maverick_24
unable to detect ov5640 in Raspberry Pi
Thu Sep 29, 2022 8:56 am
Im using raspberry Pi 4, I had compiled kernel 5.15.70 and I included ov5640 as dynamic module(configured using make menuconfig ) and after that I used ov5647.v5647dtsi and ov5647-overlay.dts files and created ov5640.dtsi and ov5640-overlay.dts and just replaced texts, i.e, ov5647 with ov5640 and 36 address with 3c, and after compiling generated dtbo file is copied to /boot/overlays/ and added dtoverlay=ov5640 and rebooted, after rebooting I2c device nodes were created but when i try to load driver, it loads successfully but when no video device nodes were found, and one more thing is in dmesg I didnt seen any error.
6by9
Re: unable to detect ov5640 in Raspberry Pi
Thu Sep 29, 2022 10:16 am
Where has this ov5640 module come from? Has it got all the necessary supply rails and clocks on board?
Does it respond when probed with "i2cdetect -y 10"?
Have you added "dtoverlay=ov5640" to /boot/config.txt? Camera autodetection only works for Rasbperry Pi camera modules (ov5647, imx219, and imx477).
Have all the V4L2 devices probed? Check "sudo cat /sys/kernel/debug/v4l2-async/pending_async_subdevices" - you should get ov5640 and unicam listed, but with nothing after the colon.
Did the overlay apply? Check "sudo vcdbg log msg" for any dt related errors. If nothing obvious, then add "dtdebug=1" to /boot/config.txt to get more debug from the dt process.
Subhash_24
Sun Oct 02, 2022 1:58 pm
I had followed everything now I'm able to bind device with driver and video nodes are being created, now when I try to stream with libcamera I'm facing some errors
Libcamera Error:
Setting pipeline to PAUSED ...
[0:11:41.847873650] [1665]  INFO Camera camera_manager.cpp:293 libcamera v0.0.0+3865-3fad116f
[0:11:41.870382270] [1669]  WARN CameraSensor camera_sensor.cpp:212 'ov5640 10-003c': Recommended V4L2 control 0x009a0922 not supported
[0:11:41.870472917] [1669] ERROR V4L2 v4l2_subdevice.cpp:387 'ov5640 10-003c': Unable to get rectangle 2 on pad 0: Inappropriate ioctl for device
[0:11:41.870538064] [1669]  WARN CameraSensor camera_sensor.cpp:239 'ov5640 10-003c': The PixelArraySize property has been defaulted to 2592x1944
[0:11:41.870579212] [1669] ERROR V4L2 v4l2_subdevice.cpp:387 'ov5640 10-003c': Unable to get rectangle 1 on pad 0: Inappropriate ioctl for device
[0:11:41.870639600] [1669]  WARN CameraSensor camera_sensor.cpp:250 'ov5640 10-003c': The PixelArrayActiveAreas property has been defaulted to (0, 0)/2592x1944
[0:11:41.870683452] [1669] ERROR V4L2 v4l2_subdevice.cpp:387 'ov5640 10-003c': Unable to get rectangle 0 on pad 0: Inappropriate ioctl for device
[0:11:41.870723599] [1669]  WARN CameraSensor camera_sensor.cpp:258 'ov5640 10-003c': Failed to retrieve the sensor crop rectangle
[0:11:41.870755655] [1669]  WARN CameraSensor camera_sensor.cpp:264 'ov5640 10-003c': The sensor kernel driver needs to be fixed
[0:11:41.870785840] [1669]  WARN CameraSensor camera_sensor.cpp:266 'ov5640 10-003c': See Documentation/sensor_driver_requirements.rst in the libcamera sources for more information
[0:11:41.870831043] [1669] ERROR CameraSensor camera_sensor.cpp:287 'ov5640 10-003c': Mandatory V4L2 control 0x009e0902 not available
[0:11:41.870871283] [1669] ERROR CameraSensor camera_sensor.cpp:287 'ov5640 10-003c': Mandatory V4L2 control 0x009e0901 not available
[0:11:41.870904357] [1669] ERROR CameraSensor camera_sensor.cpp:295 'ov5640 10-003c': The sensor kernel driver needs to be fixed
[0:11:41.870933597] [1669] ERROR CameraSensor camera_sensor.cpp:297 'ov5640 10-003c': See Documentation/sensor_driver_requirements.rst in the libcamera sources for more information
[0:11:41.871495073] [1669] ERROR RPI raspberrypi.cpp:1184 Failed to register camera ov5640 10-003c: -22
ERROR: from element /GstPipeline:pipeline0/GstLibcameraSrc:libcamerasrc0: Could not find any supported camera on this system.
Additional debug info:
../src/gstreamer/gstlibcamerasrc.cpp(354): gst_libcamera_src_open (): /GstPipeline:pipeline0/GstLibcameraSrc:libcamerasrc0:
libcamera::CameraMananger::cameras() is empty
ERROR: pipeline doesn't want to preroll.
Failed to set pipeline to PAUSED.
Setting pipeline to NULL ...
Freeing pipeline ...
the command I used is :
     gst-launch-1.0 libcamerasrc ! video/x-raw, width=640, height=480, framerate=30/1 ! videoconvert ! videoscale ! clockoverlay time-format="%D %H:%M:%S" ! autovideosink
so what to so now?
6by9
Sun Oct 02, 2022 3:51 pm
Welcome to the world of bringing up a new sensor. OV5640 is NOT one of the sensors that support has been added for as yet, so expect issues. Mainline drivers are not necessarily written to work against libcamera.
The log messages tell you the issue
0x009e0902 is V4L2_CID_HBLANK
0x009e0901 is V4L2_CID_VBLANK
Without those it is not possible to configure frame rate, and as exposure time is normally set in units of lines you can't set exposure either.
It looks like the driver may have been updated to support these controls in the 6.0 kernel release - https://github.com/raspberrypi/linux/co ... c/ov5640.c. You could try cherry-picking all the changes back from 6.0 to 5.15, or try building 6.0.
Subhash_24
Mon Oct 03, 2022 4:06 am
ok, facing problems with ov5640 while using libcamera is common thing because, it does not have helper classes for ov5640,
and I came to know that libcamera main purpose was to ISP, and ov5647 does not have that, but ov5640 has ISP, so instead of using libcamera and writing helper classes for libcamera, its better to use v4l2.
So I planned to use v4l2, so for testing I used Raspberry Pi supported camera ov5647
So I conncted ov5647 to MIPI interface and runned this command
command:
    gst-launch-1.0 v4l2src device="/dev/video0" ! videoconvert ! autovideosink
Output Error:
Pipeline is live and does not need PREROLL ...
Pipeline is PREROLLED ...
Setting pipeline to PLAYING ...
New clock: GstSystemClock
ERROR: from element /GstPipeline:pipeline0/GstV4l2Src:v4l2src0: Failed to allocate required memory.
../sys/v4l2/gstv4l2src.c(659): gst_v4l2src_decide_allocation (): /GstPipeline:pipeline0/GstV4l2Src:v4l2src0:
Buffer pool activation failed
ERROR: from element /GstPipeline:pipeline0/GstV4l2Src:v4l2src0: Internal data stream error.
../libs/gst/base/gstbasesrc.c(3127): gst_base_src_loop (): /GstPipeline:pipeline0/GstV4l2Src:v4l2src0:
streaming stopped, reason not-negotiated (-4)
Execution ended after 0:00:00.112955084
dmesg log:
         unicam fe801000.csi : failed to start media pipeline: -22
I'm able to stream ov5647 with libcamera why not with v4l2?
if v4l2 works with ov5647, I will try to give a try with ov5640,
6by9
Mon Oct 03, 2022 6:38 am
viewtopic.php?t=322076
Media Controller separates setting the format for multiple points down the pipeline, and requires you to set the resolution and format on each pad in the chain. libcamera will do this for you, but v4l2src won't.
You can disable Media Controller for ov5647 by loading with "dtoverlay=ov5647,media-controller=0" (and removing "camera_auto_detect=1" if present).
Subhash_24
Mon Oct 03, 2022 8:22 am
Again I'm facing a problem
This is my /boot/config.txt
# http://rpf.io/configtxt
#hdmi_safe=1
#overscan_left=16
#overscan_right=16
#overscan_top=16
#overscan_bottom=16
# overscan.
#framebuffer_width=1280
#framebuffer_height=720
#hdmi_force_hotplug=1
#hdmi_group=1
#hdmi_mode=1
#hdmi_drive=2
# no display
#config_hdmi_boost=4
# uncomment for composite PAL
#sdtv_mode=2
#arm_freq=800
dtparam=i2c_arm=on
#dtparam=i2s=on
#dtparam=spi=on
# Uncomment this to enable infrared communication.
#dtoverlay=gpio-ir,gpio_pin=17
#dtoverlay=gpio-ir-tx,gpio_pin=18
dtparam=audio=on
# Automatically load overlays for detected cameras
#camera_auto_detect=1
# Automatically load overlays for detected DSI displays
display_auto_detect=1
# Enable DRM VC4 V3D driver
dtoverlay=vc4-kms-v3d
max_framebuffers=2
# Disable compensation for displays with overscan
disable_overscan=1
[cm4]
# Enable host mode on the 2711 built-in XHCI USB controller.
# This line should be removed if the legacy DWC2 controller is required
# (e.g. for USB device mode) or if USB support is not required.
otg_mode=1
[all]
[pi4]
# Run as fast as firmware / board allows
arm_boost=1
[all]
kernel=kernel-subhash.img
dtoverlay=ov5647
media-controller=0
after changing I rebooted the Raspberry Pi
and in terminal i followed the process which they shown viewtopic.php?t=322076
v4l2-ctl -v width=640,height=480,pixelformat=YUYV --device /dev/videoX
X : I used all numbers present under /dev/video*
and after that I tried
media-ctl -v -d /dev/media4 -V ''\''ov5640 10-0036'\'':0 [fmt:SRGGB10_1X10/640x480 field:none]'
after /dev/media0 I tried with /dev/meida,1,2,3,4 but I got error seeting failed
for /dev/media0
Opening media device /dev/media0
Enumerating entities
looking up device: 81:15
looking up device: 81:14
Found 2 entities
Enumerating pads and links
Setting up format SRGGB10_1X10 640x480 on pad ov5647 10-0036/0
Format set: SGBRG10_1X10 640x480
and after this:
I tried to stream using
command :
again I got error:
Error:
Execution ended after 0:00:00.036154596
and In dmesg I got :
  [ 1669.355628] unicam fe801000.csi: Wrong width or height 3840x2160 (remote pad set to 640x480)
[ 1669.355650] unicam fe801000.csi: Failed to start media pipeline: -22
So after seeing dmesg I used this command:
command:
gst-launch-1.0 v4l2src device=/dev/video0 ! 'video/x-raw, width=(int)640, height=(int)480, format=(string)UYVY' ! videoconvert ! autovideosink
Then again I got same error
and dmesg log:
6by9
Mon Oct 03, 2022 8:31 am
[all]
dtoverlay=ov5647
media-controller=0
Not what I wrote.
if you really want to split it into 2 lines, it has to be
dtoverlay=ov5647
dtparam=media-controller=0
With media controller disabled, just setting the format on /dev/video0 is sufficient to also configure the sensor subdevice.
Subhash_24
Mon Oct 03, 2022 10:07 am
failed to allocate memory error was resolved, but still Internal data stream error persists
ok this is the sequence I followed
1. dtoverlay=ov5647,media-controller=0 added to /boot/config.txt
2. v4l2-ctl -v width=640,height=480,pixelformat=pGAA --device /dev/video0
I got pixelformat information using
command:
    v4l2-ctl --device /dev/video0 --all
output:
       Format Video Capture:
	Width/Height      : 640/480
	Pixel Format      : 'pGAA' (10-bit Bayer GBGB/RGRG Packed)
	Field             : None
	Bytes per Line    : 800
	Size Image        : 384000
	Colorspace        : Raw
	Transfer Function : Default (maps to None)
	YCbCr/HSV Encoding: Default (maps to ITU-R 601)
	Quantization      : Default (maps to Full Range)
	Flags             :
3. after that I tried this
command:
             media-ctl  -v -d /dev/media1 -V ''\''ov5647 10-0036'\'':0 [fmt:SGBRG10_1X10/640x480 field:none]'
operation not permitted error thrown
output:
   Opening media device /dev/media3
Found 2 entities
Setting up format SGBRG10_1X10 640x480 on pad ov5647 10-0036/0
Unable to set format: Operation not permitted (-1)
Unable to setup formats: Operation not permitted (1)
even trying with sudo I got same thing so I left this command
4. I run gstreamer to stream, but still I'm facing error but this time error is little different, I'm not getting failed to allocate memory error now, but still getting Internal data stream error.
command:
ERROR: from element /GstPipeline:pipeline0/GgstreamerstV4l2Src:v4l2src0: Internal data stream error.
Execution ended after 0:00:00.000436181
I checked dmesg log I'm did not see any log related to this,
5. I run gstreamer to stream, with adding width and height
command :
     gst-launch-1.0 v4l2src device=/dev/video0 ! 'video/x-raw, width=(int)640, height=(int)480' ! autovideosink
got same error, and again I did not see any log in dmesg
6. I run gstreamer , by adding width, height and format, I'm unable to stream, and got online output with some warning
command:
gst-launch-1.0 v4l2src device=/dev/video0 ! 'video/x-raw, width=(int)640, height=(int)480, format=(string)pGAA' ! autovideosink
output:
WARNING: erroneous pipeline: could not link v4l2src0 to autovideosink0, v4l2src0 can't handle caps video/x-raw, width=(int)640, height=(int)480, format=(string)pGAA
6by9
Mon Oct 03, 2022 11:05 am
command:
output:
Found 2 entities
Correct. You've just disabled Media Controller, therefore expecting it to do anything useful is a bit daft.
Subhash_24 wrote:4. I run gstreamer to stream, but still I'm facing error but this time error is little different, I'm not getting failed to allocate memory error now, but still getting Internal data stream error.
command:
GStreamer has very limited support for Bayer formats.
Converting a Bayer image into a usable YUV or RGB image is far more than the simple videoconvert does. (This is the whole reason we have libcamera).
Subhash_24 wrote:5. I run gstreamer to stream, with adding width and height
command :
Because you're still not addressing the issue of the image format.
Subhash_24 wrote:6. I run gstreamer , by adding width, height and format, I'm unable to stream, and got online output with some warning
command:
output:
Exactly - it can't handle "format=(string)pGAA"
You can stream ov5647 using V4L2 - "v4l2-ctl --stream-mmap=3 --stream-count=1000 --stream-to=file.raw" will give you a stream of raw Bayer images.
ov5640 can give you processed YUYV images, and those you can pass through GStreamer as-is.
Subhash_24
Mon Oct 03, 2022 12:00 pm
Thanks @6by9 I learnt a lot, everything is working fine now. Thanks for your support
Subhash_24
Thu Oct 06, 2022 4:52 pm
Hello @6by9 can you tell me why we need to add dtoverlay=ov5640, inorder to detect ov5640, why it is not the same case with ov5647, where we are not even setting dtoverlay in config.txt but it is getting detected? but not the same with ov5640 even copying ov5640.dtbo to /boot/overlays/
trejan
Thu Oct 06, 2022 5:14 pm
OV5647 was used in the Raspberry Pi Camera v1. The Pi firmware will autodetect the official Pi cameras and automatically load the overlay. OV5640 isn't one of them so you need to load the overlay for it yourself.
Subhash_24
Thu Oct 06, 2022 5:25 pm
Dont we have control on that?
trejan
Thu Oct 06, 2022 6:15 pm
All you can do is disable that autodetection by setting camera_auto_detect=0 in /boot/config.txt. You can't make it autoload the ov5640 overlay.
6by9
Thu Oct 06, 2022 8:52 pm
OV5640 is not an official Pi camera module.
The firmware is closed source, so no you can't add it. You can manually add the relevant "dtoverlay=..." line to load the overlay.
Return to “Camera board”
