What I’m trying to do:
On a Raspberry Pi 4 B, I’m trying to use Gstreamer Editing Services to cut a portion of a video previously created by Gstreamer on the pi. The output video would be only a fraction of the duration of the input video long. Using hwaccel would be nice.
Steps description:
I used a fresh install of “Raspberry Pi OS with desktop rel September 22nd 2022 32 bits version, Kernel version: 5.15 Debian version: 11 (bullseye)” downloaded here
I did a full package upgrade via the graphical utility and I installed the necessary packages:
gstreamer1.0-tools → 1.18.4-2.1
gstreamer1.0-plugins-base-apps → 1.18.4-2
ges1.0-tools → 1.18.4-2
The procedure is the following:
First I create a 3 s long video (in case anyone wonders, the capsfilter after the v4l2h264enc element is necessary and is based on this 2021 post:
gst-launch-1.0 videotestsrc num-buffers=100 ! v4l2h264enc ! 'video/x-h264,level=(string)3' ! h264parse ! mp4mux ! filesink location=video.mp4Code: Select all
ges-launch-1.0 +clip video.mp4 inpoint=1 duration=1 -o out.mp4 -f "video/quicktime:video/x-h264"Code: Select all
ERROR from element v4l2h264enc0: Failed to process frame./>
Debugging info: ../sys/v4l2/gstv4l2videoenc.c(828): gst_v4l2_video_enc_handle_frame (): /GESPipeline:gespipeline0/GstEncodeBin:internal-encodebin/v4l2h264enc:v4l2h264enc0:
Maybe be due to not enough memory or failing driverCode: Select all
[172098.718574] bcm2835-codec bcm2835-codec: bcm2835_codec_start_streaming: Failed enabling i/p port, ret -3
…My first thought: in order to extract a portion of a video, ges has to decode and reencode the stream (I hope I’m right!). Do both decode and encode elements (v4l2h264dec and v4l2h264enc) work? I mean, do they work, separately, on their own?
-Well, v4l2h264enc seems to work because the first pipeline above produced a file ‘video.mp4’ which can be played with gst-play-1.0
-What about v4l2h264dec?
Firstly: does ges use v4l2h264dec to decode? To get info on that I used debugging on ges-launch-1.0:
GST_DEBUG=v4l2*:7 ges-launch-1.0 +clip video.mp4 inpoint=1 duration=1 -o out.mp4 -f "video/quicktime:video/x-h264"Then, to test if v4l2h264dec works I tried to use it in a simple pipeline for decoding to a raw file:
gst-launch-1.0 -vvvv filesrc location=video.mp4 ! qtdemux ! h264parse ! v4l2h264dec ! filesink location=video.rawCode: Select all
gst-launch-1.0 filesrc location=video.raw ! queue ! "video/x-raw, width=320, height=240, format=I420, framerate=30/1" ! rawvideoparse use-sink-caps=true ! autovideosinkNow that I know v4l2h264dec is working, can ges use v4l2h264dec effectively?
To test this, I ask ges for a rendering in the raw video format:
ges-launch-1.0 +clip video.mp4 inpoint=1 duration=1 -o out.raw -f "video/x-raw"Code: Select all
gst-launch-1.0 filesrc location=out.raw ! queue ! "video/x-raw, format=I420, width=320, height=240, framerate=30/1" ! rawvideoparse use-sink-caps=true ! videoconvert ! autovideosinkWell, anyway, ges seems to be able to use v4l2h264dec to do something that looks like decoding, even if I don't know what format it's using...
At this point it seems both v4l2h264dec and v4l2h264enc elements are working, at least separately.
Now, could the problem be that v4l2h264dec and v4l2h264enc can’t run at the same time? (my thought being: both use the same hardware and it is a limitation).
To test this, I create a pipeline that uses both elements:
gst-launch-1.0 filesrc location=video.mp4 ! qtdemux ! h264parse ! v4l2h264dec ! v4l2h264enc ! 'video/x-h264,level=(string)3' ! h264parse ! mp4mux ! filesink location=out.mp4From these observations it seems the problem comes from the way ges-launch manages things.
Could it be the same problem that the one of the 2021 post mentioned earlier? i.e. the chosen level for the encode that causes the problem?
To test that, I parsed the output using debugging:
GST_DEBUG=v4l2*:7 ges-launch-1.0 +clip video.mp4 inpoint=1 duration=1 -o out.mp4 -f "video/quicktime:video/x-h264" > log_debug 2>&1 Selected H264 profile baseline at level 1
Yes, It’s there, and it mentions level 1. So could it be the exact same problem?
To go further, I tried to look for the lines produced by the firmware mentioned in the 2021 post:
2752715.698: venc: enc_open: consistency failed
2752715.777: venc: enc_open: other failureMy investigations end here…
My questions:
-Is here the right place to ask about this? If not, where?
-Is there a way to cut a video using ges-launch using hwaccel on the pi?
-If the answer is yes, could someone describe it?
-If the answer is no, are there other options to cut a video using command line on the pi?
-How is my logic in trying to solve this problem? Please don’t hesitate to point out misunderstandings and errors, these are most valuable!
Let me finish this post by stating how
