raspberryswirl
Updating to wpa_supplicant 2.10
Tue Aug 16, 2022 8:28 pm
Hi all!
Can anyone point me in the right direction as to the simplest way to update wpa_supplicant 2.9 to 2.10?
I've reviewed the following resources but it's a bit out of my league:
https://w1.fi/wpa_supplicant/
https://www.linuxfromscratch.org/blfs/v ... icant.html
I'm ideally looking for an install script similar to this guide designed for 2.9
viewtopic.php?t=287485
Any help will be appreciated. Thank you!
pidd
Re: Updating to wpa_supplicant 2.10
Tue Aug 16, 2022 9:18 pm
2.10 is in bullseye-backports, add bullseye-backports to your sources and install with apt
eg new file /etc/apt/sources.list.d/backports.list
containing the following
deb http://deb.debian.org/debian bullseye-backports main
then
sudo apt update
sudo apt install wpasupplicant/bullseye-backports
raspberryswirl
Wed Aug 17, 2022 6:35 am
Thanks - something like this was exactly what I was looking for!
I got an error however after adding backports that public key is not available and installation failed. I believe it's fixed by the following commands before running apt update:
sudo apt-key adv --keyserver keyserver.ubuntu.com --recv-keys 04EE7237B7D453EC
sudo apt-key adv --keyserver keyserver.ubuntu.com --recv-keys 648ACFD622F3D138
Not sure if these keys are the best / safest to use so anyone feel free to chime in or confirm they are okay.
Thanks again for the help!
pidd
Wed Aug 17, 2022 6:53 am
They are fine and safe to use, iirc you only need one of them but two does no harm.
64-bit RPiOS already has relevant keyrings, installing the debian-archive-keyring package may work
