 to remove and 215 not upgraded.
also when I did update command I got :
sudo apt update
RonR
Sat Jul 24, 2021 5:37 pm
Did you look at line 8 in source list /etc/apt/sources.list to see what is malformed?
mustafasei
Mon Jul 26, 2021 10:04 am
No I have no experience in such field
Can you please advise about that
Mon Jul 26, 2021 12:11 pm
Not unless you show us what you have in that file.
This is what I have in my default file:
pi@raspberrypi:~ $ cat /etc/apt/sources.list
deb http://deb.debian.org/debian buster main contrib non-free
deb http://deb.debian.org/debian-security/ buster/updates main contrib non-free
deb http://deb.debian.org/debian buster-updates main contrib non-free
# Uncomment deb-src lines below then 'apt-get update' to enable 'apt-get source'
#deb-src http://deb.debian.org/debian buster main contrib non-free
#deb-src http://deb.debian.org/debian-security/ buster/updates main contrib non-free
#deb-src http://deb.debian.org/debian buster-updates main contrib non-free
You probably have something extra for node installation and have mistyped it or it has become corrupted somehow.
Unreadable squiggle
Tue Jul 27, 2021 3:38 pm
mustafasei wrote:
Tue Jul 27, 2021 1:54 pm
below is the list :
deb http://mirrordirector.raspbian.org/raspbian/ jessie main contrib non-free rpi
# Uncomment line below then 'apt-get update' to enable 'apt-get source'
#deb-src http://archive.raspbian.org/raspbian/ jessie main contrib non-free rpi
deb http://feeds.labviewmakerhub.com/debian/ binary/
deb
binary/
That looks quite messed up to me. Most of the lines are the same. There should be only one line per source location. Line 8 and 9 are very wrong. If you need that "labviewhub" entry, I'd change the file to look like this:
Unreadable squiggle
mustafasei
Tue Jul 27, 2021 4:52 pm
How can I change it please ? I have no experience in programming of RPI
appreciate it you guide me step by step
Tue Jul 27, 2021 6:40 pm
If you type
sudo nano /etc/apt/sources.list
There are a few ways to do this. the most common is to use sudo nano /etc/apt/sources.list to let you edit the file, delete the lines you don't need, and the save the file by pressing Ctrl-o to "Write Out", then Ctrl-x to "Exit) as shown at the bottom of the editor screen.
Another method is to use something like sudo sed -i 5,18d /etc/apt/sources.list which will just delete lines 5 to 18 of that file for you.
Unreadable squiggle
jbudd
Tue Jul 27, 2021 6:51 pm
This may be a dumb suggestion since I'm not clear of the difference between node.js and node-red.
If you are using node-red, the best way to install and update it is with the script on the nodered.org getting started page.
And with the current version you can install additional nodes from within node-red via hamburger menu/manage palette.
ps maybe try it on a new SD card first, using Buster. You seem to be still on Jessie?
mustafasei
Tue Jul 27, 2021 7:08 pm
I got as below
sed: couldn't open temporary file /etc/apt/sedhrErG9: Permission denied
Tue Jul 27, 2021 7:12 pm
Sorry, my fault. I forgot to say you need to put sudo in front of the sed command. I have corrected my previous post.
Unreadable squiggle
mustafasei
Thu Jul 29, 2021 9:04 pm
Hi
It is work perfectly now and thank you for your help
now I got new issue after do full upgrade I lost the connection with wifi even after resend the supplicant.conf file to SD card still no wifi connection
Any advice please
jbudd
Thu Jul 29, 2021 9:06 pm
Show us your wpa_supplicant.conf.
mustafasei
Fri Jul 30, 2021 9:44 am
Shall I attached the .conf file or a picture to a command??
jbudd
Fri Jul 30, 2021 1:05 pm
Either copy and paste the text, or a picture. Easier to censor your SSID and password in text form.
mustafasei
Fri Jul 30, 2021 2:28 pm
country=us
update_config=1
ctrl_interface=/var/run/wpa_supplicant
network={
scan_ssid=1
ssid="****"
psk="*****"
I was following the video and post below but I found as per picture
https://www.youtube.com/watch?v=V1j-mnofPpk
viewtopic.php?t=124069
jbudd
Fri Jul 30, 2021 2:42 pm
country=us
update_config=1
My wpa_supplicant.conf file (Buster not Jessie) has this:
update_config=1
country=GB
I don't know if the country code has to be upper case but certainly worth trying US
Your ctrl_interface is missing "DIR=" and GROUP=netdev
