darnelld
CM4 BGA IC identification
Fri Oct 29, 2021 8:12 pm
Hello All,
I am trying to identify the IC on the bottom side of the CM4 shown in the image attached that is connected to the two ferrites.
Any help is much appreciated!
Cheers
MikeDB
Re: CM4 BGA IC identification
Sat Oct 30, 2021 1:06 am
Possibly the power switching and regulator chip, equivalent of U2 on the Pi4 but with less voltages needed.
Always interested in innovative audio startups needing help and investment. Look for InPoSe Ltd or Future Horizons on LinkedIn to find me (same avatar photograph)
trejan
Sat Oct 30, 2021 1:20 am
Dialog Semiconductor DA9090.
The main MxL7704 PMIC is on the top.
f0rd0prefect
Wed Mar 02, 2022 4:29 pm
According to the PCN (Product Change Note) of the RPi4 Rev1.5 (Raspberry Pi 4 Revision 9 PCB) there is also a DA9090 on the RPi4-Board since Oct21. It has replaced the MxL7704-R4 PMIC
g**gle did not find any information about this PMIC. Seems pin-compatible to the MxL7704-R4?
Wed Mar 02, 2022 4:39 pm
What do you need to know about it?
timg236
Wed Mar 02, 2022 4:56 pm
It's not compatible and requires different firmware. The firmware is in Buster (legacy) and Bullseye supports this. IIRC firmware support was added over six months ago.
Ventran
Fri Mar 04, 2022 11:26 am
The MxL7704-R4 PMIC is not compatiblem with MxL7704-P4 on RPi CM4. This is a special version of PMCI designed for Raspberry Pi Fundation. This IC require pre-programing internal registers via I2C. Cloning P4 (i2c dump) and write to R4, give you absolutely nothing. CM4 requires an appropriate sequence of voltage enabling (core power supply, memory, etc.). This is ensured by a custom PMIC.
Contact: www.moisen.eu
Fri Mar 04, 2022 11:45 am
sed /fundation/Ltd/
Return to “Compute Module”
