I've got Kodi installed on a Pi3B running Bullseye, and whilst I can start it up, that seems to be about all I can do with it.
I've currently got the Pi connected to a monitor, but in due course, I'll plug it into my TV. I can access Kodi using Firefox from another computer.
I've tried a couple of different things, firstly setting up the weather service. I've select the Met Office, but that doesn't seem to give me any weather, and if I try to change it away from the default of London, I get a 403 error from a Met Office server.
Turning to TV/Radio streaming, I've selected the PVR, but all I get is "PVR manager is starting up: 0%" on the monitor and a revolving circle with "just a sec" in the browser, which never changes. It appears to have pre-configured "Tvheadend HTSP Client", but according to the event log, the server is unreachable. Is this the right client for the UK, and how do I change it if not.
TIA
Adrian
Getting Kodi to work - UK
Frequently Ffoiled
Re: Getting Kodi to work - UK
PVR requires a server on your network (which can be the original pi) that has a TV receiver card (e.g. a USB DVB dongle, or I2S DVB HAT) connected to an aerial. Do you have that? If not, PVR is not for you.ffoiled wrote: ↑Wed Feb 08, 2023 4:51 pmTurning to TV/Radio streaming, I've selected the PVR, but all I get is "PVR manager is starting up: 0%" on the monitor and a revolving circle with "just a sec" in the browser, which never changes. It appears to have pre-configured "Tvheadend HTSP Client", but according to the event log, the server is unreachable. Is this the right client for the UK, and how do I change it if not.
Kodi is a media player. You will need to have your own media (e.g. an a USB devive, or shared drive on you local network).
It doesn't not include content itself. (Although there are addons, like iPlayer that can be installed).
Thanks MaddyR and Dom.
I think that I might have misunderstood how Kodi works. My assumption was that it was some form of front end for the likes of iPlayer and ITVX. I wasn't looking for a PVR type device (I've already got one), but assumed (silly me) that Kodi's PVR was the tool for accessing online content (e.g. iPlayer).
I'll look into plugins for the services I want to use.
However, that doesn't explain why I can't get the weather to work.
Adrian
Adrian
Frequently Ffoiled
As with a lot of open source, Kodi is reliant on volunteer effort to get things working, and to keep them working. I would guess that the Met Office have changed their systems in some way, and this has caused the problem in Kodi. It is also possible, of course, that there is a problem at the Met Office.
Thanks, that is an entirely fair comment.andrum99 wrote: ↑Wed May 03, 2023 4:45 pmAs with a lot of open source, Kodi is reliant on volunteer effort to get things working, and to keep them working. I would guess that the Met Office have changed their systems in some way, and this has caused the problem in Kodi. It is also possible, of course, that there is a problem at the Met Office.
Adrian
Frequently Ffoiled
ffoiled wrote: ↑Tue May 02, 2023 3:09 pmThanks MaddyR and Dom.
Adrian
Why not just view in the chromium web browser ?
It's probably just a storm in a teacup.
...i'll get my coat.
Pi4B 2GB Rev1.4 Mini-PC/Media Centre: ARM=2.25GHz @1.1v, Core=600MHz, GPU=850MHz. Raspberry Pi OS with KODI on 128GB Sandisk Extreme Pro A2 microSD card in Integral card reader in USB3.0 port (138MB/s read). Geekworm P173 case with copper shim on SOC.
