Rather new to Raspberry Pi and Linux, trying to figure out how to run multichannel audio without an audio interface.
The idea is to run an HDMI cable in an audio extractor and take the 7.1 signal - treating it as a regular 8ch of audio - to feed loudspeakers. Optionally I am also going to use an Audio Injector Octo or a different audio interface, depending on the situation.
I have uninstalled Pulse Audio because it clashes with everything i need, from Audio Injector to Jack:
sudo apt-get remove pulseaudio
sudo apt-get remove pulseaudio-utils
sudo apt-get autoremove
$ sudo apt-get install alsa-base alsa-tools alsa-tools-gui alsa-utils alsa-oss alsamixergui libalsaplayer0
now when I try to run jack both from terminal AND from the GUI i get the following error:
- JackShmReadWritePtr::~JackShmReadWritePtr - init not done for -1, skipping unlock
13:29:22.970 Statistics reset.
13:29:34.376 JACK is starting...
13:29:34.377 /usr/bin/jackd -dalsa -dhw:vc4hdmi0 -r44100 -p16 -n2 -P
Cannot connect to server socket err = no such file or directory
Cannot connect to server request channel
jack server is not running and cannot be started
13:29:34.452 JACK was started with PID=1823
Copyright 2001-2005 Paul Davis and others.
Copyright 2004-2016 Grame.
Copyright 2016-2021 Filipe Coelho.
jackdmp comes with ABSOLUTELY NO WARRANTY
This is free software, and you are welcome to redistribute it
under certain conditions; see the file COPYING for details
JACK server starting in realtime mode with priority 10
self-connect-mode is "Don't restrict self connect requests"
audio_reservation_init
Acquire audio card Audio0
creating alsa driver ... hw:vc4hdmi0|-|16|2|44100|0|0|nomon|swmeter|-|32bit
configuring for 44100Hz, period = 16 frames (0.4 ms), buffer = 2 periods
Sorry. The audio interface "hw:vc4hdmi0" doesn't support any of the hardware sample formats that JACK's alsa-driver can use.
ALSA: cannot configure playback channel
Released audio card Audio0
audio_reservation_finish
Cannot initialize driver
JackServer::Open failed with -1
Failed to open server
13:29:34.902 JACK was stopped
13:29:36.478 Could not connect to JACK server as client. - Overall operation failed. - Unable to connect to server. Please check the messages windows for more info.
So far speaker tests run correctly.
sudo speaker-test -c 2 -t sine -D hdmi:vc4hdmi0
speaker-test 1.2.4
Playback device is hdmi:vc4hdmi0
Stream parameters are 48000Hz, S16_LE, 2 channels
Sine wave rate is 440,0000Hz
Rate set to 48000Hz (requested 48000Hz)
Buffer size range from 64 to 65536
Period size range from 32 to 32768
Using max buffer size 65536
Periods = 4
was set period_size = 16384
was set buffer_size = 65536
0 - Front Left
1 - Front Right
Time per period = 4,111098
0 - Front Left
So far both my aplay-L and my aplay -l look good to me (even tho i don't understand why the PulseAudio Sound Server still shows up ???)
sudo aplay -L
null
Discard all samples (playback) or generate zero samples (capture)
sysdefault
Default Audio Device
lavrate
Rate Converter Plugin Using Libav/FFmpeg Library
samplerate
Rate Converter Plugin Using Samplerate Library
speexrate
Rate Converter Plugin Using Speex Resampler
jack
Jack Audio Connection Kit
oss
Open Sound System
pulse
upmix
Plugin for channel upmix (4, 6, 8)
downmix
Plugin for channel downmix (stereo) with a simple spacialization
default
anyChannelCount
hw:CARD=vc4hdmi0,DEV=0
vc4-hdmi-0, MAI PCM i2s-hifi-0
Direct hardware device without any conversions
plughw:CARD=vc4hdmi0,DEV=0
Hardware device with all software conversions
sysdefault:CARD=vc4hdmi0
hdmi:CARD=vc4hdmi0,DEV=0
HDMI Audio Output
dmix:CARD=vc4hdmi0,DEV=0
Direct sample mixing device
usbstream:CARD=vc4hdmi0
vc4-hdmi-0
USB Stream Output
hw:CARD=vc4hdmi1,DEV=0
vc4-hdmi-1, MAI PCM i2s-hifi-0
plughw:CARD=vc4hdmi1,DEV=0
sysdefault:CARD=vc4hdmi1
hdmi:CARD=vc4hdmi1,DEV=0
HDMI Audio Output
dmix:CARD=vc4hdmi1,DEV=0
vc4-hdmi-0
USB Stream Output
sudo aplay -l
**** List of PLAYBACK Hardware Devices ****
card 0: vc4hdmi0 [vc4-hdmi-0], device 0: MAI PCM 12s-hifi-0 [MAI PCM 12s-hifi-0]
Subdevices: 1/1
Subdevice #0: subdevice #0
card 1: vc4hdmi1 [vc4-hdmi-1], device 0: MAI PCM 12s-hifi-0 [MAI PCM 12s-hifi-0]
Subdevices: 1/1
To me it doesn't seem that I have a problem inside ALSA, it looks more like Jack not being able to find something it needs to run.
Anyone has a clue?
Also, eventually, I would like to enable the 7.1 on both HDMI that are 2ch by default. Does anyone know where can I find the config file to do so?
Device:
Raspberry Pi 4 Mod. B 8Gb
System:
Raspberry Pi reference 64bit
Best Regards,
G
