STICKY: Bullseye - Comments and bug reports thread.
Hi all,
As you may have seen Bullseye has now been released, and it's a big one. It's not just an upgrade to Bullseye, but upgrades in lots of other places as well. Please see the blog post for more gory details.https://www.raspberrypi.com/news/raspbe ... -bullseye/
Please report any issues you may find here.
- DougieLawson
Re: Bullseye - Comments and bug reports thread.
Thank you. That will keep me a little bit amused until the end of the year.
Torrents downloading now.
When can we expect the RaspiOS lipstick on a Debian X86 pig version?
Hi, I think the V4l2 /dev/video driver has dropped support for h264
buster$ v4l2-ctl --list-formats-ext
ioctl: VIDIOC_ENUM_FMT
Type: Video Capture
[0]: 'YU12' (Planar YUV 4:2:0)
Size: Stepwise 32x32 - 3280x2464 with step 2/2
[1]: 'YUYV' (YUYV 4:2:2)
[2]: 'RGB3' (24-bit RGB 8-8-8)
[3]: 'JPEG' (JFIF JPEG, compressed)
[4]: 'H264' (H.264, compressed)
[5]: 'MJPG' (Motion-JPEG, compressed)
[6]: 'YVYU' (YVYU 4:2:2)
[7]: 'VYUY' (VYUY 4:2:2)
[8]: 'UYVY' (UYVY 4:2:2)
[9]: 'NV12' (Y/CbCr 4:2:0)
[10]: 'BGR3' (24-bit BGR 8-8-8)
[11]: 'YV12' (Planar YVU 4:2:0)
[12]: 'NV21' (Y/CrCb 4:2:0)
[13]: 'RX24' (32-bit XBGR 8-8-8-8)
I now get :
bullseye$ v4l2-ctl --list-formats-ext
Type: Video Capture
[0]: 'YUYV' (YUYV 4:2:2)
Size: Stepwise 16x16 - 16376x16376 with step 1/1
[1]: 'UYVY' (UYVY 4:2:2)
[2]: 'YVYU' (YVYU 4:2:2)
[3]: 'VYUY' (VYUY 4:2:2)
[4]: 'RGBP' (16-bit RGB 5-6-5)
[5]: 'RGBR' (16-bit RGB 5-6-5 BE)
[6]: 'RGBO' (16-bit A/XRGB 1-5-5-5)
[7]: 'RGBQ' (16-bit A/XRGB 1-5-5-5 BE)
... and 40 more none of which are h264.
this is on a Raspberry Pi 3 Model B Rev 1.2 with a pi camera v2.1
Any ideas for getting h264 back ?
Type: Video Capture
I now get :
Type: Video Capture
Nice! I will start testing this later tonight. By the way, which Mesa version are you using for this release?
pi@rpi-b64:~ $ apt list --installed | grep mesa
WARNING: apt does not have a stable CLI interface. Use with caution in scripts.
libegl-mesa0/stable,now 20.3.5-1+rpt3+rpi1 arm64 [installed,automatic]
libgl1-mesa-dri/stable,now 20.3.5-1+rpt3+rpi1 arm64 [installed]
libglapi-mesa/stable,now 20.3.5-1+rpt3+rpi1 arm64 [installed,automatic]
libgles2-mesa/stable,now 20.3.5-1+rpt3+rpi1 arm64 [installed]
libglx-mesa0/stable,now 20.3.5-1+rpt3+rpi1 arm64 [installed,automatic]
mesa-va-drivers/stable,now 20.3.5-1+rpt3+rpi1 arm64 [installed,automatic]
mesa-vdpau-drivers/stable,now 20.3.5-1+rpt3+rpi1 arm64 [installed,automatic]
Thanks!busywait wrote: ↑Mon Nov 08, 2021 1:15 pmpi@rpi-b64:~ $ apt list --installed | grep mesa
How do I access that config tool thingy on the left in that screenshot? Also, does "edge tiling" do what Windows 10 does, where if you drag a window beyond the left or right of the screen it gives you an option to have it fit one half of the screen, then gives you a choice of which window to fill the other half with? The explanatory text for that option in the screenshot is not hugely helpful in its description.
Blank screen on first boot/reboot
An observation: 4K screen resolutions are quite fussy about the cable used and/or the core_freq overclock in /boot/config.txt
I have a 3440x1440 monitor, iiyama ProLite XUB3493WQSU. When I booted with the micro-HDMI-to-HDMI adaptor+cable that I usually use then the 64-bit OS image booted to a blank screen. I've found 2 ways to fix this.
1: I tried a white Raspberry Pi branded micro-HDMI to HDMI cable, the desktop appeared
2: Either of these lines in /boot/config.txt enables the desktop to appear with my micro-HDMI adaptor+cable
hdmi_enable_4kp60=1
# or
#core_freq=600
#core_freq=550 did not work!
I made this edit by pressing Ctrl-Alt-F1 while staring at a blank screen during the first boot and editing /boot/config.txt. (Ctrl-Alt-F1/F2/... did not have any effect on a second boot, only during the first boot).
Equally easy, the /boot/config.txt file can be edited from another PC.
Other things that I tried that did not work:
#This did not help, X still caused a blank screen with my usual adaptor+HDMI cable
hdmi_group=1
hdmi_mode=16
hdmi_safe_mode=1
panel color transparency not function or broken.
vcdbg is missing in the 64 bit image. I will use the old statically compiled version for now.
andrum99 wrote: ↑Mon Nov 08, 2021 1:41 pmHow do I access that config tool thingy on the left in that screenshot? Also, does "edge tiling" do what Windows 10 does, where if you drag a window beyond the left or right of the screen it gives you an option to have it fit one half of the screen, then gives you a choice of which window to fill the other half with? The explanatory text for that option in the screenshot is not hugely helpful in its description.
sudo apt install dconf-editor
yes, dragging to edge resizes to half screen.
Thanks - that seems to work well, and would certainly be a useful addition to the defaults. I'm not a fan of centring windows by default though.kerry_s wrote: ↑Mon Nov 08, 2021 2:07 pmorg> gnome> mutterCode: Select all
If it works with a high quality cable, and doesn't with a low quality cable, then it's not something we will be trying to fix.
High resolution / refresh rates require a high quality cable.
Note that the hdmi_* options are generally interpreted by the firmware and are not considered by the arm-side kms driver.busywait wrote: ↑Mon Nov 08, 2021 1:48 pmCode: Select all
hdmi_group=1 hdmi_mode=16 hdmi_safe_mode=1
You generally want to use the "video=" option in cmdline.txt, which is a standard linux/kms options. See here.
(hdmi_enable_4kp60=1 actually controls clocks, rather than hdmi output, and does apply to both kms and fkms).
CPUFreq frontend applet is not shown in taskbar
Raspberry Pi in use is a Zero 2 W.
Is there a way to suppress the device tree notices?
I get two notices on boot.
This is with the Argon Artik Hat will l test with the argon one case and report back if I see anything.
Failed to load HAT overlay
dterror: not a valid FDT - err - 9
The Argon one v1 and v2 do not produce these messages.DarkElvenAngel wrote: Is there a way to suppress the device tree notices?
This is with the Argon Artik Hat will l test with the argon one case and report back if I see anything.Code: Select all
However my Pi 4 2Gb was hanging on Shutdown I'm not sure the issue there and the 4 and 8 Gb units shut down just fine.
I'll agree that they are *different* cable arrangements
Thanks for the KMS video config links - helpful to know about. A simple "uncomment this" reconfiguration seems kinder and more helpful for first-boot users that don't yet have appropriate cables. The hdmi_safe_mode=1 line in config.txt jumps out as an obvious setting for this. Does the documentation need an update to say that it is ignored in the new OS?
Maybe a conservative default configuration could avoid the black screen on the first boot for people who don't yet have a matching cable? Perhaps default to 1080p as a maximum until the user chooses a higher resolution later with the standard "click here to accept" fallback behaviour?
If you add the 'CPUFreq frontend' panel applet to the taskbar, nothing appears on the taskbar!
Edit: I see aBUGSworstnightmare already reported.
Okay, so I do have one issue so far: the desktop won't fit my old ONN 10" TV...again.
Also, the sudo nano boot config thing didn't work out, so I might need to figure it out again. However, Bullseye boots up great otherwise, but now I'm back to using overscan again.
My TV/monitor resolution is again "1366x768" btw.
I still appreciate your hard work though. Thanks.
Amateur musician and Raspberry Pi enthusiast.
1366x768 is the PITA one. The HW cannot support it directly, so will revert to the next resolution down, 720p I guess. That may be causing the borders.CheezPi wrote: ↑Mon Nov 08, 2021 4:44 pmOkay, so I do have one issue so far: the desktop won't fit my old ONN 10" TV...again.
I'm afraid that's an upstream plugin that we have never supported - you can use the CPU Temperature and CPU Usage plugins, but it looks as if something in that plugin was incompatible with GTK+3 and didn't move across properly when we rebuilt everything. I'll have a look and see if it is anything obvious.aBUGSworstnightmare wrote: ↑Mon Nov 08, 2021 3:15 pmCPUFreq frontend applet is not shown in taskbar
Not just those, no, but you can turn off all notifications by disabling them in the Appearance page of Panel Settings.
So, which settings should I put on config.txt now, may I ask?jamesh wrote: ↑Mon Nov 08, 2021 4:50 pm1366x768 is the PITA one. The HW cannot support it directly, so will revert to the next resolution down, 720p I guess. That may be causing the borders.CheezPi wrote: ↑Mon Nov 08, 2021 4:44 pmOkay, so I do have one issue so far: the desktop won't fit my old ONN 10" TV...again.
I'll have to check. I think there might be some runes which allow the use of a specific set of numbers for timing to try and bodge it in KMS like we did with the legacy graphics stack, but I don't know what they are.CheezPi wrote: ↑Mon Nov 08, 2021 4:56 pmSo, which settings should I put on config.txt now, may I ask?jamesh wrote: ↑Mon Nov 08, 2021 4:50 pm1366x768 is the PITA one. The HW cannot support it directly, so will revert to the next resolution down, 720p I guess. That may be causing the borders.CheezPi wrote: ↑Mon Nov 08, 2021 4:44 pmOkay, so I do have one issue so far: the desktop won't fit my old ONN 10" TV...again.
try adding a new mode (1360x768 or 1364x768 pixels (works fine with KMS and Pi4 as well) by following this guide https://askubuntu.com/questions/377937/ ... resolution
