petracus
Use openbox instead of mutter in rpi4 2-4-8gb
Fri Nov 12, 2021 8:26 am
Is there any possibility to use opnebox instead of mutter on raspberry larger than 2gb?
Performance has dropped considerably on bullseye for office use.
Greetings.
kerry_s
Re: Use openbox instead of mutter in rpi4 2-4-8gb
Fri Nov 12, 2021 10:42 am
sudo mousepad /etc/xdg/lxsession/LXDE-pi/desktop.conf
line #2:
window_manager=mutter
to
window_manager=openbox
save & reboot
petracus
Fri Nov 12, 2021 5:46 pm
Now, I can change resolution & rotation and changes persists!
Double thanks!
Chimneyfactory
Sat Nov 13, 2021 2:19 pm
Just a +1 on this. mutter seems slow when you've alt tabbed to a different window, mouse and keypresses are very sluggish for 3 - 5 seconds. Makes rapid switching between windows very frustrating.
I changed back to openbox and it's much better.
Pi4 4GB
ejolson
Sat Nov 13, 2021 5:17 pm
line #2:
to
save & reboot
Thanks for the tip. While it's easy to edit that file, I know the Mate desktop on x86 has a clickable mouse option to enable or disable compositing.
Maybe a similar option could be added to the Raspberry Pi, some documentation about what to try if the desktop is slow or at least make this a sticky thread like the one on the USB3 speed problems.
kerry_s
Sat Nov 13, 2021 11:08 pm
mate desktop uses marco wm.
mutter comes from gnome developers who wanted to keep it as simple as possible.
i just checked, looks like switching to marco would be just as easy. it doesn't pull that much in.
Directory: /home/pi
$ ins marco
Reading package lists... Done
Building dependency tree... Done
The following additional packages will be installed:
  libgtop-2.0-11 libgtop2-common libmarco-private2 libxpresent1 marco-common
  mate-desktop-common
The following NEW packages will be installed:
  marco-common mate-desktop-common
0 upgraded, 7 newly installed, 0 to remove and 0 not upgraded.
Need to get 1,689 kB of archives.
After this operation, 11.0 MB of additional disk space will be used.
Do you want to continue? [Y/n] n
Abort.
Annie UK
Sun Nov 14, 2021 11:05 am
I have changed from mutter to openbox but now have a coupe of issues :(
I can no longer use Ctrl + Alt + T to open a terminal ans lxappearance gives the error "Segmentation fault" so I cannot change the theme easily
Annie - Raspberry Pi 4 Model B Rev 1.4 8GB - Debian GNU/Linux 12 (bookworm) aarch64
Full Pi spec (Daily Driver): https://annieuk.ddns.net/pc-spec.php?dark
Sun Nov 14, 2021 11:33 am
Gnome want to make things so simple they simply do not work properly. So many issues with Gnome's work, not just Mutter but GTK3 as well, caused us no end of problems, and they are STILL coming out of the woodwork.
petracus
Sun Nov 14, 2021 11:44 am
For theme change, you should activate openbox configuration menu in main menu editor (category preferences).
Annie UK
Sun Nov 14, 2021 11:49 am
openbox configuration menu is greyed out and nothing happens when I select the option :(
I've installed obconf and run that from terminal
kerry_s
Sun Nov 14, 2021 12:26 pm
using gnome stuff is always difficult, to many pieces tied together. gtk3 is so ridged in it's design, whats set is set.
personally, i think they should of went with the qt, as others have done trying to move away from gnome parts.
or
more commonly mixing both qt & gtk, with qt the priority & gtk were no qt equivalent, as is the case with some apps.
there's always the option to just tweak less & use it as it comes from the repo' a more standardized desktop.
pidd
Sun Nov 14, 2021 2:27 pm
With openbox mine was ignoring keyboard volume and mute controls
If you add the alsa volume control applet (in the add/remove panel items) you can use that to program those keys in. The applet won't run alsamixer because it tries to use xterm, I've not looked into that yet.
Volume was also reduced so ran alsamixer from terminal and turned the device volume up.
Chimneyfactory
Sun Nov 14, 2021 11:38 pm
+1 on this
Ctrl Alt T does nothing in Openbox (previously opened terminal window in Buster)
Works OK in mutter
drmullins
Sun Jan 16, 2022 9:15 am
Do not modify in lxsession as this stops ctrl alt t working amongst othe problems. Instead , to enable openbox to work properly, enable vnc in raspi-config or modify startlxde-pi. See other threads - search for Mutter. Also remove lxappearance-obconf to make lxappearance and obconf work properly.
kerry_s
Sun Jan 16, 2022 9:42 am
when changing back to openbox, you get a default openbox.
you can go into ~/.config/openbox and set your own keyboard shortcuts or copy the settings from /etc/xdg
you can use all the openbox tools without lxde-pi overwriting your settings since it uses rc.xml instead of lxde-pi-rc.xml
the only problem here is the lack of experience, openbox was around long before lxde decided to use it. it's a window manager that can be setup independent of all the other parts. just use some google fu and learn.
Sun Jan 16, 2022 9:59 am
You can use lxhotkey to add shortcuts instead of messing with the files yourself. Just remember to click the Save icon when done or you will lose your changes.
Unreadable squiggle
kerry_s
Sun Jan 16, 2022 10:22 am
good to know, thanks.
that would mean all the gui tools work when switching back to openbox.
drmullins
Sun Jan 16, 2022 12:55 pm
I've tried lxhotkey with openbox enabled instead of mutter but it stops with a message saying that openbox is not supported. (It also said mutter was not supported when I tried it with Mutter)
Sun Jan 16, 2022 3:56 pm
Do you have lxhotkey-plugin-openbox installed?
Unreadable squiggle
drmullins
Sun Jan 16, 2022 4:16 pm
Thanks - all working now. I wish there was a plugin for mutter or whatever ancilliary package Raspberry Pi OS is or should be using for keyboard shortcuts - but c'est la vie I suppose.
dmitrmax
Mon Feb 07, 2022 9:20 am
line #2:
to
save & reboot
Did it. RPi still boots into GUI with mutter running. Any clues?
pidd
Mon Feb 07, 2022 12:31 pm
The memory size trick is a better method as it pulls in all the settings (eg keyboard shortcuts etc) for openbox
drmullins wrote:
Thu Jan 20, 2022 9:47 am
Reply to ChimneyFactory. Ctrl alt t works correctly if openbox is enabled by either - enabling VNC in Raspberry Pi preferences - or by modifying /usr/bin/startlxde-pi to replace 2048 by e.g. 20480 as the memory threshold for enabling Mutter rather than openbox. Modifying desktop.conf to replace Mutter by openbox does not seem to work properly (completely) and causes ctrl alt t shortcut to stop working. There's no bug in openbox in this regard.
EDIT: Since 1st Mar 2022 /usr/bin/X11/startlxde-pi
kerry_s
Mon Feb 07, 2022 1:06 pm
i've been testing using using jwm instead of openbox or mutter. jwm is no frills, very basic, i have it acting as window manager only.
get the speed of openbox with the border tiling of mutter, no compositor, no flickering shadows.
sudo apt install jwm
window_manager=jwm
~/.jwmrc
<?xml version="1.0"?>
<JWM>
    <Group>
        <Option>aerosnap</Option>
        <Option>centered</Option>
    </Group>
    <WindowStyle>
        <Font>Piboto-12</Font>
        <Width>4</Width>
        <Height>22</Height>
        <Corner>3</Corner>
        <Foreground>#FFFFFF</Foreground>
        <Background>#555555</Background>
        <Outline>#000000</Outline>
        <Opacity>1.0</Opacity>
        <Active>
            <Background>#252525</Background>
        </Active>
    </WindowStyle>
    <IconPath>
        /usr/local/share/jwm
    </IconPath>
    <Desktops width="1" height="1"></Desktops>
    <DoubleClickSpeed>200</DoubleClickSpeed>
    <DoubleClickDelta>2</DoubleClickDelta>
    <FocusModel>click</FocusModel>
    <SnapMode distance="10">border</SnapMode>
    <MoveMode>opaque</MoveMode>
    <ResizeMode>opaque</ResizeMode>
    <Key key="Up">up</Key>
    <Key key="Down">down</Key>
    <Key key="Right">right</Key>
    <Key key="Left">left</Key>
    <Key key="h">left</Key>
    <Key key="j">down</Key>
    <Key key="k">up</Key>
    <Key key="l">right</Key>
    <Key key="Return">select</Key>
    <Key key="Escape">escape</Key>
    <Key mask="A" key="Tab">nextstacked</Key>
    <Key mask="A" key="F4">close</Key>
    <Key key="Super_L">exec:lxpanelctl menu</Key>
    <Key mask="A" key="F2">exec:lxpanelctl run</Key>
    <Key mask="Ctrl+A" key="Up">maximize</Key>
    <Key mask="Ctrl+A" key="t">exec:x-terminal-emulator</Key>
    <Key key="Print">exec:scrot</Key>
    <Key mask="Ctrl+A" key="End">exec:lxde-pi-shutdown-helper</Key>
    <Key mask="Ctrl+A" key="Delete">exec:lxde-pi-shutdown-helper</Key>
    <Key mask="Ctrl+A" key="Left">maxleft</Key>
    <Key mask="Ctrl+A" key="Right">maxright</Key>
    <Key mask="Ctrl+A" key="r">restart</Key>
</JWM>
drmullins
Mon Feb 07, 2022 1:07 pm
If you are only avoiding mutter because of lack of support for custom keyboard shortcuts, you can easily add them using xbindkeys - I've updated a thread on Keyboard Shortcuts in Troubleshooting to describe this.
Return to “Raspberry Pi OS”
