Adam777
Chromium crashes trying to open YouTube
Fri Nov 12, 2021 8:01 am
After the last update, chromium immediately closes itself when opening YouTube links.
RP3+, Buster
kerry_s
Re: Chromium crashes trying to open YouTube
Fri Nov 12, 2021 10:44 am
clear your cookies
Adam777
Fri Nov 12, 2021 10:59 am
clear your cookies
Yep, that seemed to do the trick, thank you ;)
kerry_s
Fri Nov 12, 2021 11:05 am
clear your cookies
looks like you'll need it to add to the clear list.
if you have the sync fix it'll be fine.
sudo mousepad /etc/chromium.d/00-rpi-vars
--oauth2-client-id=77185425430.apps.googleusercontent.com --oauth2-client-secret=OTJgUOQcT7lO7GsGZq2G4IlT --enable-features=VaapiVideoDecoder
kerry_s
Fri Nov 12, 2021 2:54 pm
never mind it just started crashing again. :lol:
eat-sleep-code
Fri Nov 12, 2021 3:49 pm
Same issue here. Manually clearing cookies fixed it momentarily, but this is not a valid solution for it to happen every time.
kerry_s
Fri Nov 12, 2021 3:59 pm
suggest using an alternative browser for youtube for the time being.
it's youtube's local storage cookie(the 1 with the youtube icon in cookies view) causing the issue, i also noticed they enabled poly, which slows down browsers other than theirs.
snowballEarth
Fri Nov 12, 2021 4:06 pm
Yeah wtf? I'm getting this too, started today - probably with an update.
Clearing browsing data didn't fix the problem.
rpi4, bullseye
CheezPi
Fri Nov 12, 2021 4:44 pm
Wow. Looks like I'm not alone now, eh? I hope for a fix on this soon.
EDIT:
Here's what I have: Pi 400, Bullseye.
Amateur musician and Raspberry Pi enthusiast.
Fri Nov 12, 2021 4:46 pm
So, testing this, and not finding any problems - Youtube, latest BE, fully updated.
Can someone pass on a link to a crashing video in case its related to the video type?
kerry_s
Fri Nov 12, 2021 4:49 pm
it's the whole site, after you leave, then try and go back.
CheezPi
Fri Nov 12, 2021 4:54 pm
The whole site, including the Chromium app is being weird, crashing the entire browser for some reason.
frankdrn
Fri Nov 12, 2021 5:00 pm
I got this log of the youtube crash.
[6063:1:1112/153157.301528:VERBOSE1:sandbox_linux.cc(69)] Activated seccomp-bpf sandbox for process type: renderer.
[5781:5818:1112/153157.330500:VERBOSE1:media_stream_manager.cc(705)] RFAOSF::Core() [process_id=8, frame_id=4]
[5834:5849:1112/153157.437780:VERBOSE1:network_delegate.cc(32)] NetworkDelegate::NotifyBeforeURLRequest: https://www.youtube.com/
[5834:5849:1112/153157.608954:VERBOSE1:tls_handshaker.cc(106)] TlsClient: Continuing handshake
[1112/153157.674736:ERROR:elf_dynamic_array_reader.h(61)] tag not found
Segmentation fault
Thats the point where I typed youtube.com into the browser and pressed return. Not sure if any of that is useful.
If you delete the youtube service workers from within Chromium the site will work again but you have to accept the t&c's again.
CheezPi
Fri Nov 12, 2021 5:04 pm
frankdrn wrote: I got this log of the youtube crash.
Segmentation fault
Ehh...I don't know...I think there should be a better fix than clearing YouTube cookies or whatever.
yan
Fri Nov 12, 2021 5:14 pm
It crash here too 5 times. I just click on the youtube bookmark and it crash. I remove all addons but doesn't fix the problem, only if i delete the cookies the page start to work again.
If i type on the URL bar m.youtube.com youtube will open. With www youtube is crashing.
This the error that appear in the terminal when the Chromium crash :
 [1112/192314.769824:ERROR:elf_dynamic_array_reader.h(61)] tag not found
Segmentation fault
DarkElvenAngel
Fri Nov 12, 2021 5:23 pm
I'm having a crashing issue as well however it happens after a few videos play I don't have to do anything with cookies.
I've done some setting tweaking that may be useful to know about from my post here viewtopic.php?p=1934933#p1933143
I was also using the incognito mode for youtube so cookies aren't saved. Pi4 4GB fully updated 32bit bullseye
CheezPi
Fri Nov 12, 2021 5:24 pm
Okay...clearing the YouTube service worker cookies did work, but I think that's only a temporary solution. It's probably a bug within Chromium or something.
EDIT: Using the mobile YouTube URL seems to do well too, but it shouldn't really be like that. At least, I don't think so.
frankdrn
Fri Nov 12, 2021 5:50 pm
Yeah, it's not a solution and it only works for the current session. Maybe it could narrow the problem down a bit.
I tried DarkElvenAngel's suggestion of disabling the Skia API but that didn't fix the crash for me.
CheezPi
Fri Nov 12, 2021 5:55 pm
Me too, yeah. Something is wrong. I would point out that this is happening after the fact that they changed the function of the dislike button, but that's probably unrelated since that opens up another can of worms towards Google sites in general.
DarkElvenAngel
Fri Nov 12, 2021 5:56 pm
I still have crashes but using incognito mode helps with the cookie problem since they are automatically deleted. I can watch about 3 to 5 videos before crashing out. I mentioned Skia as I don't have default setup.
CheezPi
Fri Nov 12, 2021 6:01 pm
Hmm...I would also temporarily use a different browser too...but what if it is also an issue on other Chromium-based browsers?
Fri Nov 12, 2021 6:04 pm
OK, I can replicate this, will forward the issue to those who know.
kerry_s
Fri Nov 12, 2021 6:05 pm
just edit your bookmark to https://m.youtube.com
it still go's to the desktop site but doesn't crash.
CheezPi
Fri Nov 12, 2021 6:08 pm
Thanks. I hope things work out.
Annie UK
Fri Nov 12, 2021 8:14 pm
That URL crashes here :(
Annie - Raspberry Pi 4 Model B Rev 1.4 8GB - Ubuntu 22.10 aarch64
Full Pi spec (Daily Driver): https://annieuk.ddns.net/pc-spec.php?dark
Return to “Raspberry Pi OS”
