tinker2much
[SOLVED] serial console more than 80x24?
Mon Sep 05, 2022 5:44 pm
I bought a USB UART serial console cable during the recent Pimoroni sale https://shop.pimoroni.com/products/usb- ... =288389664; I had a spare Pi Zero and a spare sd card, so time to play. I got connected without too much trouble, using "screen" from a Debian laptop. But the console seems to be set to 80x24; its like a smaller viewport within the larger screen display. You can sort of see this when I do an "ls -l" in a full directory, see attached.
. This is even more obvious when I invoke "mc" (midnight commander) - see other attached image.
Is this configurable, and where? On the Zero, on the laptop, in screen?
memjr
Re: serial console more than 80x24?
Mon Sep 05, 2022 5:57 pm
If that is configurable, it'll be in one of these 2 files (system vs user config)
Customizing Screen
Like many Linux applications, Screen uses a customizable configuration file. Find the system-wide configuration file at /etc/screenrc. The user’s configuration file is located at ~/.screenrc.
And user manual https://www.gnu.org/software/screen/manual/screen.html
Try this:
https://www.gnu.org/software/screen/man ... indow-Size
tinker2much
Mon Sep 05, 2022 6:16 pm
With either of screen's width or height commands, I get "Your termcap does not specify how to change the terminal's width|height to ..."
I have the feeling that the problem is what's appearing IN the screen window, not the screen window itself. IOW, the contents not the container. Which would have to be fiddled with on the sending zero?
memjr
Mon Sep 05, 2022 6:19 pm
Dumb question: did you try to change the settings of your terminal? Not just drag to corner of the window to make it longer and wider, but actually change it's default settings.
cleverca22
Mon Sep 05, 2022 6:46 pm
the problem is that the serial terminal emulator, is not informing the remote (linux on rpi) end about the resizing
so the remote linux is just stuck defaulting to 80x24
echo "stty rows $(tput lines) cols $(tput cols)"
the 2 tput commands, send ansii control codes to ask the terminal emulator what the width/height are
the stty command then modifies the tty on the remote linux, to change the dimensions
you can also just run the "resize" command from the xterm package to do the same thing
jojopi
Mon Sep 05, 2022 7:52 pm
They do not. tput lines and cols just print the currently-assumed terminal size, which is the very thing we are trying to correct.
The resize program from the xterm package, however does attempt to query the terminal emulator using escape sequences.
cleverca22
Mon Sep 05, 2022 8:38 pm
oops, right, i forgot how that command was meant to be used, and why the echo is there
you where meant to run that before you start the serial terminal program, to get the LOCAL terminal size
and it prints out an stty command, that you copy, then paste into the terminal after you connect
yep, thats far simpler, and can be used repeatedly as you resize, its just slightly confusing that its in the xterm package
tinker2much
Mon Sep 05, 2022 9:01 pm
I ran the following on the local terminal:
Which returned the following:
stty rows 33 cols 132
I cut that from the local terminal and pasted it into the serial terminal, and that did it. Now mc looks like this:
You guys are great, thank you very much!
ukscone
Re: [SOLVED] serial console more than 80x24?
Mon Sep 25, 2023 3:59 pm
if you install the xterm package then the command resize will set the serial console to the size of your console window. you can also put
    rsz() {
        if [[ -t 0 && $# -eq 0 ]];then
                local IFS='[;' escape geometry x y
                echo -ne '\e7\e[r\e[999;999H\e[6n\e8'
                read -t 5 -sd R escape geometry
                x=${geometry##*;} y=${geometry%%;*}
                if [[ ${COLUMNS} -eq ${x} && ${LINES} -eq ${y} ]];then
                        echo "${TERM} ${x}x${y}"
                else
                        echo "${COLUMNS}x${LINES} -> ${x}x${y}"
                        stty cols ${x} rows ${y}
                fi
        else
                print 'Usage: rsz'
        fi
    case $( /usr/bin/tty ) in
            /dev/ttyAMA0|/dev/ttyAMA10|/dev/ttyO0|/dev/ttyS0) export LANG=C
                                                rsz
    esac
into /etc/profile.d/serial-console.sh
and it should automatically resize/set your console window size
Thomas Nittel
Mon Sep 25, 2023 4:16 pm
If the following lines are added to /etc/bash.bashrc the columns and rows of a serial console will automatically be adjusted to the screen size. So, the Midnight Commander will fill the whole screen which it finds at start. This solution was originally posted at https://unix.stackexchange.com/a/680244
# resize function for connected serial console
resize() {
  old=$(stty -g)
  stty raw -echo min 0 time 5
  printf '\0337\033[r\033[999;999H\033[6n\0338' > /dev/tty
  IFS='[;R' read -r _ rows cols _ < /dev/tty
  stty "$old"
  #echo "cols:$cols"
  #echo "rows:$rows"
  stty cols "$cols" rows "$rows"
ALL_COMMANDS_FINISHED=1
PreCommands() {
  if [ "$ALL_COMMANDS_FINISHED" = '1' ]; then
    ALL_COMMANDS_FINISHED=0
    resize
    #echo "1->0"
  fi
PostCommands() {
# if login thru tty*
if [[ $(tty) == /dev/tty* ]]; then
  # PreCommands is called before every single command on a command line
  trap PreCommands DEBUG
  # PostCommands is called after all commands on a command line are finished
  PROMPT_COMMAND="PostCommands"
fi
The Midnight Commander at the serial terminal will start with color and mouse support if the following line is added to /etc/bash.bashrc (see https://midnight-commander.org/wiki/doc/faq):
alias mc='mc -x -c'
To enable root to use the alias the following line can be added to /etc/bash.bashrc:
alias sudo='sudo -E '
I use 2023-05-03-raspios-bullseye-arm64-lite and PuTTY 0.77 under Windows 10 Pro 22H2.
cleverca22
Mon Sep 25, 2023 4:22 pm
both duplicate answers, i already said the same thing back in this thread, in 2022
