An update has been pushed to support libwidevinecdm0 and chromium-browser on 64-bit RPiOS bullseye directly.
This is used by DRM protected services like Netflix and Amazon Prime.
If you were previously using 32-bit libwidevinecdm0/chromium-browser on 64-bit RPiOS, it should be possible to apt remove them,
and reinstall the native 64-bit versions. This should result in an improvement in widevine video performance.
Let us know if this works for you.
Re: Chromium and widevine on 64-bit
It works great. Thank you!
On 32bit systems I executed a script by vpetkov and then had to use chromium media edition for netflix:
viewtopic.php?p=1767167#p1767167
What steps are now needed to use netflix with current 64bit PiOS chromium browser?
sudo apt install libwidevinecdm0
https://stamm-wilbrandt.de/cgi-bin/echo ... ank+you%21dom wrote: ↑Wed Feb 22, 2023 5:55 pmassuming you already have chromium-browser installed.Code: Select all
$ echo -e 'Thank you!' | pbmtext -builtin fixed | pnmcrop | pbmtobraille
$ I verified Netflix to work, and Amazon Prime Video:
Really appreciate the effort. In my case however, Raspberry 4B 8gb, the streaming starts but after a few seconds pushes the CPU to 100% and the video and sound are interrupted every few seconds as of then (whereas it was working with the 32bit browser).
This is big news and very welcome. I am curious how you did this as I was not aware of Google releasing a 64-bit version of Widevine for arm64?
What resolution is it using on 32-bit and 64-bit?
There are chromeos images for arm64.
