mjack
Re: Bullseye vncserver is very slow without display
Wed Nov 10, 2021 10:03 pm
dom wrote:
Wed Nov 10, 2021 9:54 pm
mjack wrote:
Wed Nov 10, 2021 8:11 pm
Are you saying you are not getting a 1280x720 VNC desktop?
I'm getting a 720x480 (I presume) desktop in a 1280x720 (I presume) window in VNC Viewer.
Wed Nov 10, 2021 10:07 pm
Why do you think that? I'd assume a 1280x720 VNC viewer resolution would mean that is the resolution of the desktop the VNC server is providing.
Can you switch between lowest and highest resolutions in the display tab of Raspberry Pi Configuration and see if you get more "room" for window with the higher setting?
mjack
Wed Nov 10, 2021 10:23 pm
The VNC Viewer window size (and size in Sesion information) changes accordingly, after a reboot, but the actual desktop stays at 720x480.
Man in a van
Wed Nov 10, 2021 10:31 pm
Same for me :?:
ronnie
RonR
Wed Nov 10, 2021 10:48 pm
Same for me :?:
Make sure you're updated (sudo apt update && sudo apt full-upgrade).
Then, in raspi-config (Display Options -> VNC Resolution), change to a different resolution, save it, change it back to the desired resolution, save it, and reboot.
Wed Nov 10, 2021 11:09 pm
The headless resolution works on Pi4.
Maybe on pi0-3 the composite resolution is overriding it.
Does:
dtoverlay=vc4-kms-v3d,nocomposite
(Replacing the existing kms line)
Help?
RonR
Wed Nov 10, 2021 11:13 pm
I had the previously described problem two Pi4's (one Bullseye 32 and one Bullseye 64) after the latest updates. It was necessary to change to a different resolution and back followed by a reboot on both.
Man in a van
Wed Nov 10, 2021 11:16 pm
Same for me :?:
Fully updated before starting
I tried this
Raspberry Configuration in the gui, changed to the smallest resolution, rebooted.
Repeated the procedure, changed to the largest resolution, rebooted.
Screen shot shows the result.
Will try your suggestion
ronnie
@Dom
Should say, this is a piZero2W
RonR
Wed Nov 10, 2021 11:23 pm
I believe the GUI configuration is now only for a connected monitor (not VNC). Without a connected monitor, the HDMI entries in the GUI configuration are greyed out. raspi-config must be used for VNC configuration.
Man in a van
Wed Nov 10, 2021 11:27 pm
did not work
ronnie :(
Man in a van
Wed Nov 10, 2021 11:30 pm
Does:
Help?
Winner! Winner! Chicken Dinner !! :o ;) :roll:
It took a few seconds for the screen to fill out, but it's there 8-)
Thanks to both; I'm off to bed for my ugly sleep :) :)
ronnie
Man in a van
Wed Nov 10, 2021 11:34 pm
Just to quickly add, that I choose the smallest resolution and the size of the screen did change.
ronnie
RonR
Thu Nov 11, 2021 12:00 am
Does:
Help?
@dom,
The addition of ',nocomposite' is required on a Raspberry Pi 3B+.
raymate
Thu Nov 11, 2021 12:32 am
Im getting the same problem, everything is set to 720P for VNC as described by Dom (raspi-config etc)
But the virtual window it seems to be 720 x 480 inside a 720P VNC window, the desktop will not fill as asked in the preferences. See below.
Screen Shot 2021-11-10 at 19.25.59.png (191.88 KiB) Viewed 5292 times
2) VNC Viewer on other machine reports 1280x720 for session.
3) Screen Configuration only has "Composite-!" screen, and 720x480 resolution.
The Screen Configuration describes physical displays.
Composite can't be auto-detected so is assume if hdmi is not connected.
If VNC viewer reports 1280x720 then what is wrong?
___________________________________________________________________
Pi model B / Pi 2 / Pi 3 / Pi 4 / Pi 400 / Pi Zero W / Pi Zero 2 W / Pico
mjack
Thu Nov 11, 2021 5:58 am
Does:
Help?
This works on a Zero 2. I can change resolution for the desktop via raspi-config and Raspberry Pi Configuration. VNV Viewer reports the resolution I select.
There's a small glitch when I log in: the Viewer window is only the size of the login dialog, and the desktop is briefly 'tiled' to fill the Viewer window. Once the desktop is settled (top bar etc), everything is fine.
Man in a van
Thu Nov 11, 2021 10:53 am
Just a note to confirm this is so ;)
ronnie
mmozzano
Thu Nov 11, 2021 11:00 am
I updated from buster to bullseye on two seperate Pi4 machines last night and also having issues with vnc (getting 'Cannot currently show the desktop). When I run raspi-config however I dont see anything relating to vnc resolutions under Display Options.
I'm fully up to date when I run apt update and apt full-upgrade but when I check the version of raspi-config it comes back as...
raspi-config is already the newest version (20210212).
Am I doing something wrong?!
Update: a fresh install rather than attempting to upgrade from buster has resolved this issue.
FTrevorGowen
Thu Nov 11, 2021 3:18 pm
FTrevorGowen wrote:
Wed Nov 10, 2021 4:01 pm
dom wrote:
Wed Nov 10, 2021 3:52 pm
There should be some updates propagating (to raspberrypi-ui-mods, raspi-config, rc-gui) that improve VNC server behaviour:
If VNC is enabled, it should now switch back to openbox rather than mutter on the next reboot. This should make the lag a lot better.
If no monitor is connected, then the new Headless Resolution combo box on the Display tab of Raspberry Pi Configuration and the corresponding VNC Resolution item in the Display menu of raspi-config can be used to set the size of the virtual desktop.
If a monitor is connected, the virtual desktop will be the same size as the connected monitor; this overrides any setting made above.
So manual changes to startlxde-pi or video= line in cmdline.txt shouldn't be needed after this.
W.r.t. "the new Headless Resolution combo box..." I'm guessing that method should now be used rather than via the vncserver's -geometry option. (Although it would be "nice", from the point of view of a vncserver launch via a PuTTY (SSH) or serial terminal session if it were possible for said geometry option to "invoke" the same function/method as the "HeadlessRes. Combo box" unless, of course it (now) does? )
Trev.
[Update]
I've now been able to update/upgrade Bullseye on a P4B and re-test VNC with and without a monitor connected. However, to perform a direct display vs. virtual with the same resolution/size I had to re-configure the monitor's setting to match one available within the "HeadlessRes. Combo box" as shown in the (VNC window) screenshots below:
With monitor (Hanns-G HL198)
Re-booted w/o monitor attached (ie. no uHDMI-to-HDMI cable plugged in)
Trev
Butchijo
Thu Nov 11, 2021 6:14 pm
Just my findings.
Installed Bullseye on a PiZ2 and had problems with the VNC resolution. I tried the Suggestions above: full update and select low resolution ollowed with high resolution. The VNC size changed but the RPi window remained the same (low resolution). So the problem is not fixed on a RPiZ2.
BTW If i put the SD card out of a RPiZ2 and put it in a RPi4B then it works ok.
raymate
Thu Nov 11, 2021 6:20 pm
I can confirm for me on a 3B adding the "nocomposite" to the line below works I get a proper sized 720P
Does:
Help?
RobLatour
Thu Nov 11, 2021 6:39 pm
dom wrote: ↑
Wed Nov 10, 2021 6:09 pm
Does:
Help?
( change made in /boot/config.txt )
worked for me - thanks!
peter_shaw
Mon Nov 15, 2021 8:18 pm
this worked for me on a fresh install. headless pi 4 using VNC
sudo nano /boot/config.txt
hdmi_force_hotplug=1
hdmi_group=2
hdmi_mode=35 #(for 1280x1024)
#dtoverlay=vc4-kms-v3d
Man in a van
Mon Nov 15, 2021 10:02 pm
please ignore original text, posted in error :oops:
ronnie
riscman
Sat Nov 20, 2021 5:31 pm
Does:
Help?
This works for me on a Pi3B+, but a word of warning to folks like me who don't read the instructions carefully.
Instead of replacing the existing kms line as instructed above I inserted the "dtoverlay=vc4-kms-v3d,nocomposite" after the original making the wrong assumption that the later instruction would supersede the original.
It does not work. After commenting out the original all was well. Thanks
Omniptizator
Mon Dec 06, 2021 10:48 am
Hi, I would like to return to initial topic of this thread - does this switch to openbox in headless imply improved overall performance for VNC? Because without the trick with "D" by @aBUGSworstnightmare in resolution in cmdline.txt I still get huge lags in Chromium (terminal window via VNC is working fine, for example).
