So months later, and I've tried again.
I've created a
deluged.service and
deluge-web.service, and both
appear to work.
Via my browser, I can connect to the web client, but when I try and download, that's when the problems start.
I tried accessing deluged via the console, and after just sitting there, when I quit, I get this:
Unhandled error in Deferred:
File "/usr/lib/python3/dist-packages/twisted/internet/defer.py", line 654, in _runCallbacks
current.result = callback(current.result, *args, **kw)
File "/usr/lib/python3/dist-packages/deluge/ui/client.py", line 436, in __on_login_fail
login_deferred.errback(result)
File "/usr/lib/python3/dist-packages/twisted/internet/defer.py", line 501, in errback
self._startRunCallbacks(fail)
File "/usr/lib/python3/dist-packages/twisted/internet/defer.py", line 568, in _startRunCallbacks
self._runCallbacks()
--- <exception caught here> ---
File "/usr/lib/python3/dist-packages/deluge/ui/client.py", line 408, in __on_connect_fail
self.daemon_info_deferred.errback(reason)
File "/usr/lib/python3/dist-packages/twisted/internet/defer.py", line 561, in _startRunCallbacks
raise AlreadyCalledError
twisted.internet.defer.AlreadyCalledError:
Temporarily disabling observer LegacyLogObserverWrapper(<bound method TwistedLoggingObserver.emit of <deluge.log.TwistedLoggingObserver object at 0x7fa7c8e340>>) due to exception: [Failure instance: Traceback: <class 'TypeError'>: findCaller() takes from 1 to 2 positional arguments but 3 were given
/usr/lib/python3/dist-packages/twisted/internet/defer.py:962:__del__
/usr/lib/python3/dist-packages/twisted/logger/_logger.py:190:failure
/usr/lib/python3/dist-packages/twisted/logger/_logger.py:144:emit
/usr/lib/python3/dist-packages/twisted/logger/_observer.py:131:__call__
/usr/lib/python3/dist-packages/twisted/logger/_legacy.py:93:__call__
/usr/lib/python3/dist-packages/deluge/log.py:204:emit
/usr/lib/python3.9/logging/__init__.py:1489:critical
/usr/lib/python3.9/logging/__init__.py:1573:_log
File "/usr/lib/python3/dist-packages/twisted/internet/defer.py", line 962, in __del__
log.failure(format,
File "/usr/lib/python3/dist-packages/twisted/logger/_logger.py", line 190, in failure
self.emit(level, format, log_failure=failure, **kwargs)
File "/usr/lib/python3/dist-packages/twisted/logger/_logger.py", line 144, in emit
self.observer(event)
File "/usr/lib/python3/dist-packages/twisted/logger/_observer.py", line 131, in __call__
observer(event)
File "/usr/lib/python3/dist-packages/twisted/logger/_legacy.py", line 93, in __call__
self.legacyObserver(event)
File "/usr/lib/python3/dist-packages/deluge/log.py", line 204, in emit
getattr(LoggingLoggerClass, event_dict['log_level'].name)(
File "/usr/lib/python3.9/logging/__init__.py", line 1489, in critical
self._log(CRITICAL, msg, args, **kwargs)
File "/usr/lib/python3.9/logging/__init__.py", line 1573, in _log
fn, lno, func, sinfo = self.findCaller(stack_info, stacklevel)
builtins.TypeError: findCaller() takes from 1 to 2 positional arguments but 3 were given
I'm running:
Pi OS Bullseye
Deluge 2.0.3
