ejolson
MicroPython double precision
Mon Sep 13, 2021 2:33 pm
Does anyone know if there is an official MicroPython for the Pico available that has been built with support for double-precision floating-point arithmetic?
The one I downloaded from the getting started defaults to single precision.
From what I understand this is a compile time setting. I understand rebuilding the uf2 is an option. Are there instructions building a double-precision version for the Pico? Has anyone tried or done this?
hippy
Re: MicroPython double precision
Mon Sep 13, 2021 3:53 pm
Funnily enough I had noticed your comment about MicroPython only being single precision in the BBC Basic thread. I looked into that yesterday and found it's a simple fix -
mpconfigport.h - around line 65 ...
#define MICROPY_FLOAT_IMPL                      (MICROPY_FLOAT_IMPL_FLOAT)
Needs to change to ...
#define MICROPY_FLOAT_IMPL                      (MICROPY_FLOAT_IMPL_DOUBLE)
To build as a cloned port ...
cd ~/pico/micropython/ports
cp -r rp2 rp2double
cd rp2double
nano mpconfigport.h           # As above
rm -r -f build
mkdir build
cd build
cmake ..
make
My version of the kahan test mentioned -
import time
#        123456789-12345
flt = 14.392726722865724
print("")
print("Floating point format test")
print("")
print(flt)
print("")
print("14.4               -> {:0.1f}".format(flt))
print("14.39              -> {:0.2f}".format(flt))
print("14.393             -> {:0.3f}".format(flt))
print("14.3927            -> {:0.4f}".format(flt))
print("14.39273           -> {:0.5f}".format(flt))
print("14.392727          -> {:0.6f}".format(flt))
print("14.3927267         -> {:0.7f}".format(flt))
print("14.39272672        -> {:0.8f}".format(flt))
print("14.392726723       -> {:0.9f}".format(flt))
print("14.3927267229      -> {:0.10f}".format(flt))
print("14.39272672287     -> {:0.11f}".format(flt))
print("14.392726722866    -> {:0.12f}".format(flt))
print("14.3927267228657   -> {:0.13f}".format(flt))
print("14.39272672286572  -> {:0.14f}".format(flt))
print("14.392726722865724 -> {:0.15f}".format(flt))
# https://www.raspberrypi.org/forums/viewtopic.php?f=144&t=316761&start=625
# 14.392726722865724
# Total elapsed time 8.883 seconds
print("")
print("Floating point kahan test ... please wait - takes about 80 seconds")
print("")
tstart = time.ticks_us()
n = 1_000_000
s = 0
c = 0
for k in range(1, n+1):
    v = 1 / k + c
    snext = s + v
    c = v - (snext - s)
    s = snext
tstop = time.ticks_us()
print(s)
print("14.392726722865724 -> {:0.15f}".format(s))
print("Total elapsed time {} seconds".format((tstop-tstart)/1_000_000))
On stock firmware (float) ..
14.39273
14.4               -> 14.4
14.39              -> 14.39
14.393             -> 14.393
14.3927            -> 14.3927
14.39273           -> 14.39273
14.392727          -> 14.392733          <-- Diverges here (float)
14.3927267         -> 14.3927326
14.39272672        -> 14.39273262
14.392726723       -> 14.392732620
14.3927267229      -> 14.3927326202
14.39272672287     -> 14.39273262024
14.392726722866    -> 14.392732620239
14.3927267228657   -> 14.3927326202393
14.39272672286572  -> 14.39273262023926
14.392726722865724 -> 14.392732620239258
14.39273
14.392726722865724 -> 14.392727851867676
Total elapsed time 72.93056 seconds
Using firmware build for "double" ...
14.39272672286573
14.4               -> 14.4
14.39              -> 14.39
14.393             -> 14.393
14.3927            -> 14.3927
14.392727          -> 14.392727
14.3927267         -> 14.3927267
14.39272672        -> 14.39272672
14.392726723       -> 14.392726723
14.3927267229      -> 14.3927267229
14.39272672287     -> 14.39272672287
14.392726722866    -> 14.392726722866
14.3927267228657   -> 14.3927267228657
14.39272672286572  -> 14.39272672286573  <-- Diverges here (double)
14.392726722865724 -> 14.392726722865725
14.39272672286573
Total elapsed time 76.64488 seconds
The time penalty for going to double doesn't seem that bad here.
ejolson
Mon Sep 13, 2021 4:22 pm
cp -r rp2 rp2double
cd rp2double
rm -r -f build
mkdir build
cd build
cmake ..
make
import time
#        123456789-12345
print("")
print("")
print(flt)
print("")
print("")
print("")
n = 1_000_000
s = 0
c = 0
    v = 1 / k + c
    snext = s + v
    c = v - (snext - s)
    s = snext
print(s)
14.39273
14.4               -> 14.4
14.39              -> 14.39
14.393             -> 14.393
14.3927            -> 14.3927
14.39273
14.39272672286573
14.4               -> 14.4
14.39              -> 14.39
14.393             -> 14.393
14.3927            -> 14.3927
14.39272672286573
Thanks for running that test!
I find it interesting that the speed penalty for double precision is dwarfed by other inefficiencies in the interpreter. From what I understand single precision is not accurate enough for banking, science, engineering or mathematics and not fast enough for machine learning.
I wonder why single precision was chosen as the default.
hippy
Mon Sep 13, 2021 6:14 pm
Main reason is probably that's how it is for other ports so that's how it got implemented for the RP2040.
I would also guess that most applications run on a microcontroller don't require double precision so it makes sense to default to single precision.
jahboater
Mon Sep 13, 2021 6:36 pm
For the C language, speed is critical and yet double precision is the default (and it has always been so).
I believe single precision is used to save memory when allocating large arrays, it is rarely used to improve speed.
scruss
Mon Sep 13, 2021 6:51 pm
With regular computers, that's definitely true. With micro controllers, very few of them have double precision hardware floating point and you are working with constrained memory. The Cortex-M7 in the Teensy 4 is the only one I know of that has hardware double-precision floating point support built in. Cortex-M4, as seen in many other MicroPython boards, has 32-bit floating point in hardware. The Cortex-M0+ in the Pico has no floating point support beyond the software library shipped in the ROM.
Pronouns: he/him
hippy
Mon Sep 13, 2021 6:59 pm
As an amateur C programmer you might have to explain that to me. I thought one always got 32-bit single precision if one specified "float", 64-bit "double", and I am guessing 128-bit for "long double". I am not seeing where any "default" comes into it
trejan
Mon Sep 13, 2021 7:06 pm
IEEE 754 floating point is trap for the unwary due to its limitations on representing numbers. If you need high precision then you use a bignum library not floats or doubles.
Guess the output of this short program.
#include <stdio.h>
int main()
  double total = 0.0;
  for (int i = 0; i < 10000000; i++) {
    total += 0.2;
  printf("%f\n", total);
scruss
Mon Sep 13, 2021 8:08 pm
... and yet BASIC on the TI-99/4A managed it without bignums:
>list
10 T=0
20 FOR I=1 TO 10000000
30 T=T+0.2
40 NEXT I
50 PRINT T
60 END
>run
 2000000
** DONE **
Pronouns: he/him
trejan
Mon Sep 13, 2021 8:24 pm
It uses a different floating point number format. TI BASIC can accurately store 0.2 unlike IEEE 754. It isn't as efficient if you're implementing it in hardware though. IEEE 754 is basically Intel's design.
ejolson
Mon Sep 13, 2021 8:44 pm
>list
10 T=0
30 T=T+0.2
40 NEXT I
50 PRINT T
60 END
>run
 2000000
** DONE **
How long does it take a TI-99/4A to add all that up?
jahboater
Mon Sep 13, 2021 10:28 pm
Hippy,
The literal 3.14 is a double. You have to add a suffix F to make it a float, or L to make it a long double.
The library functions, for example sin() default to double, that is, they take a double argument and return a double.
You have to use sinf() for floats and sinl() for long double.
So the familiar sin(3.14) gets a double argument as expected and returns a double.
For float that would be sinf(3.14f), not so nice.
And so on.
If "double" doesnt read well, I just do
typedef double real;
and all is well.
Paeryn
Mon Sep 13, 2021 10:33 pm
<edit: oh, jahboater replied whilst I was typing away...>
I presume jahboater is referring to the fact that a floating point literal without a size suffix is a double. That means that in the following function
float scale( float x )
  return x * 1.1;
the compiler will promote x to a double, do the multiplication and then demote the result to a float. To avoid the automatic promotion / demotion you have to tell the compiler that 1.1 is only a float e.g.
  return x * 1.1f;
Also a lot of people probably just use the maths functions like sin() even when passing a float and assigning the returned value to a float (sin() takes and returns double, the single precision version is sinf()).
And long double isn't necessarily a 128-bit float, it only has to be at least as long as a double (64-bit) but it could be Intel's extended (80-bit). GCC has __float128 for quad precision floats where available and the suffix for such literals is q.
jahboater
Mon Sep 13, 2021 10:35 pm
Since 2008, 0.2 can be stored.
That is IEEE 754 supports decimal, as well as binary, floating-point.
You can use that now in C as _Decimal32, _Decimal64, and _Decimal128.
jahboater
Mon Sep 13, 2021 10:37 pm
On the Pi, that's one advantage of 64-bit mode.
Long double is 128-bits for aarch64, and only 64-bits for ARM32.
trejan
Mon Sep 13, 2021 11:18 pm
Since IEEE 754-2008, 0.2 can be stored, and 0.3 + 0.3 + 0.3 == 1.0
Yep but DFP is optional so not everything supports it. The FPUs in the various Pi SoCs don't. The stock GCC used for the Pico SDK doesn't support it either.
scruss
Tue Sep 14, 2021 12:34 am
I know. And if you thought that DFP was slow, the bigfloats you recommended are positively glacial. Your test code was the "never do this" that you'd get in any numerical analysis intro, too.
I really don't want to know. I used abbeyj/ti99basic: TI-99/4A BASIC as a scripting language, which claims to be a portable emulator of the VM that TI BASIC ran in.
An MSX 1, which also uses decimal floating point, would take over 13 hours to calculate that sum.
Pronouns: he/him
jahboater
Tue Sep 14, 2021 1:23 am
I'll stick with binary, its close enough for most things except currency perhaps.
The example takes 16 milliseconds on a Pi4.
ejolson
Tue Sep 14, 2021 1:27 am
I thought it was maybe an emulator.
It seems a million terms is too few for C on a modern x86 processor. I adapted the C code from
viewtopic.php?p=1912396#p1912396
to create a Linux test for both single and double precision.
On a Ryzen 1700 the result was
$ gcc -O2 -Wall -o kahan kahan.c
$ ./kahan
n=1000000000
21.300481502347942
Elapsed double time 4.163 seconds
21.300481796264648
Elapsed float time 4.611 seconds
This implies double precision is about 10 percent faster. There was an even greater advantage for the PDP-11 on which the C programming language was originally developed; however, I think the Living Computers Museum
https://www.livingcomputers.org/
replaced misspiggy with an emulator so it's difficult to check.
For reference the code is
#include <stdio.h>
#include <stdarg.h>
#ifdef PICO
#define NMAX 1000000
#include <pico/stdlib.h>
#include <pico/time.h>
#include "tusb.h"
unsigned int ticks_ms(){
    absolute_time_t t=get_absolute_time();
    return to_ms_since_boot(t);
#else
#define NMAX 1000000000
#include <time.h>
#include <unistd.h>
#include <stdint.h>
    static struct timespec s,t;
    clock_gettime(CLOCK_MONOTONIC_RAW,&t);
    if(!s.tv_sec) s=t;
    return (t.tv_sec-s.tv_sec)*1000+(t.tv_nsec-s.tv_nsec)/1000000;
int sleep_ms(uint32_t usec){
    return usleep((useconds_t)usec*1000);
#endif
double dosum(){
    unsigned int n=NMAX;
    double s=0;
    double c=0;
    for(unsigned int k=1;k<=n;k++){
        double v=1.0/k+c;
        double snext=s+v;
        c=v-(snext-s);
        s=snext;
    return s;
float dosumf(){
    float s=0;
    float c=0;
        float v=1.0f/k+c;
        float snext=s+v;
        c=v-(snext-s);
        s=snext;
    return s;
extern int dogprintf(const char *restrict fmt,...)
    __attribute__((format(printf,1,2)));
int dogprintf(const char *restrict fmt,...){
    va_list ap;
    va_start(ap,fmt);
    int r=vprintf(fmt,ap);
    fflush(stdout);
    return r;
#define printf dogprintf
int main(){
#ifdef PICO
    stdio_init_all();
    printf("Waiting for usb host");
    while(!tud_cdc_connected()){
      printf(".");
      sleep_ms(500);
    printf("\n");
#endif
    unsigned int tstart,tstop;
    double s;
    printf("n=%u\n",NMAX);
    printf("\n");
    tstart=ticks_ms();
    s=dosum();
    tstop=ticks_ms();
    printf("%.15f\n",s);
    printf("Elapsed double time %g seconds\n",(tstop-tstart)/1000.0);
    printf("\n");
    tstart=ticks_ms();
    s=dosumf();
    tstop=ticks_ms();
    printf("Elapsed float time %g seconds\n",(tstop-tstart)/1000.0);
    sleep_ms(500);
    return 0;
I think -DPICO allows the code to still compile for the Pico, but I didn't check what the performance differences were for that platform.
jahboater
Tue Sep 14, 2021 1:43 am
That's interesting.
Double is slightly slower on the Pi4:
$ gcc -s -O2 try.c -o try
$ ./try
n=1000000000
21.300481502347942
Elapsed double time 7.626 seconds
21.300481796264648
Elapsed float time 7.149 seconds
ejolson
Tue Sep 14, 2021 2:07 am
That's interesting.
$ ./try
n=1000000000
21.300481502347942
21.300481796264648
Did you set the CPU governor to performance? If not, there may be a slight performance hit on the first timing as the CPU ramps up its clock speed.
On 32-bit Raspberry Pi OS using gcc 8.3.0 on the Pi 4B I get
$ ./kahan
n=1000000000
21.300481502347942
Elapsed double time 10.692 seconds
21.300481796264648
Elapsed float time 9.35 seconds
which is slower than your times. Is your Pi over clocked?
I tried a few other x86 machines ranging from a 486DX2 to more recent XEON and EPYC servers. In each case the single and double precision speeds were within about 10 percent of each other.
I may have misspoken about the PDP-11. Although the hardware only supported double precision, it's possible the compiler did not bother to maintain single precision accuracy at intermediate points in a computation. In that case execution speed would be essentially identical using either float or double.
Trying to time anything on the emulator generates random numbers for me. If anyone has Unix running on vintage PDP-11 hardware, here is a version of kahan.c that will compile using the Kernighan and Ritchey C compiler.
#include <stdio.h>
#include <sys/types.h>
#include <sys/timeb.h>
#define NMAX 1000000l
static double toc_start;
double toc(){
    struct timeb ts;
    ftime(&ts);
    return ts.time+ts.millitm/1000.0-toc_start;
double tic(){
    toc_start+=toc();
    return toc_start;
double dosum(){
    double s=0;
    double c=0;
    long k;
    for(k=1;k<=NMAX;k++){
        double v=1.0/k+c;
        double snext=s+v;
        c=v-(snext-s);
        s=snext;
    return s;
float dosumf(){
    float s=0;
    float c=0;
    long k;
        float v=1.0/k+c;
        float snext=s+v;
        c=v-(snext-s);
        s=snext;
    return s;
int main(){
    double s,t;
    printf("n=%lu\n",NMAX);
    printf("\n");
    tic();
    s=dosum();
    t=toc();
    printf("Elapsed double time %g seconds\n",t);
    printf("\n");
    tic();
    s=dosumf();
    t=toc();
    printf("Elapsed float time %g seconds\n",t);
    return 0;
Please post any results here for comparison.
Note that double precision on graphics cards can be as much as 32 times slower than single precision. What I find surprising is how close the double and single precision versions of MicroPython are even though the Pico does everything related to floating point in software. Could it really?
ejolson
Tue Sep 14, 2021 3:50 am
Here is an interesting data point. If I accidentally leave the suffix off of 1.0f in the single precision dosumf routine I get
$ ./kahan ; # Ryzen 1700
n=1000000000
21.300481502347942
Elapsed double time 4.191 seconds
21.300481796264648
Elapsed float time 6.394 seconds
which shows single precision can turn out to be much slower than double precision if one uses the wrong type of floating point constants.
jahboater
Tue Sep 14, 2021 5:22 am
I changed to "performance" with similar results.
$ ./kahan
n=1000000000
21.300481502347942
21.300481796264648
This Pi runs Raspberry Pi OS 64-bit, GCC 11.2, CPU clock 2.1GHz.
Dropping the overclock gives:
$ ./try
n=1000000000
21.300481502347942
Elapsed double time 10.68 seconds
21.300481796264648
Elapsed float time 10.015 seconds
which are close enough to your figures.
jahboater
Tue Sep 14, 2021 5:43 am
Yes, it is doing extra single/double conversions. Here is the loop with the conversions in bold:
.L10:
// try.c:48: float v=1.0/k+c;
scvtf d1, w0 // tmp103, k
fcvt d2, s2 // tmp106, c
// try.c:47: for(unsigned int k=1;k<=n;k++){
add w0, w0, 1 // k, k,
fmov s3, s0 // s, <retval>
cmp w0, w1 // k, tmp109
fdiv d1, d4, d1 // tmp104, tmp105, tmp103
fadd d1, d1, d2 // tmp107, tmp104, tmp106
fcvt s1, d1 // v, tmp107
// try.c:49: float snext=s+v;
fadd s0, s0, s1 // <retval>, <retval>, v
// try.c:50: c=v-(snext-s);
fsub s2, s0, s3 // tmp108, <retval>, s
fsub s2, s1, s2 // c, v, tmp108
bne .L10 //,
The 64-bit FDIV is probably slower too.
fanoush
Tue Sep 14, 2021 12:48 pm
  return x * 1.1;
  return x * 1.1f;
there are also gcc options
-fsingle-precision-constant -Wdouble-promotion -Wfloat-conversion
that would change the default to float not requiring the 'f' everywhere an also warns if any promotion to double like you described is happening.
Useful with Cortex M4F to stay in HW 32bit floats as much as possible.
Return to “MicroPython”
