rasput1n
Re: Moving Linux Kernel to 5.15
Mon Mar 14, 2022 10:35 pm
Come to think of it, the root partition wasn't read only. It must be a different issue.
PhilE
Tue Mar 15, 2022 10:10 am
You might not have intentionally made it read-only, but the kernel can do that under certain circumstances.
down1
Thu Mar 17, 2022 10:46 am
Any idea when it will become mainlined into stable?
Thu Mar 17, 2022 2:36 pm
The next bullseye sdcard update (and corresponding apt update) will be 5.15.
It depends on results of testing when that will happen.
Possibly a few weeks, but could be longer if new issues are discovered.
putter
Wed Mar 30, 2022 5:05 pm
Today I casually did apt upgrade, and got 5.15...
I see that the zfs-dkms package hasn't been updated for this kernel yet:
Building initial module for 5.15.30-v8+
configure: error:
	*** None of the expected "capability" interfaces were detected.
	*** This may be because your kernel version is newer than what is
	*** supported, or you are using a patched custom kernel with
	*** incompatible modifications.
	*** ZFS Version: zfs-2.0.3-9
	*** Compatible Kernels: 3.10 - 5.10
Error! Bad return status for module build on kernel: 5.15.30-v8+ (aarch64)
Any idea when the ZFS package will get updated?
thanks
chincheta0815
Thu Mar 31, 2022 8:13 am
thanks
As a possible workaround/update: zfs-dkms from bullseye-backports seems to work.
Probably it makes sense to update archive.raspberrypi.org to use that packages, so there won't be any hasseling with two repos...
santiagobiali
Thu Mar 31, 2022 1:14 pm
Upgraded to 5.15 using apt upgrade, but as zfs is not currently supported, did a rollback using:
rpi-update c31423c78b731922064fb85b011d6a5508224ed1
uname -r shows: 5.10.103-v8+
But when I try to install zfs-dkms using
apt install zfs-dkms
I get:
Loading new zfs-2.0.3 DKMS files...
It is likely that 5.10.103-v8+ belongs to a chroot's host
Building for 5.10.0-13-arm64, 5.10.103+, 5.10.103-v7+, 5.10.103-v7l+, 5.10.103-v8+, 5.10.95+, 5.10.95-v7+, 5.10.95-v7l+, 5.10.95-v8+, 5.15.30-v8+, 5.15.32+, 5.15.32-v7+, 5.15.32-v7l+ and 5.15.32-v8+
Module build for kernel 5.10.0-13-arm64 was skipped since the
kernel headers for this kernel does not seem to be installed.
Module build for kernel 5.10.103+ was skipped since the
Module build for kernel 5.10.103-v7+ was skipped since the
Module build for kernel 5.10.103-v7l+ was skipped since the
Module build for kernel 5.10.103-v8+ was skipped since the
Module build for kernel 5.10.95+ was skipped since the
Module build for kernel 5.10.95-v7+ was skipped since the
Module build for kernel 5.10.95-v7l+ was skipped since the
Module build for kernel 5.10.95-v8+ was skipped since the
configure: error:
Tried to
apt reinstall raspberrypi-kernel-headers -y
But got no luck. How do I reinstall kernel headers for 5.10.103-v8+? Can't see old versions in apt list:
apt list -a raspberrypi-kernel-headers
Listing... Done
raspberrypi-kernel-headers/stable,now 1:1.20220328-1 arm64 [installed]
raspberrypi-kernel-headers/stable 1:1.20220328-1 armhf
craigevil
Thu Mar 31, 2022 1:31 pm
Just wanted to say that the newest 5.15.30 kernel fixed my wifi and Bluetooth issues.
Linux raspberrypi 5.15.30-v8+ #1536 SMP PREEMPT Mon Mar 28 13:53:14 BST 2022 aarch64 GNU/Linux
Raspberry PI 400 Raspberry Pi OS Bookworm Kernel: 6.6.18-v8+ DE: XFCE
Debian - "If you can't apt install something, it isn't useful or doesn't exist"
PhilE
Thu Mar 31, 2022 1:33 pm
...and has caused a new one - the regulatory.db is being ignored or not found, limiting the channel usage (e.g. 1-11 in the 2.4G band).
bls
Thu Mar 31, 2022 1:38 pm
I see this message on both 5.10.103 and 5.15.30:
Mar 26 09:56:37 pvn kernel: cfg80211: Loading compiled-in X.509 certificates for regulatory database
Mar 26 09:56:37 pvn kernel: cfg80211: loaded regulatory.db is malformed or signature is missing/invalid
Pi tools:
Quickly and easily build customized exactly as-you-want SSDs/SD Cards: https://github.com/gitbls/sdm
Easily run and manage your network's DHCP/DNS servers on a Pi: https://github.com/gitbls/ndm
Easy and secure IPSEC/IKEV2 VPN installer/manager: https://github.com/gitbls/pistrong
Lightweight Virtual VNC Config: https://github.com/gitbls/RPiVNCHowTo
santiagobiali
Thu Mar 31, 2022 4:39 pm
I get:
configure: error:
Tried to
Listing... Done
Update. Fixed:
Downloaded and installed kernel-headers from https://archive.raspberrypi.org/debian/ ... -firmware/
Builded zfs module:
dkms build -m zfs -v 2.0.3
apt reinstall zfs-dkms zfsutils-linux -y
modprobe -v zfs
PhilE
Thu Mar 31, 2022 5:23 pm
The WLAN regression is now understood - see https://github.com/raspberrypi/Raspberr ... issues/217. A fix will roll out shortly.
putter
Fri Apr 01, 2022 6:00 am
thanks
Thank you.
kevsestrella
Sun Apr 03, 2022 8:14 am
I did an apt upgrade and got the 5.15 kernel. I'm using a gspca/ov534 camera and found that it's not working on 5.15, v4l2 doesnt find the device.
6by9
Sun Apr 03, 2022 12:55 pm
I did an apt upgrade and got the 5.15 kernel. I'm using a gspca/ov534 camera and found that it's not working on 5.15, v4l2 and alsa doesnt find the device.
It looks like USB_GSPCA_OV534 and load of other configs have disappeared between https://github.com/raspberrypi/linux/bl ... #L803-L850 and the 5.15 branch.
That's normally due to a change in the dependencies, and in this case it looks like it is https://github.com/torvalds/linux/commi ... 011d274617 changing the default of the parent USB_GSPCA option from module to disabled.
I've created https://github.com/raspberrypi/linux/issues/4977 to ask my colleague PhilE to deal with it.
kevsestrella
Sun Apr 03, 2022 2:01 pm
Thank you :D
shcshc
Wed Apr 06, 2022 12:49 pm
I get:
configure: error:
Tried to
Listing... Done
Update. Fixed:
Builded zfs module:
modprobe -v zfs
i have same problem. what can i exactly do? which heders schuld i download?
fduncanh
Re: Moving Linux Kernel to 5.15 (trying to find source of a regression)
Thu Apr 07, 2022 2:09 am
current 5.15.32-v8+ and -v7l+ introduces a regression from 5.10.x : a *huge* latency in rendering h264 video with hardware decoding and rendering it with OpenGL (Gstreamer videosink glimagsink) on the "Desktop" Raspberry Pi OS image, but not on the "Lite" using kmssink
for video rendering. (also kernel v7l+). This suggests that the issue involves openGL not the actual h264 decoding with video4linux2.
* i verified this by comparing an app I maintain using clean installations of the January 2022 image Raspberry Pi OS (for desktop,. not Lite)
(a) with 5.10 kernel held back from updating (apt-mark hold raspberrypi-kernel) (works great) and (b) fully-upgraded (HUGE latency).
I believe there must somewhere be a repository where all the sequence of "testing" 5.15 kernel releases leading up to the stable release are kept.
I would like to sequentially upgrade through this sequence to see If I can find a point where this regression appeared (or maybe it was always there?)
**Can anyone tell me where to find these older 5.15.x RPi OS testing kernels to install?**
chrender
Fri Apr 08, 2022 8:47 am
Thanks to @santiagobiali, the following fixed the ZFS issue for me:
Going back to 5.10.92, according to https://github.com/raspberrypi/rpi-firm ... its/master the latest commit before bump to 5.10.94 is b976c54917e240630c05a9b383010f1492bc61b4, so I ran
rpi-update b976c54917e240630c05a9b383010f1492bc61b4
Installing headers the following way:
wget https://archive.raspberrypi.org/debian/pool/main/r/raspberrypi-firmware/raspberrypi-kernel-headers_1.20220120-1_arm64.deb
dpkg -i raspberrypi-kernel-headers_1.20220120-1_arm64.deb
After that, executing
apt install zfs-dkms zfsutils-linux
produced the ZFS modules for 5.10.92.
santiagobiali
Wed May 04, 2022 7:50 pm
As @chincheta0815 said, using ZFS from bullseye-backport also works on 5.15. Just updated one of my rasps and tested.
Here's how:
Insert into "/etc/apt/sources.list":
	deb http://deb.debian.org/debian bullseye-backports main contrib non-free
	deb-src http://deb.debian.org/debian bullseye-backports main contrib non-free
Then
	apt update
	apt list -a zfs-dkms
Should show some versions:
	zfs-dkms/bullseye-backports,bullseye-backports,now 2.1.4-1~bpo11+1 all <- This one is v2.1.4, works with kernel 5.15.
	zfs-dkms/bullseye-backports,bullseye-backports 2.0.6-1~bpo11+1 all
Install the packages from the specific version that supports the 5.15 kernel:
  	#apt install {ZFS-PACKAGE}={VERSION}
	apt install zfs-dkms=2.1.4-1~bpo11+1
	apt install libnvpair3linux=2.1.4-1~bpo11+1 libuutil3linux=2.1.4-1~bpo11+1 libzfs4linux=2.1.4-1~bpo11+1
	apt install zfsutils-linux=2.1.4-1~bpo11+1
	apt install zfs-zed=2.1.4-1~bpo11+1
That's it.
down1
Sat Jul 30, 2022 1:24 pm
On the standard bullseye release. A new kernel hasn't been offered since 5.15.32-v7l+ #Thu Mar 31.
Is this suppose to be the case or have I broken apt?
Sat Jul 30, 2022 1:28 pm
5.15.32 is still the current Pi kernel at the moment.
Unreadable squiggle
down1
Sat Jul 30, 2022 1:34 pm
Thanks. I thought it was changed monthly, but if this is suppose to be the case great.
Sat Jul 30, 2022 1:37 pm
Apt updates are relatively infrequent, typically driven by major security updates, bug fixes, or new features (usually tied to application updates that rely on them).
There is a new RPiOS sdcard image planned in the next few weeks that will include a kernel update (but exact date is subject to testing results).
More frequent kernel updates are available through rpi-update, but obviously there is higher risk of regression with less widely tested software.
carldani
Mon Aug 29, 2022 6:56 pm
Oh. Thanks for the heads-up. I'm currently in the process of switching my video streaming appliance (Pi 4B) from Raspberry Pi OS Buster with kernel 5.10.52-v8+ to Raspberry Pi OS Bullseye with some kernel 5.15.x and I noticed stuttering video and worse latency, but I didn't measure anything yet. With Buster, GStreamer kmssink was unbearably slow and I had to switch to GStreamer glimagesink for decent performance. I hope I can keep using glimagesink when switching to Bullseye.
Did you manage to bisect the regression?
