Taomyn
Repo changed from "stable" to "oldstable", what does this mean?
Tue Aug 24, 2021 7:59 am
When I went to update my 3 x RPI-4s they all showed no updates, which is unusual in my experience even after a week between checks I usually get some updates, but now they all also display the message after the check:
N: Repository 'http://raspbian.raspberrypi.org/raspbian buster InRelease' changed its 'Suite' value from 'stable' to 'oldstable'
What does this mean?
The full text from a check of one RPi is:
pi@octopi:~ $ sudo apt update
Get:1 http://archive.raspberrypi.org/debian buster InRelease [32.6 kB]
Get:2 http://archive.raspberrypi.org/debian buster/main armhf Packages [378 kB]
Hit:3 https://repo.zabbix.com/zabbix/5.4/raspbian buster InRelease
Get:4 http://raspbian.raspberrypi.org/raspbian buster InRelease [15.0 kB]
Get:5 http://raspbian.raspberrypi.org/raspbian buster/main armhf Packages [13.0 MB]
Fetched 13.4 MB in 9s (1,513 kB/s)
Reading package lists... Done
Building dependency tree
All packages are up to date.
Re: Repo changed from "stable" to "oldstable", what does this mean?
Tue Aug 24, 2021 8:08 am
It's nothing to worry about.
The main Raspbian repository tracks the Debian repositories. Debian has just upgraded from Buster to Bullseye. Bullseye is their new "stable" release and Buster has been relegated to "oldstable".
When Raspberry Pi are ready, they will release new install images that use Bullseye instead of Buster. That will be fairly soon.
There are some important differences between Buster and Bullseye, most notably the removal of Python 2.
Unreadable squiggle
Taomyn
Tue Aug 24, 2021 8:17 am
Thanks for the prompt response and explanation, I'm glad it's nothing to be concerned over, but my worry stemmed more from the fact that there were zero updates on all my devices which has never happened in the year or so of checking every week - yes I'm a bit thorough in this regard.
greatquux
Tue Aug 24, 2021 8:27 pm
Will we be able to upgrade to the bullseye release when ready with a simple apt update and apt full-upgrade?
roydukkey
Wed Aug 25, 2021 2:05 am
rpdom wrote: [...] they will release new install images that use Bullseye instead of Buster.
Will these images seamlessly apply and install with these commands? Or, will systems currently on Buster diverge from active, regular updates?
sudo apt update
sudo apt full-upgrade
davidcoton
Wed Aug 25, 2021 2:04 pm
sudo apt update
From past history, it is unlikely that cross-version upgrades will be supported.
It is possible that upgrading basic systems will just be a matter of changing the apt sources, but it is also possible that *your* system will break.
The normal mantra will continue to update systems within the original version, but from past history RPT will not continue to provide updates, so only the Debian updates will apply.
electronix_tech
Fri Aug 27, 2021 5:59 pm
I used Solution 1 from this web page and it fixed that problem.
https://exerror.com/repository-http-deb ... e-updates/
Solution 1. sudo apt-get update --allow-releaseinfo-change
HawaiianPi
Fri Aug 27, 2021 7:06 pm
By default update/full-upgrade only performs upgrades to the installed release (Buster will only get Buster updates).
Upgrading to a new major release has never been an approved procedure. Raspberry Pi OS is not a rolling release (meaning, it's not designed to upgrade from one major release to another).
That doesn't mean people won't try it, and some may even be successful, but for others it will end badly. It's always recommended to start fresh which each new major release. For some this may seem like a daunting task, but problems with in-place upgraded systems often cause far more headaches.
pfletch101
Sat Aug 28, 2021 2:15 pm
I share the OP's surprise that there were no available updates after (in my case) 2 weeks since my last apt dist-upgrade. I won't be moving to Bullseye for a couple of months (after it is released) on my 'workhorse' Pi, since I will have a fair amount of configuration and testing to do before I can do this. In the interim, will any Debian Buster updates (presumably largely security-related) be available from the Raspberry Pi Debian Buster repository, or will I need to go direct to the Debian repositories for these.
davidcoton
Sat Aug 28, 2021 2:25 pm
Again, looking at the precedents, security (and other) updates from Debian will be echoed in the RPiOS repository. It is only the RPi specific updates that cease -- RPT do not have the (human) bandwidth to support two versions.
It should not matter, but note that apt full-upgrade has replaced apt dist-upgrade. It's just a name thing, dist-upgrade was misleading because the distribution (wheezy/jessie/stretch/buster/bullseye) actually remains the same, there is no automatic cross-distribution upgrade in apt.
craigevil
Sat Aug 28, 2021 3:41 pm
That is too bad. With Debian you can pretty much go from release to release forever as long as you READ the Release docs.
What changes that rpios can't be upgraded to a new release?
I added the Bullseye repos months ago and everything seems to be working without any problems.
Active apt repos in: /etc/apt/sources.list.d/raspi.list
1: deb https://archive.raspberrypi.org/debian/ buster main
2: deb https://archive.raspberrypi.org/debian/ bullseye main
Raspberry PI 400 Raspberry Pi OS (Debian Sid) Kernel: 6.1.54-v8+ aarch64 DE: XFCE 4.18
Debian - "If you can't apt install something, it isn't useful or doesn't exist"
Sat Aug 28, 2021 3:51 pm
You can certainly try it, but we don't test it, and don't put any effort in to making sure it works. So the choice is yours.
dickon
Sat Aug 28, 2021 7:13 pm
And that having finally been said, I can say without fear of being countered, that it's been flawless every time I've done it. I will happily admit that my systems aren't quite normal -- netbooted, so /dev/mmcblk0p1 size is irrelevant; no desktop -- but the usual Debian update dance has workd for me every time. Headless lite -> lite will probably just work. Desktops possibly not so much.
Snapshot and try it. If you can't snapshot, well, that's another discussion...
Chivar
Tue Aug 31, 2021 2:53 am
2: deb https://archive.raspberrypi.org/debian/ bullseye main <---- this worked for me also i just added it on a new line
allpass
Fri Sep 03, 2021 5:25 pm
This is a big problem for us. We run automatic updates in our product (running on CM3+) that runs apt-get update -y and this change basically breaks hundreds of end-user products in the field. :oops:
Is there a way to revert this so that updates will continue to work? Accepting returns of all these units because the update system is broken or having to explain to several hundred customers how to manually re-image their system is going to be a very expensive prospect for us.
Fri Sep 03, 2021 6:56 pm
I've asked around to see if there is anything that can be done. I don't know enough about it to know where the change came from or what it affects or how to get round it.
However, I am quite concerned about you updating multiple products in the field automatically from the repos without testing first. Really you shouldn't be doing this, as there is really no guarantee that it will work properly afterwards. This is a prime example! For products like this you should provide your own updates that are fully testing and you know will work, not rely on some third party system. Probably your own apt server where you control exactly what goes on, but I am no expert.
PhilE
Fri Sep 03, 2021 7:04 pm
We've never (in my memory) supported upgrades between major OS releases. From https://www.raspberrypi.org/documentati ... rs/os.html (emphasis added):
Note that full-upgrade is used in preference to a simple upgrade, as it also picks up any dependency changes that may have been made.
Generally speaking, doing this regularly will keep your installation up to date for the particular major Raspberry Pi OS release you are using (e.g. Stretch). It will not update from one major release to another, for example, Stretch to Buster.
And further down, before the discussion of dust-upgrade, it says:
Upgrading from Operating System Versions
WARNING
Upgrading an existing image is possible, but is not guaranteed to work in every circumstance and we do not recommend it. If you do wish to try upgrading your operating system version, we strongly suggest making a backup first — we can accept no responsibility for loss of data from a failed update.
PhilE
Fri Sep 03, 2021 7:09 pm
And it's a bit much to say
when what you mean is that they will no longer update.
allpass
Sat Sep 04, 2021 12:11 am
Well sure, but users think it's broken because our app reports an error. ;)
We still had the raspi repos in the sources list but we've locked all package versions to the current ones except for the apt server that serves the latest version of our application. I never thought I had to remove those since I figured they wouldn't change, or that the raspi servers being down wouldn't cause the apt-get update to require user intervention. Indeed during testing we saw some servers down and the process still completed anyway without manual prodding. Obviously it's my fault for not knowing the intricacies of this stuff... I wear many hats. But I don't understand the purpose behind requiring manual changes... I've been using Linux on my desktop for years and never had this happen to me.
Does anyone know of a GUI-based tool that incorporates usbboot and an image writing tool into one program? If my users have to image their units I need something as straightforward as possible. Ideally they could plug in the USB bootloader port on the device, run a program and it would bootload and then update the image in one step. I wrote up instructions for my IT-minded users but a lot of folks don't even know which end of the USB cable is which. :)
AkulaMD
Sat Sep 04, 2021 4:45 am
Hi, newbie question here. What are the noticeable differences with the removal of Python 2 for a normal end user like me who use the Raspberry Pi 4 for watching YouTube, Netflix and browsing internet. Thank you in advance.
Raspberry Pi OS (32-bit) with desktop and recommended software
Raspberry Pi 4 Model B 8GB at stock speed (never overclock)
Never overclock your Pi.
Encourage optimization instead.
craigevil
Sat Sep 04, 2021 5:52 am
None.
jojopi
Sat Sep 04, 2021 6:56 am
The error message from apt-get update (1.8.2.2) is:
E: Repository 'http://raspbian.raspberrypi.org/raspbian buster InRelease' changed its 'Suite' value from 'stable' to 'oldstable'
N: This must be accepted explicitly before updates for this repository can be applied. See apt-secure(8) manpage for details.
This disables the Raspbian repository only, not the Raspberry Pi OS repo, nor any that you have added.
So, can you push a new version of your application with a postinst script to accept the Suite change or otherwise patch the problem? Re-imaging seems a rather extreme solution, and bear in mind Raspberry Pi are not recommending bullseye yet, so you probably want to stay on buster for a few months anyway.
Incidentally, apt 1.8.2.3 was released on April 19, with the only difference being that AllowReleaseInfoChange::Suite defaults to true. If your systems had done an unpinned upgrade between then and August 14, that would also have avoided the problem:
allpass
Sat Sep 04, 2021 1:43 pm
I would love to push a new version of my application but the problem is that apt-get update fails before my update script (triggered by my user application) even has a change to actually upgrade any packages. So the problem is that there seems like no way to actually have any packages update (mine or anyone else's) without console access which is not possible since there is no console accessible to the user.
beta-tester
Sun Sep 05, 2021 4:22 pm
simply replacing buster by bullseye or adding an additional line for bullseye in
/etc/apt/sources.list and /etc/apt/sources.list.d/raspi.list
does not work for me...
when i try to full-upgrade it throws an error:
Calculating upgrade... Error!
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
 libc6-dev : Breaks: libgcc-8-dev (< 8.4.0-2~) but 8.3.0-6+rpi1 is to be installed
E: Error, pkgProblemResolver::Resolve generated breaks, this may be caused by held packages.
jojopi
Sun Sep 05, 2021 4:33 pm
buster has 8.3.0-6+rpi1 and bullseye should have 8.4.0-7+rpi1.
Did you change all references in sources.list and sources.list.d/raspi.list? Did you run apt update before the upgrade?
Return to “Raspberry Pi OS”
