MinistryofSillyWalks
GPIOs not reliably switching on our motor
Mon Aug 02, 2021 7:15 pm
We have a setup with a RPI 4B and a custom extension board with which we are controlling a motor for a tray.
The code for opening the tray is this:
  import RPi.GPIO as GPIO
    from time import sleep
    GPIO.setmode(GPIO.BCM)
    Tray = [2,3]
    Close = [3]
    Open = [2]
    GPIO.setup(Tray, GPIO.OUT, initial=GPIO.HIGH)
    GPIO.output(Open, GPIO.HIGH)
    GPIO.output(Close, GPIO.LOW)
    GPIO.cleanup(Tray)
    sleep (5)
Now, we have the problem, that the tray/ motor gets reliably activated only in spyder but not reliably from the console.
Both spyder and the console use the same python version.
It seems to me, that it is a timing problem because when executing from terminal, it randomly works or not. The motor cycle (set with a time limit) starts in one direction when GPIO 3 is low and 2 is high and vice versa.
Any idea where the problem might lie or how we can improve this?
Many thanks
joan
Re: GPIOs not reliably switching on our motor
Mon Aug 02, 2021 8:19 pm
You are changing the outputs to inputs with the call to cleanup(). Put the cleanup() after the sleep().
