TomEilers
Bullseye vncserver is very slow without display
Mon Nov 08, 2021 3:24 pm
My Buster vncserver and or client was running very well.
My Buster and Bullseye config.txt display setting are:
framebuffer_width=1024
framebuffer_height=768
hdmi_group=2
hdmi_mode=16
In Buster I also had to run raspi-config to make vncserver working with:
Advanced Options-> Resolution->resolution->dmt mode 16 1024&768
Otherwise my vncclient cann't connect to desktop.
In Bullseye I don't have and cann't change display setting, but vncserver is very slow.
Also option display settings resolution is not available any more in Bullseye raspi-config.
What do i do wrong ?
Thank you very much.
klricks
Re: Bullseye vncserver is very slow without display
Tue Nov 09, 2021 12:54 am
Verified VNC is so slow it is unusable when booted without a HDMI monitor and with the now default KMS driver.
To fix you can revert back to old driver by 'commenting out' the KMS driver in /boot/config.txt like this:
#dtoverlay=vc4-kms-v3d
reboot
Now you can apply a fixed resolution with sudo raspi-config or GUI Config tool.
reboot
VNC will then work normally.
TomEilers
Tue Nov 09, 2021 8:01 am
Thank you very much, this solved my problem.
I nice thing to remark :
If a display is connected but powered off, vncserver also works at normal speed.
The vc4-kms-v3d driver hdmi output seems to be looking for some resitance or something like that.
klricks
Tue Nov 09, 2021 12:33 pm
As long as the AC Mains are connected to the monitor, it is really in a standby mode and not powered off..... So the RPi or whatever device can still communicate with the monitor and negotiate the best screen resolution etc.
user_13ad24
Tue Nov 09, 2021 5:22 pm
I have / had the same problem and posted at approximately the same time about it, but the post hasn't been approved until later as it seems.
Anyway the workaround/solution works for me too.
It is interesting though that even with the KMS driver, if you start a secondary virtual vnc desktop (with "vncserver") and the accessing it at IP:1 for example, it works at normal speed, but the window frames and controls are not drawn correctly, hence you can't operate with windows normally. Maybe this bypasses the KMS driver, but still....the VNC virtual desktop should still work; maybe it's a problem with GTK+3.
Tue Nov 09, 2021 7:08 pm
Rather than disabling the kms overlay, can you try disabling mutter?
In /usr/bin/startlxde-pi, edit '$TOTAL_MEM -ge 2048' to, say '$TOTAL_MEM -ge 20480' and reboot.
That should disable mutter and may help VNC performance.
VNC are looking into a more permanent solution.
RonR
Tue Nov 09, 2021 7:38 pm
That improves performance, but the resolution still cannot be set in raspi-config (missing option) or desktop settings (greyed out).
Tue Nov 09, 2021 7:47 pm
If you are running headless, then I'd suggest adding:
video=HDMI-A-1:1920x1080@60D
to cmdline.txt to force a display resolution with kms.
aBUGSworstnightmare
Tue Nov 09, 2021 8:01 pm
Confirmed working on a CM4 2GB
content of my cmdline.txt (for reference)
console=serial0,115200 console=tty1 root=PARTUUID=9c48fee6-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash video=HDMI-A-1:1920x1080@60D plymouth.ignore-serial-consoles
Last edited by aBUGSworstnightmare on Tue Nov 09, 2021 8:19 pm, edited 1 time in total.
aBUGSworstnightmare
Tue Nov 09, 2021 8:04 pm
have you installed latest arandr package? Should be reported as available download viewtopic.php?p=1935699#p1935661
Screen Configuration editor before the update
Screen configuration editor after arandr package update - rotation no longer disabled
Last edited by aBUGSworstnightmare on Tue Nov 09, 2021 8:23 pm, edited 2 times in total.
Tue Nov 09, 2021 8:10 pm
have you tested this? Did not work for me as HDMI was still reported as unconnected (by xrandr) when I've tested this in the afternoon.
Will retest tomorrow for sure.
Not with VNC, but I have used that line with HDMI disconnected before. Did you test with the "D" at the end?
aBUGSworstnightmare
Tue Nov 09, 2021 8:21 pm
did not had the trailing "D" when testing this afternoon. Works fine now, thanks for pointing out correct syntax.
BTW: what's that D good for?
RonR
Tue Nov 09, 2021 8:28 pm
That appears to be a work-around. I had tried that yesterday with no success, but maybe the new arandr package that arrived today made a difference.
I hope there's a more elegant solution forthcoming.
aBUGSworstnightmare
Tue Nov 09, 2021 8:32 pm
Yes, a better solution should be used. Seems to be a good one for the moment though.
Just to notice: trying to rotate that display to portrait fails; get's reverted to landscape immediately. Yes, another workaround would be adding a new mode which is 1080x1920 ... I know ...
Tue Nov 09, 2021 8:38 pm
D means assume the display is connected. Something like hdmi_force_hotplug=1 with firmware driver.
RonR
Tue Nov 09, 2021 8:41 pm
FWIW...
This change appears to be unnecessary with the addition of 'video=HDMI-A-1:1920x1080@60D' to cmdline.txt and the new arandr package.
aBUGSworstnightmare
Tue Nov 09, 2021 8:46 pm
what? That sounds like the answer to my question here viewtopic.php?t=323281&start=100#p1935437
Was looking for such as my kernel command line in the afternoon failed for unknown (by that time) reasons.
Thanks for sharing that info!
FTrevorGowen
Tue Nov 09, 2021 8:53 pm
I'm guessing that this approach may also fix the desktop icon placement issue, possibly also linked to the use of RealVNC's virtual mode as reported here: viewtopic.php?t=323281&start=100#p1935462
and clarified here viewtopic.php?t=323281&start=125
Trev.
aBUGSworstnightmare
Tue Nov 09, 2021 9:04 pm
Trev.
yes. Look at the screenshots here viewtopic.php?t=323294&p=1935762#p1935714
TomEilers
Wed Nov 10, 2021 3:35 pm
Thanks for your very fast updated raspi-config(s)
I enabled dtoverlay=vc4-kms-v3d again , and set the new headless resolution to my display type.
Wed Nov 10, 2021 3:52 pm
There should be some updates propagating (to raspberrypi-ui-mods, raspi-config, rc-gui) that improve VNC server behaviour:
If VNC is enabled, it should now switch back to openbox rather than mutter on the next reboot. This should make the lag a lot better.
If no monitor is connected, then the new Headless Resolution combo box on the Display tab of Raspberry Pi Configuration and the corresponding VNC Resolution item in the Display menu of raspi-config can be used to set the size of the virtual desktop.
If a monitor is connected, the virtual desktop will be the same size as the connected monitor; this overrides any setting made above.
So manual changes to startlxde-pi or video= line in cmdline.txt shouldn't be needed after this.
FTrevorGowen
Wed Nov 10, 2021 4:01 pm
W.r.t. "the new Headless Resolution combo box..." I'm guessing that method should now be used rather than via the vncserver's -geometry option. (Although it would be "nice", from the point of view of a vncserver launch via a PuTTY (SSH) or serial terminal session if it were possible for said geometry option to "invoke" the same function/method as the "HeadlessRes. Combo box" unless, of course it (now) does? )
Trev.
mjack
Wed Nov 10, 2021 8:11 pm
Fresh bullseye install, updste and full-upgrade on headless Zero 2.
Maybe I'm doing something wrong, but I can't get it to work as described.
1( 1280x720 set in Raspberry Pi Configuration -> Display -> Headless Resolution,
2) VNC Viewer on other machine reports 1280x720 for session.
3) Screen Configuration only has "Composite-!" screen, and 720x480 resolution.
4 neofetch via ssh reports 720x480 resolution.
I've rebooted several times during this.
RealVNC session information
neofetch via ssh session
sammy04
Wed Nov 10, 2021 8:48 pm
I received that update & rebooted, whatever resolution i select in headless resolution, it is still not working.
Wed Nov 10, 2021 9:54 pm
The Screen Configuration describes physical displays.
Composite can't be auto-detected so is assume if hdmi is not connected.
If VNC viewer reports 1280x720 then what is wrong?
Are you saying you are not getting a 1280x720 VNC desktop?
