Nezra
Nvme and asm1164e
Mon Sep 20, 2021 12:40 pm
Curious if anyone has seen this, knows why, or has a solution.
My setup is Raspbian, a CM4 8gb wifi, no emmc, and two asm1164e based boards.
I'm trying to add multiple nvme drives to it. When I have 4 drives, it boots fine. If I add a 5th, it kernel panics in the first few seconds and blanks the screen. I've tried different adaptors and drives. 4 is stable, 5 or more panics. It happens before the log is flushed to disk, so I can't see them. It doesn't matter what slot they are in either.
It's not a limitation of devices, because I can add additional pcie devices to it, including usb 3.0 hubs when it has 4 drives installed.
In short, anyone have an idea of why or where the limitation could be? Or a solution idea or what I could do to see the logs?
PhilE
Re: Nvme and asm1164e
Mon Sep 20, 2021 12:50 pm
There's a suggestion here that you might be running out of MSI interrupts. What does "sudo lspci -vvv" report for a working system with 4 NVME drives attached?
Nezra
Mon Sep 20, 2021 3:36 pm
Here's the output as suggested, 4 drives, just the two ASM1164e boards attached to the CM4 IO board. no other pcie devices attached. i'll put the 00:00.0 and 01:00.0 in a different post due to character limitations
02:01.0 PCI bridge: ASMedia Technology Inc. ASM1184e PCIe Switch Port (prog-if 00 [Normal decode])
        Control: I/O- Mem- BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr+ Stepping- SERR+ FastB2B- DisINTx+
        Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
        Latency: 0, Cache Line Size: 64 bytes
        Interrupt: pin A routed to IRQ 66
        Bus: primary=02, secondary=03, subordinate=03, sec-latency=0
        I/O behind bridge: 0000f000-00000fff
        Memory behind bridge: fff00000-000fffff
        Prefetchable memory behind bridge: 00000000fff00000-00000000000fffff
        Secondary status: 66MHz- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- <SERR- <PERR-
        BridgeCtl: Parity+ SERR+ NoISA- VGA- MAbort- >Reset- FastB2B-
                PriDiscTmr- SecDiscTmr- DiscTmrStat- DiscTmrSERREn-
        Capabilities: [50] MSI: Enable+ Count=1/1 Maskable- 64bit+
                Address: 00000000fffffffc  Data: 6540
        Capabilities: [78] Power Management version 3
                Flags: PMEClk- DSI- D1- D2- AuxCurrent=0mA PME(D0+,D1-,D2-,D3hot+,D3cold+)
                Status: D0 NoSoftRst+ PME-Enable- DSel=0 DScale=0 PME-
        Capabilities: [80] Express (v2) Downstream Port (Slot+), MSI 00
                DevCap: MaxPayload 256 bytes, PhantFunc 0
                        ExtTag+ RBE+
                DevCtl: Report errors: Correctable- Non-Fatal- Fatal- Unsupported-
                        RlxdOrd+ ExtTag+ PhantFunc- AuxPwr- NoSnoop+
                        MaxPayload 128 bytes, MaxReadReq 512 bytes
                DevSta: CorrErr- UncorrErr- FatalErr- UnsuppReq- AuxPwr+ TransPend-
                LnkCap: Port #1, Speed 5GT/s, Width x1, ASPM L0s L1, Exit Latency L0s unlimited, L1 unlimited
                        ClockPM- Surprise- LLActRep+ BwNot+ ASPMOptComp+
                LnkCtl: ASPM Disabled; Disabled- CommClk-
                        ExtSynch- ClockPM- AutWidDis- BWInt- AutBWInt-
                LnkSta: Speed 2.5GT/s, Width x1, TrErr- Train- SlotClk+ DLActive- BWMgmt- ABWMgmt-
                SltCap: AttnBtn- PwrCtrl- MRL- AttnInd- PwrInd- HotPlug- Surprise-
                        Slot #1, PowerLimit 26.000W; Interlock- NoCompl-
                SltCtl: Enable: AttnBtn- PwrFlt- MRL- PresDet- CmdCplt- HPIrq- LinkChg-
                        Control: AttnInd Unknown, PwrInd Unknown, Power- Interlock-
                SltSta: Status: AttnBtn- PowerFlt- MRL- CmdCplt- PresDet- Interlock-
                        Changed: MRL- PresDet- LinkState-
                DevCap2: Completion Timeout: Not Supported, TimeoutDis-, LTR-, OBFF Not Supported ARIFwd-
                DevCtl2: Completion Timeout: 50us to 50ms, TimeoutDis-, LTR-, OBFF Disabled ARIFwd-
                LnkCtl2: Target Link Speed: 5GT/s, EnterCompliance- SpeedDis-, Selectable De-emphasis: -6dB
                         Transmit Margin: Normal Operating Range, EnterModifiedCompliance- ComplianceSOS-
                         Compliance De-emphasis: -6dB
                LnkSta2: Current De-emphasis Level: -3.5dB, EqualizationComplete-, EqualizationPhase1-
                         EqualizationPhase2-, EqualizationPhase3-, LinkEqualizationRequest-
        Capabilities: [c0] Subsystem: ASMedia Technology Inc. ASM1184e PCIe Switch Port
        Capabilities: [100 v1] Virtual Channel
                Caps:   LPEVC=0 RefClk=100ns PATEntryBits=1
                Arb:    Fixed- WRR32- WRR64- WRR128-
                Ctrl:   ArbSelect=Fixed
                Status: InProgress-
                VC0:    Caps:   PATOffset=00 MaxTimeSlots=1 RejSnoopTrans-
                        Arb:    Fixed+ WRR32- WRR64- WRR128- TWRR128- WRR256-
                        Ctrl:   Enable+ ID=0 ArbSelect=Fixed TC/VC=ff
                        Status: NegoPending+ InProgress-
        Capabilities: [200 v1] Advanced Error Reporting
                UESta:  DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
                UEMsk:  DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
                UESvrt: DLP+ SDES+ TLP- FCP+ CmpltTO- CmpltAbrt- UnxCmplt- RxOF+ MalfTLP+ ECRC- UnsupReq- ACSViol-
                CESta:  RxErr- BadTLP- BadDLLP- Rollover- Timeout- NonFatalErr-
                CEMsk:  RxErr- BadTLP- BadDLLP- Rollover- Timeout- NonFatalErr+
                AERCap: First Error Pointer: 1f, GenCap+ CGenEn- ChkCap+ ChkEn-
        Kernel driver in use: pcieport
02:03.0 PCI bridge: ASMedia Technology Inc. ASM1184e PCIe Switch Port (prog-if 00 [Normal decode])
        Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr+ Stepping- SERR+ FastB2B- DisINTx+
        Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR+ <PERR- INTx-
        Interrupt: pin A routed to IRQ 67
        Bus: primary=02, secondary=04, subordinate=09, sec-latency=0
        Memory behind bridge: c0000000-c03fffff
        Secondary status: 66MHz- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- <SERR+ <PERR-
                Address: 00000000fffffffc  Data: 6541
                        ExtTag+ RBE+
                LnkCap: Port #3, Speed 5GT/s, Width x1, ASPM L0s L1, Exit Latency L0s unlimited, L1 unlimited
                LnkSta: Speed 5GT/s, Width x1, TrErr- Train- SlotClk+ DLActive+ BWMgmt+ ABWMgmt-
                        Slot #3, PowerLimit 26.000W; Interlock- NoCompl-
                        Changed: MRL- PresDet- LinkState+
                LnkSta2: Current De-emphasis Level: -6dB, EqualizationComplete-, EqualizationPhase1-
                Status: InProgress-
                        Status: NegoPending- InProgress-
02:05.0 PCI bridge: ASMedia Technology Inc. ASM1184e PCIe Switch Port (prog-if 00 [Normal decode])
        Interrupt: pin A routed to IRQ 68
        Bus: primary=02, secondary=0a, subordinate=0a, sec-latency=0
                Address: 00000000fffffffc  Data: 6542
                        ExtTag+ RBE+
                LnkCap: Port #5, Speed 5GT/s, Width x1, ASPM L0s L1, Exit Latency L0s unlimited, L1 unlimited
                        Slot #5, PowerLimit 26.000W; Interlock- NoCompl-
                Status: InProgress-
02:07.0 PCI bridge: ASMedia Technology Inc. ASM1184e PCIe Switch Port (prog-if 00 [Normal decode])
        Interrupt: pin A routed to IRQ 69
        Bus: primary=02, secondary=0b, subordinate=0b, sec-latency=0
                Address: 00000000fffffffc  Data: 6543
                        ExtTag+ RBE+
                LnkCap: Port #7, Speed 5GT/s, Width x1, ASPM L0s L1, Exit Latency L0s unlimited, L1 unlimited
                        Slot #7, PowerLimit 26.000W; Interlock- NoCompl-
                Status: InProgress-
04:00.0 PCI bridge: ASMedia Technology Inc. ASM1184e PCIe Switch Port (prog-if 00 [Normal decode])
        Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr+ Stepping- SERR+ FastB2B- DisINTx-
        Interrupt: pin A routed to IRQ 65
        Bus: primary=04, secondary=05, subordinate=09, sec-latency=0
        Capabilities: [50] MSI: Enable- Count=1/1 Maskable- 64bit+
                Address: 0000000000000000  Data: 0000
        Capabilities: [80] Express (v2) Upstream Port, MSI 00
                        ExtTag+ AttnBtn- AttnInd- PwrInd- RBE+ SlotPowerLimit 26.000W
                LnkCap: Port #0, Speed 5GT/s, Width x1, ASPM L0s L1, Exit Latency L0s unlimited, L1 unlimited
                        ClockPM- Surprise- LLActRep- BwNot- ASPMOptComp+
                LnkSta: Speed 5GT/s, Width x1, TrErr- Train- SlotClk+ DLActive- BWMgmt- ABWMgmt-
                Status: InProgress-
                CESta:  RxErr+ BadTLP- BadDLLP- Rollover- Timeout- NonFatalErr-
        Capabilities: [300 v1] Vendor Specific Information: ID=0000 Rev=0 Len=c00 <?>
05:01.0 PCI bridge: ASMedia Technology Inc. ASM1184e PCIe Switch Port (prog-if 00 [Normal decode])
        Interrupt: pin A routed to IRQ 70
        Bus: primary=05, secondary=06, subordinate=06, sec-latency=0
        Memory behind bridge: c0000000-c00fffff
                Address: 00000000fffffffc  Data: 6544
                        ExtTag+ RBE+
                DevSta: CorrErr+ UncorrErr- FatalErr- UnsuppReq- AuxPwr+ TransPend-
                Status: InProgress-
                CESta:  RxErr+ BadTLP+ BadDLLP- Rollover- Timeout- NonFatalErr-
05:03.0 PCI bridge: ASMedia Technology Inc. ASM1184e PCIe Switch Port (prog-if 00 [Normal decode])
        Interrupt: pin A routed to IRQ 71
        Bus: primary=05, secondary=07, subordinate=07, sec-latency=0
        Memory behind bridge: c0100000-c01fffff
                Address: 00000000fffffffc  Data: 6545
                        ExtTag+ RBE+
                DevSta: CorrErr+ UncorrErr- FatalErr+ UnsuppReq- AuxPwr+ TransPend-
                Status: InProgress-
                UESta:  DLP- SDES- TLP- FCP+ CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
                CESta:  RxErr+ BadTLP+ BadDLLP+ Rollover+ Timeout+ NonFatalErr-
                AERCap: First Error Pointer: 0d, GenCap+ CGenEn- ChkCap+ ChkEn-
05:05.0 PCI bridge: ASMedia Technology Inc. ASM1184e PCIe Switch Port (prog-if 00 [Normal decode])
        Interrupt: pin A routed to IRQ 72
        Bus: primary=05, secondary=08, subordinate=08, sec-latency=0
        Memory behind bridge: c0200000-c02fffff
                Address: 00000000fffffffc  Data: 6546
                        ExtTag+ RBE+
                Status: InProgress-
                CESta:  RxErr+ BadTLP+ BadDLLP- Rollover+ Timeout+ NonFatalErr-
05:07.0 PCI bridge: ASMedia Technology Inc. ASM1184e PCIe Switch Port (prog-if 00 [Normal decode])
        Interrupt: pin A routed to IRQ 73
        Bus: primary=05, secondary=09, subordinate=09, sec-latency=0
        Memory behind bridge: c0300000-c03fffff
                Address: 00000000fffffffc  Data: 6547
                        ExtTag+ RBE+
                Status: InProgress-
06:00.0 Non-Volatile memory controller: Device 1e95:9100 (rev 03) (prog-if 02 [NVM Express])
        Subsystem: Silicon Motion, Inc. Device 2263
        Interrupt: pin A routed to IRQ 0
        Region 0: Memory at 600000000 (64-bit, non-prefetchable) [size=16K]
        Capabilities: [40] Power Management version 3
                Flags: PMEClk- DSI- D1- D2- AuxCurrent=0mA PME(D0-,D1-,D2-,D3hot-,D3cold-)
        Capabilities: [50] MSI: Enable- Count=1/8 Maskable+ 64bit+
                Masking: 00000000  Pending: 00000000
        Capabilities: [70] Express (v2) Endpoint, MSI 00
                DevCap: MaxPayload 128 bytes, PhantFunc 0, Latency L0s unlimited, L1 unlimited
                        ExtTag- AttnBtn- AttnInd- PwrInd- RBE+ FLReset+ SlotPowerLimit 26.000W
                        RlxdOrd+ ExtTag- PhantFunc- AuxPwr- NoSnoop- FLReset-
                LnkCap: Port #0, Speed 8GT/s, Width x4, ASPM L1, Exit Latency L0s <1us, L1 <8us
                        ClockPM+ Surprise- LLActRep- BwNot- ASPMOptComp+
                LnkCtl: ASPM Disabled; RCB 64 bytes Disabled- CommClk-
                DevCap2: Completion Timeout: Range ABCD, TimeoutDis+, LTR+, OBFF Not Supported
                LnkCtl2: Target Link Speed: 8GT/s, EnterCompliance- SpeedDis-
                         Transmit Margin: Normal Operating Range, EnterModifiedCompliance- ComplianceSOS+
                         Compliance De-emphasis: Unknown
        Capabilities: [b0] MSI-X: Enable+ Count=16 Masked-
                Vector table: BAR=0 offset=00002000
                PBA: BAR=0 offset=00002100
        Capabilities: [100 v2] Advanced Error Reporting
                AERCap: First Error Pointer: 00, GenCap+ CGenEn- ChkCap+ ChkEn-
        Capabilities: [158 v1] #19
        Capabilities: [178 v1] Latency Tolerance Reporting
                Max snoop latency: 0ns
                Max no snoop latency: 0ns
        Capabilities: [180 v1] L1 PM Substates
                L1SubCap: PCI-PM_L1.2+ PCI-PM_L1.1+ ASPM_L1.2+ ASPM_L1.1+ L1_PM_Substates+
                          PortCommonModeRestoreTime=10us PortTPowerOnTime=10us
                L1SubCtl1: PCI-PM_L1.2- PCI-PM_L1.1- ASPM_L1.2- ASPM_L1.1-
                           T_CommonMode=0us LTR1.2_Threshold=0ns
                L1SubCtl2: T_PwrOn=10us
        Kernel driver in use: nvme
07:00.0 Non-Volatile memory controller: Device 1e95:9100 (rev 03) (prog-if 02 [NVM Express])
        Region 0: Memory at 600100000 (64-bit, non-prefetchable) [size=16K]
                CESta:  RxErr- BadTLP+ BadDLLP+ Rollover+ Timeout+ NonFatalErr-
08:00.0 Non-Volatile memory controller: Device 1e95:9100 (rev 03) (prog-if 02 [NVM Express])
        Region 0: Memory at 600200000 (64-bit, non-prefetchable) [size=16K]
09:00.0 Non-Volatile memory controller: Device 1e95:9100 (rev 03) (prog-if 02 [NVM Express])
        Region 0: Memory at 600300000 (64-bit, non-prefetchable) [size=16K]
Nezra
Mon Sep 20, 2021 3:37 pm
and the output from 00:00.0 nd 01:00.0:
00:00.0 PCI bridge: Broadcom Limited Device 2711 (rev 20) (prog-if 00 [Normal decode])
        Bus: primary=00, secondary=01, subordinate=0b, sec-latency=0
        I/O behind bridge: 00000000-00000fff
        Secondary status: 66MHz- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort+ <SERR+ <PERR-
        Capabilities: [48] Power Management version 3
                Flags: PMEClk- DSI- D1- D2- AuxCurrent=0mA PME(D0+,D1-,D2-,D3hot+,D3cold-)
                Status: D0 NoSoftRst+ PME-Enable- DSel=0 DScale=1 PME-
        Capabilities: [ac] Express (v2) Root Port (Slot-), MSI 00
                DevCap: MaxPayload 512 bytes, PhantFunc 0
                        ExtTag- RBE+
                        RlxdOrd+ ExtTag- PhantFunc- AuxPwr+ NoSnoop+
                DevSta: CorrErr+ UncorrErr- FatalErr- UnsuppReq- AuxPwr- TransPend-
                LnkCap: Port #0, Speed 5GT/s, Width x1, ASPM L0s L1, Exit Latency L0s <2us, L1 <4us
                        ClockPM+ Surprise- LLActRep- BwNot+ ASPMOptComp+
                LnkSta: Speed 5GT/s, Width x1, TrErr- Train- SlotClk+ DLActive- BWMgmt- ABWMgmt+
                RootCtl: ErrCorrectable- ErrNon-Fatal- ErrFatal- PMEIntEna+ CRSVisible+
                RootCap: CRSVisible+
                RootSta: PME ReqID 0000, PMEStatus- PMEPending-
                DevCap2: Completion Timeout: Range ABCD, TimeoutDis+, LTR+, OBFF Via WAKE# ARIFwd-
        Capabilities: [100 v1] Advanced Error Reporting
                CESta:  RxErr- BadTLP+ BadDLLP+ Rollover- Timeout+ NonFatalErr-
                AERCap: First Error Pointer: 00, GenCap- CGenEn- ChkCap- ChkEn-
        Capabilities: [180 v1] Vendor Specific Information: ID=0000 Rev=0 Len=028 <?>
        Capabilities: [240 v1] L1 PM Substates
                          PortCommonModeRestoreTime=8us PortTPowerOnTime=10us
                           T_CommonMode=1us LTR1.2_Threshold=0ns
01:00.0 PCI bridge: ASMedia Technology Inc. ASM1184e PCIe Switch Port (prog-if 00 [Normal decode])
        Bus: primary=01, secondary=02, subordinate=0b, sec-latency=0
                        ExtTag+ AttnBtn- AttnInd- PwrInd- RBE+ SlotPowerLimit 0.000W
                Status: InProgress-
                CESta:  RxErr- BadTLP- BadDLLP- Rollover+ Timeout+ NonFatalErr+
PhilE
Mon Sep 20, 2021 4:21 pm
Hmm - even with just(!) those 4 drives, that's a lot of MSIs:
Running "cat /proc/interrupts" might give a clearer picture of how many of those MSIs are actually claimed.
Nezra
Mon Sep 20, 2021 5:09 pm
Thanks for looking into it. here's the interrupt list requested.
          CPU0       CPU1       CPU2       CPU3
 25:          2          0          0          0     GICv2  99 Level     timer
 26:          0          0          0          0     GICv2  29 Level     arch_timer
 27:     201352     160394     161717     109668     GICv2  30 Level     arch_timer
 33:      39267          0          0          0     GICv2  65 Level     fe00b880.mailbox
 36:       6781          0          0          0     GICv2 153 Level     uart-pl011
 37:         18          0          0          0     GICv2 149 Level     fe205000.i2c, fe804000.i2c
 38:   47609590          0          0          0     GICv2 105 Level     fe980000.usb, dwc2_hsotg:usb1
 42:       1607          0          0          0     GICv2 114 Level     DMA IRQ
 49:         45          0          0          0     GICv2  66 Level     VCHIQ doorbell
 50:     241484          0          0          0     GICv2 158 Level     mmc1, mmc0
 57:      92617          0          0          0     GICv2 189 Level     eth0
 58:      12280          0          0          0     GICv2 190 Level     eth0
 64:          0          0          0          0     GICv2 106 Level     v3d
 65:          0          0          0          0     GICv2 175 Level     PCIe PME
 74:         12          0          0          0  BRCM STB PCIe MSI 3145728 Edge      nvme0q0
 75:         18          0          0          0  BRCM STB PCIe MSI 3670016 Edge      nvme1q0
 76:         12          0          0          0  BRCM STB PCIe MSI 4194304 Edge      nvme2q0
 77:         18          0          0          0  BRCM STB PCIe MSI 4718592 Edge      nvme3q0
 78:         34          0          0          0  BRCM STB PCIe MSI 3145729 Edge      nvme0q1
 79:        785          0          0          0  BRCM STB PCIe MSI 3145730 Edge      nvme0q2
 80:        531          0          0          0  BRCM STB PCIe MSI 3145731 Edge      nvme0q3
 81:        148          0          0          0  BRCM STB PCIe MSI 3145732 Edge      nvme0q4
 82:       2532          0          0          0  BRCM STB PCIe MSI 3670017 Edge      nvme1q1
 83:       2432          0          0          0  BRCM STB PCIe MSI 3670018 Edge      nvme1q2
 84:       2879          0          0          0  BRCM STB PCIe MSI 3670019 Edge      nvme1q3
 85:       2882          0          0          0  BRCM STB PCIe MSI 3670020 Edge      nvme1q4
 86:          9          0          0          0  BRCM STB PCIe MSI 4194305 Edge      nvme2q1
 87:        911          0          0          0  BRCM STB PCIe MSI 4194306 Edge      nvme2q2
 88:        453          0          0          0  BRCM STB PCIe MSI 4194307 Edge      nvme2q3
 89:         99          0          0          0  BRCM STB PCIe MSI 4194308 Edge      nvme2q4
 90:         29          0          0          0  BRCM STB PCIe MSI 4718593 Edge      nvme3q1
 91:        202          0          0          0  BRCM STB PCIe MSI 4718594 Edge      nvme3q2
 92:       1142          0          0          0  BRCM STB PCIe MSI 4718595 Edge      nvme3q3
 93:        186          0          0          0  BRCM STB PCIe MSI 4718596 Edge      nvme3q4
IPI0:          0          0          0          0  CPU wakeup interrupts
IPI1:          0          0          0          0  Timer broadcast interrupts
IPI2:       1740       2267       2211       2171  Rescheduling interrupts
IPI3:      25934      85159      74700      66953  Function call interrupts
IPI4:          0          0          0          0  CPU stop interrupts
IPI5:       9895      19424      19362       7618  IRQ work interrupts
IPI6:          0          0          0          0  completion interrupts
Err:          0
there are alot, 5 for each drive.
PhilE
Tue Sep 21, 2021 9:52 am
The Root Complex in 2711 supports 32 MSIs, so even with 5 drives there should be some spare, but there is clearly a hard limit of some kind there.
If you are serious about trying to debug this then I would recommend acquiring a serial port adaptor to capture the early kernel output - FTDI TTL 232 RGs are standard at Pi Towers, but you can also use a Pico with the right image.
jdb
Tue Sep 21, 2021 12:35 pm
The PCIe RC driver allocates MSIs from a bitmap, which selects 2^N aligned chunks of length 2^N. Requesting 5 interrupts will allocate 8 internally, which explains why it goes splat with 5 drives not 4. However - running out of PCIe resources should not be fatal (and implies a bug somewhere).
Edit - this is nonsense - the bitmap alloc is of order 0 (so no alignment restriction and as PhilE says, the actual MSI tokens allocated are sequential)
Also - there's not really much point in each NVMe device allocating 4+1 queues with 4+1 interrupts - they are all routed to a single CPU (and this CPU is common to all MSIs).
Rockets are loud.
https://astro-pi.org
Return to “Compute Module”
