arm_freq=2000
arm_freq=2147
gpu_freq=750
arm_freq=2000
arm_freq=2147
gpu_freq=750
Revision : d03115
Model : Raspberry Pi 4 Model B Rev 1.5
arm_freq=2000
core_freq=700
gpu_freq=700
for raspberry putaftermath17 wrote: ↑Thu Aug 11, 2022 3:58 pmWhen you say you run in "performance mode", are you referring to the overlock settings in your post? I know that "over_voltage" has been deemed to not be necessary anymore. I assume the consensus is the 3 other settings you use still apply to the newest revisions of the Pi 4?
echo "performance" | sudo tee /sys/devices/system/cpu/cpu*/cpufreq/scaling_governor
yes, i'm using a pi4-4gb, when using raspberry i'm using the standard 32bit raspberry os mainly for drm sites.I assume the consensus is the 3 other settings you use still apply to the newest revisions of the Pi 4?
A little higher, maybe, but much higher is doubtful.aftermath17 wrote: ↑Thu Aug 11, 2022 3:28 pmEven with an arm_freq of 2000, this thing doesn't even sweat and idles ~40C. I bet it can go much higher.
Mechatronics Inc.
