therealdavidp
Picamera2 preview release
Tue Feb 15, 2022 1:53 pm
Hi everyone, for folks that haven't spotted it yet, please check this out! There's quite a lot you can do already, and a number of examples, though no support for video recording just yet.
Feel free to post questions below, I'll do my best to answer.
GigiG
Re: Picamera2 preview release
Wed Feb 16, 2022 11:38 am
Hi, I'm trying to build Picamera2 on RPi0 (Buster) but after the command
git clone --branch picamera2 [email protected]:raspberrypi/libcamera.git
I got the following error:
[email protected]: Permission denied (publickey).
Regards
therealdavidp
Wed Feb 16, 2022 12:16 pm
Hi, it sounds like maybe you haven't set up an ssh key for accessing GutHub? I believe that repository should be publicly visible (someone please say if that doesn't seem to be the case), so maybe try visiting https://github.com/raspberrypi/picamera2 in your browser. The little "Code" drop-down box should give you an https link to clone the repository, maybe try that?
6by9
Wed Feb 16, 2022 12:22 pm
Regards
Use
git clone  --branch picamera2 https://github.com/raspberrypi/libcamera.git
Cloning using SSH requires you to have a Github account with an SSH public key registered.
Pull request opened to update the docs. https://github.com/raspberrypi/picamera2/pull/1
*edit* PR now merged to advise using HTTPS instead of SSH.
GigiG
Wed Feb 16, 2022 1:04 pm
Use
git clone  --branch picamera2 https://github.com/raspberrypi/picamera2.git
Thanks. I suppose to clone a libcamera.git not picamera2.git, right?
dgalland
Thu Feb 17, 2022 6:46 pm
So I immediately tried all this with the capture_jpeg example
picam2 = Picamera2()
#preview = NullPreview(picam2)
preview = QtGlPreview(picam2)
cam_config = picam2.still_configuration()
#cam_config = picam2.preview_configuration()
picam2.configure(cam_config)
- With NullPreview and preview_configuration I have a 640x480 jpeg :D :D :D
- With NullPreview and still_configuration :
Unable to request 1 buffers: Cannot allocate memory :x
- With QtGlPreview I have an OpenGL error :x
But then it starts to work!
Raspberry 3B+ 1G
therealdavidp
Thu Feb 17, 2022 6:56 pm
Yes, I haven't been trying this on a Pi 3 yet. Sounds like there may be some issues with the amount of CMA memory, so possibly worth having a look in /proc/meminfo. Not sure why you'd get an OpenGL error. Is Glamor re-enabled?
tvoverbeek
Thu Feb 17, 2022 8:12 pm
Build it on a Pi4 2G aarch64. No problems. Went exactly as described.
First tests worked fine: preview(drm, gl, qt and at with x-forwarding)
Also via VNC (except the drm one for obvious reasons).
Have not tried opencv yet on 64-bit
dgalland
Thu Feb 17, 2022 9:45 pm
cat /proc/meminfo
MemTotal:         944968 kB
MemFree:          380900 kB
MemAvailable:     648656 kB
Buffers:           25344 kB
Cached:           286856 kB
SwapCached:        32848 kB
Active:           233984 kB
Inactive:         232752 kB
Active(anon):       8100 kB
Inactive(anon):   153948 kB
Active(file):     225884 kB
Inactive(file):    78804 kB
Unevictable:          32 kB
Mlocked:              32 kB
SwapTotal:        102396 kB
SwapFree:          57084 kB
Dirty:               236 kB
Writeback:             0 kB
AnonPages:        125920 kB
Mapped:           113340 kB
Shmem:              7512 kB
KReclaimable:      16248 kB
Slab:              34804 kB
SReclaimable:      16248 kB
SUnreclaim:        18556 kB
KernelStack:        1960 kB
PageTables:         5052 kB
NFS_Unstable:          0 kB
Bounce:                0 kB
WritebackTmp:          0 kB
CommitLimit:      574880 kB
Committed_AS:    1140160 kB
VmallocTotal:    1114112 kB
VmallocUsed:        5732 kB
VmallocChunk:          0 kB
Percpu:              576 kB
CmaTotal:         262144 kB
CmaFree:          192512 kB
I don't know what Glamor is and how to re-enable it?
therealdavidp
Fri Feb 18, 2022 8:16 am
A bit surprised not to see CMA listed. i guess the usual questions probably apply - what version of the OS is this (a fresh Bullseye?), what do "uname -a" and "vcgencmd version" report. I'll have to try it on a Pi 3 for myself, but I'm not able to lay my hands on one just at the moment so it'll have to wait a short while.
dgalland
Fri Feb 18, 2022 9:30 am
Scrolling down:
CmaTotal: 262144 kB
CmaFree: 192512 kB
Yes it is a fresh bullseye just installed
Linux raspberrypi 5.10.92-v7+ #1514 SMP Mon Jan 17 17:36:39 GMT 2022 armv7l GNU/Linux
version bd88f66f8952d34e4e0613a85c7a6d3da49e13e2 (clean) (release) (start)
with only one buffer it works:
cam_config = picam2.still_configuration(buffer_count=1)
MRV
Fri Feb 18, 2022 1:53 pm
Any news on dual camera stereo 3d picamera support?
therealdavidp
Fri Feb 18, 2022 5:55 pm
Stereoscopic camera support in Picamera2 will require it to be present in libcamera first and as yet we don't have any kind of estimated timetable for that.
dgalland
Sat Feb 19, 2022 5:24 pm
So I did some experimenting with Picamera2.
My current Picamera application captures as fast as possible jpeg encoded frames either in full 4056x3040 resolution or in binned 2028x1520 mode.
First of all it's not clear why three configurations are provided and what are really the differences between them.
Is it really useful since generally we will specify at least size and format:
cam_config = picam2.still_configuration(buffer_count=1, main={"size": (2028, 1520), "format": "RGB888"})
If I change still to preview or video what is really the difference for the obtained frames ?
I noticed that with "still" I actually get 2016x1520 frames while with "video" or "preview" we stay in 2028x1520 but in this case the make_array fails to numpy reshape (padding?)
Then I compared from the performance point of view.
With my PI3B+ 1G we can allocate only one buffer then in binned mode 2028x1520 the simple loop on the requests without any copy nor treatment reaches without dropped frames 30fps (the default it seems).
But if I add the copy in a numpy array we fall to 10fps without jpeg encoding and to 5fps with jpeg encoding with many dropped frames.
This is not as good as my Picamera legacy stack based application which reaches 13 2028*1520 jpeg encoded frames per sec (in video mode)
It seems that a PI4 with sufficient memory capacity is necessary ?
startTime = time.time()
count = 100
for i in range(0,count) :
    request = picam2.capture_request()
    image = request.make_array("main")
    jpeg = cv2.imencode('.jpg', image)
    request.release()
stopTime = time.time()
fps = float(count/(stopTime-startTime))
print("Time:", (stopTime-startTime), " Fps:", fps)
Then I did HDR experiments a bit like the Mertens supplied example but in the frame stream without closing and opening the camera by playing with AeEnable and ExposureTime. The behavior is correct and here it is interesting to have the metadata without the frame.
therealdavidp
Sat Feb 19, 2022 6:08 pm
The three configurations try to give users the settings they're most likely to want "out of the box". But other users may want different things so we'll have to see what the best way is to do this across the user base. So for example:
* Video configurations give you the most buffers, which will help avoiding dropped frames, especially once we have a supported h264 encoder. They also give you a "faster" version of the colour denoise processing, and fix the framerate to 30fps, which is often what people want.
* The still configuration gives you better but slower colour denoise and tries to allocate fewer buffers because the frames will typically be larger.
* The preview configuration doesn't do any special colour denoise at all, I believe, and gives you variable framerates. This means you can switch to still captures and get longer exposure times.
But there's nothing very fundamentally different - by changing what you ask for, and perhaps specifying application specific control values, you can make any one configuration match another.
Yes, there are padding issues. I think the "video_configuration" method is forgetting to align the output stream size; it probably should. But you can always change the size again before calling "configure" and it should do what you ask. There's probably no reason not to "slice" the numpy arrays into a "non-aligned" shape, I just haven't tried yet whether it has any performance implications.
Obviously we'll have to look at the memory issues on the Pi 3. I don't think there's any clear reason why it shouldn't be able to allocate as many buffers as libcamera-apps do, so maybe there's something to investigate there.
We haven't released any video encoding as yet, but eventually I expect that to include jpeg ("mjpeg") encoding in due course. There are issues with jpeg encode/decode in that it's generally moving into software, and in the Python world it's hard to use muiti-threading efficiently so there will definitely be some things that will require optimisation here.
You certainly shouldn't need a Pi 4, but it will obviously affect performance. This is just a preview release, so it's clearly good to hear about other platforms and we will be spending time on them in the future.
tvoverbeek
Mon Feb 21, 2022 9:41 pm
I have been playing with preview_drm.py (no X) since I want to run this eventually on a Pi Zero.
The preview window is always positioned in the upper left hand corner (at 0,0).
I have added a possibility to specify a non zero upper left hand corner, so it can e positioned where you want it
by modifying drm_preview.py.
Should i submit a pull request for this change?
The other preview options are in qt windows, so can be positioned in the desktop.
therealdavidp
Tue Feb 22, 2022 9:16 am
Yes please, that sounds like a good change!
tvoverbeek
Tue Feb 22, 2022 10:03 pm
PR submitted.
Could be enhanced by checking if the window (now specified with x,y,w,h) actually fits on the screen and if not adjust accordingly.
tvoverbeek
Wed Feb 23, 2022 9:27 pm
OpenCV and picamera2
When installing picamera2 on Raspi OS 64-bit on a Pi4-2GB I used the apt version of opencv:
 sudo apt install python3-opencv
This is version 4.5.1 which is more recent than the 4.4.0.46 version suggested in the README.
The Haar classifiers are in a separate package: opencv-data.
sudo apt install opencv-data
They are then in /usr/share/opencv4/haarcascades/.
After modifying the Haar classifiers path in opencv_face_detect and opencv_face_detect_2 both
examples work.
I have not tried (yet) to use the apt opencv package on Raspi OS 32-bit, but I exepct it to work.
The opencv_mertens_merge examples fails on the last exposure with:
ERROR RPISTREAM rpi_stream.cpp:242 Failed to queue buffer for ISP Output0
I guess it is running out of buffers. This is on a 2G Pi4
therealdavidp
Wed Feb 23, 2022 9:59 pm
Hi, just a note to anyone interested that we've posted an early version of video encode support. Again, it's a "have a look and give it a try" thing, and only for h.264, at this stage.
To see how to use it, please look at https://github.com/raspberrypi/picamera ... e_video.py
Anyone installing Picamera2 will also need the python-v4l2 module now, which can be installed using:
cd
git clone https://github.com/RaspberryPiFoundation/python-v4l2.git
Don't forget to add /home/pi/python-v4l2 to your PYTHONPATH variable.
therealdavidp
Thu Feb 24, 2022 9:30 am
examples work.
Ah thanks, maybe this was the incantation I didn't know about. I'll give it a try.
Actually I get this message on both 2GB and 4GB Pi4s, but in both cases it seems to produce the output files correctly. I'm not really sure why the message pops out, maybe the camera is still running on somehow and we aren't recycling buffers back to it fast enough. Or something. We'll take a look. It's certainly not running out of memory - if you "watch -n 0.25 grep Cma /proc/meminfo" while it's running it has loads of spare CMA memory on both platforms (actually I see no difference between the two).
tvoverbeek
Thu Feb 24, 2022 2:00 pm
See my last commit to fix opencv_mertens_merge. It seems picam2.configure has to be called before each picam2.start.
Then the example works
ianblack
Tue Mar 01, 2022 6:49 pm
I've started a branch on my picamera2 fork that is going to have a focus on headless applications. Or applications that don't require a camera preview. Last night I figured out the steps for acquiring, configuring (sort of), starting, stopping, and releasing the camera. I'm having a hard time wrapping my head around the methods for sending and receiving requests. Is there an example that goes straight from point A to point B on how to submit a request for an image and then obtain the data? Or can you provide any insight? Thanks.
therealdavidp
Wed Mar 02, 2022 9:20 am
Hi, have you checked out the various examples here? Please feel free to post back here if you'd like any more help with those.
ianblack
Thu Mar 03, 2022 9:58 am
I've looked through the examples a little bit. I think I am looking for something that is a little more granular and pieces out the interactions between the camera and libcamera. I've been working on documenting and simplifying your code here (at least I think I am). I'd like to get it to a point where I can submit a pull request while maintaining similar functionality to what you already have. I think I am having a hard time wrapping my head around the create and queueRequests functions and the entire CompletedRequests class. It may be that when I read requests I think of the python-requests module.
Here is my attempt at dumbing down the requests process.
Camera Starts
1) queueRequests ()
2) getReadyRequests
3) Plug into CompletedRequests which holds the thread until the requests are completed and then encodes them for shipment elsewhere.
Is there a simple way of recreating that, or do I have to jump through the hoops that CompletedRequests goes through?
Does the libcamera_config we submit have all of the information needed to complete requests? It looks like it is restricted to three streams at a single time. Does the order of those streams matter or is the 0th stream always for "main"?
I also seem to be breaking something when I send all of the controls with the start function. Are all of the controls accepted as options? It may also be how I am supplying the data. For example, it looks like the FrameDurationLimits control should be a tuple, while in the default controls it makes it seem like it is an integer. Am I interpreting those tuples correctly when you list the controls? (min, max, default).
Return to “Camera board”
