eXsoR
Contact: ICQ
[Tutorial] Show RPI's Temperature with a command.
Sun Feb 24, 2013 8:48 pm
So i decided to make a quick Tutorial on how to show the Raspberry PI's Temperature.
Note: this is using the on-board sensor.
The command to do this is:
/opt/vc/bin/vcgencmd measure_temp
You can also simplify the command by making an alias and adding it to your ~/.bashrc or as instructed in the bashrc file. Make a file in your home directory called .bash_aliases and put your aliases in that file rather then in the .bashrc file.
Making the .bash_aliases file by running the command:
sudo nano .bash_aliases
Make sure you are in your home directory before making the file. You can check by making sure your terminal says pi@raspberrypi ~ $ and (~) meaning you are in your home directory. if you are not just run the command
cd ~
In the file wright the aliases. example:
alias temp='/opt/vc/bin/vcgencmd measure_temp'
note: if you don't put the apostrophe ( ' ) before and after the command it wont work. Also note that I put the nickname that you are going to give this command, followed up a equals sign (=).
I hope you guys find this useful is I did. Since i live in a very hot environment that I like to check the temp here and there. :D
Re: [Tutorial] Show RPI's Temperature with a command.
Sun Feb 24, 2013 10:43 pm
Nice tip!
I'd just like to point out that you don't need "sudo" to run nano on files in your home directory. You already have all the permissions you need. Keep root/superuser privileges for when they are really needed - it's safer prcatice.
BerryPicker
Mon Feb 25, 2013 1:09 pm
With the 2013-02-09 raspbian distribution the command and response is
/opt/vc/bin/vcgencmd: error while loading shared libraries: libvcos.so: cannot open shared object file: No such file or directory
For information on this see:
Bug 15006 - Libraries in ld.so.cache ignored by ld-linux-armhf.so.3 on armv6l
http://sourceware.org/bugzilla/show_bug.cgi?id=15006
The offered workaround is
pi@raspberrypi ~ $ cd /opt/vc/bin
pi@raspberrypi /opt/vc/bin $ LD_LIBRARY_PATH=/opt/vc/lib ./vcgencmd measure_temp
temp=49.2'C
So, now for another exercise in building an alias ...
SuPeRMiNoR2
Fri Mar 15, 2013 5:25 pm
BerryPicker wrote:With the 2013-02-09 raspbian distribution the command and response is
temp=49.2'C
As far as I can tell, that bug has been fixed, but if anyone has a older version that still has that bug here is the the alias to use.
alias temp="LD_LIBRARY_PATH=/opt/vc/lib && /opt/vc/bin/vcgencmd measure_temp"
m0rgo
Wed Mar 20, 2013 10:02 pm
Is it possible to import the system temperature into a python program?
pluggy
Thu Mar 21, 2013 12:23 am
An alternative is to read /sys/class/thermal/thermal_zone0/temp on a recent Raspdian. Divide it by 1000 for degrees C.
cat /sys/class/thermal/thermal_zone0/temp
will do it at the command line.
Fraoch
Thu Mar 21, 2013 5:12 pm
Does Pi Raspbian support lm-sensors? That's the package I use on my Ubuntu PC. However I think lm-sensors needs access to a hardware monitoring chip which I doubt the Pi has - unless there's something hidden in the SoC which wouldn't be terribly surprising, there's lots of stuff in there. ;)
It'd be nice to display the temperature using conky, I have to learn how to do this - looks like it can be done.
Pencoed-made Model 1B, Samsung memory
2B 1.1
3B
3B+
4B 2GB
badfur
Mon Apr 01, 2013 10:38 am
#!/bin/bash
cpuTemp0=$(cat /sys/class/thermal/thermal_zone0/temp)
cpuTemp1=$(($cpuTemp0/1000))
cpuTemp2=$(($cpuTemp0/100))
cpuTempM=$(($cpuTemp2 % $cpuTemp1))
echo CPU temp"="$cpuTemp1"."$cpuTempM"'C"
echo GPU $(/opt/vc/bin/vcgencmd measure_temp)
m0rgo
Wed Apr 03, 2013 9:15 pm
I asked earlier if the system temperature could be imported into a python script.
Here is my solution;
First, write a shell script to get system time and save it into a file in current directory.
e.g.
#!/bin/bash
#get system temperarure and save as 'sysTemp'
/opt/vc/bin/vcgencmd measure_temp > sysTemp
# this creates a file called sysTemp in current directory
Secondly, write a python script / function to import value in sysTemp and convert it to a number that can be used;
e.g.
#!/bin/python
#script to read a file and extract a number
fo = open("sysTemp") # Open a file
str = fo.read(); #read characters in sysTemp and hold them as 'str'
fo.close() #close opened file
print(str) # print string to check
temp1=str[5:9] #chop out required characters
temp2=eval(temp1) #convert string into number
print("system temp = ", temp2) # print value to check
temp=temp2*2 # multiply by 2 to check for mathematical useability
print("twice system temp = ",temp) # print multiplied number
When you get to the point that 'temp' is useable, it can be used for whatever you want.
Note. I've commented the above to death to explain what is going on. In use, you would remove unnecessary comments and print statements.
m0rgo
Wed Apr 03, 2013 9:55 pm
There is another command that you can use to get the system temperature;
cat /sys/class/thermal/thermal_zone0/temp.
This gives the system temperature in milli-degrees
To use the alternate temperature command and import it into Python;
First, write shell script to get system time and save it into a file in current directory. I used temp.sh for the shell script.
i.e.
#!/bin/bash
#get system temperature and save as 'sysTemp'
cat /sys/class/thermal/thermal_zone0/temp > sysTemp
Note. This version gives a five figure number that is milli-degrees, so it will need converting for use.
i.e.
#!/bin/python
str = fo.read(); # read characters in sysTemp
fo.close() # close opened file
print('string = ',str) # print string to check
t=eval(str) # convert string into number
print ('extracted number = ',t) # print evaluated number
t2=t*2 # multiply by 2, evaluated number
print('twice temp in milli-degrees = ',t2) # print result of multiplication
t3=(t/1000.00) # convert five figure temp (milli-degrees) to degrees to two decimal places
print ('temperature in degrees = ',t3) # print result
Again, remove extraneous print commands and comments to reduce size and clutter in script.
Joe Schmoe
Wed Apr 03, 2013 10:07 pm
Interestingly, I get different results from the program vs accessing the file in /sys. (And, yes, I ran this enough times to be confident that the results are not just instaneously changing...)
Also, these numbers seems high to me. The last time I played around with this temperature stuff, I was consistently getting readings around 47 degrees. Of course, now my Pi is in a box - instead of in the open air. I suppose that would account for the change.
pts/2 pi@raspberrypi /var/log $ /opt/vc/bin/vcgencmd measure_temp
temp=53.0'C
pts/2 pi@raspberrypi /var/log $ gawk '{print $1/1000,"degrees C"}' /sys/class/thermal/thermal_zone0/temp
54.072 degrees C
yuusou
Mon Apr 29, 2013 8:45 am
badfur wrote:
#!/bin/bash
I quite liked your script, so I decided to clean it up a little:
#!/bin/bash
gpuTemp0=$(/opt/vc/bin/vcgencmd measure_temp)
gpuTemp0=${gpuTemp0//\'/º}
gpuTemp0=${gpuTemp0//temp=/}
echo CPU Temp: $cpuTemp1"."$cpuTempM"ºC"
echo GPU Temp: $gpuTemp0
The output comes out as following:
pi@YuuberryPi ~ $ ./temp
CPU Temp: 56.2ºC
GPU Temp: 56.2ºC
pi@YuuberryPi ~ $
solar3000
Sat May 18, 2013 12:39 am
 perl -e 'm/(\d+)/; $x=$1; s/\d+//; printf ("%.1f", ( $x / 1000))' -p /sys/class/thermal/thermal_zone0/temp
Antikythera
sprinkmeier
Sat May 18, 2013 2:33 am
Nice one!
in python:
tempC = int(open('/sys/class/thermal/thermal_zone0/temp').read()) / 1e3
solar3000
Sat May 18, 2013 11:20 pm
Or both:
perl -e 'm/(\d+)/; $c=$1/1000; s/\d+//; $f = $c * 9 / 5 + 32; for ($f, $cputemp){ $_ = sprintf ( "%.1f" ,  $_  ) }; print "$c C, $f F";' -p /sys/class/thermal/thermal_zone0/temp
Antikythera
solar3000
Sat May 18, 2013 11:22 pm
can you do one liners in python?
What I did above, you can just copy and paste in your bash prompt and hit enter (gently).
Antikythera
sprinkmeier
Sat May 18, 2013 11:51 pm
solar3000 wrote:can you do one liners in python?
$ python -c "import base64;print(base64.decodestring('WUVTIQ==\n'))"
solar3000
Sun May 19, 2013 12:58 am
python -c "import base64;print(base64.decodestring('QmlnIEZhdCBTaG93b2Zm\n'))"
Antikythera
sprinkmeier
Sun May 19, 2013 3:29 am
$ python -c "import base64;import gzip;print(gzip.zlib.decompress(base64.decodestring('eJxTUFBQ5gJiIEQCyiDABWIooAiDCS5UZSjiaOqhxqCbjkUlAH+dENQ=\n')))"
solar3000
Sun May 19, 2013 5:54 am
since you're going there....
how about some ascii art?
ASCII art one liner?
http://www.codeproject.com/Articles/109 ... -Generator
Antikythera
Sun May 19, 2013 6:30 am
Just because I was bored... ;-)
sed "s/\(...\)$/.\1°C/" < /sys/class/thermal/thermal_zone0/temp
JacopoBassan
Thu Nov 07, 2013 4:06 pm
I know this post is old, but oh well…
The command "bc" is a REALLY useful utility to perform simple & complex math operation.
Performing Math calculation in Bash
sudo apt-get install bc
After that if you just want to get something formatted like "32.8" type
echo "scale=1; $(cat /sys/class/thermal/thermal_zone0/temp)/1000" | bc
Note: you can choose between "scale=1/2/3..." to get a different decimal precision.
slackpi
Mon Dec 02, 2013 9:40 pm
JacopoBassan wrote:I know this post is old, but oh well…
Excellent solution!
Running Slackware ARM 14.1 on the Pi
phoenixDownunder
Fri Jan 17, 2014 12:22 am
When I run /opt/vc/bin/vcgencmd measure_temp I get
temp=64.3'C
Is that a bit high? Ambient is 44C here
AndyD
Fri Jan 17, 2014 12:51 am
phoenixDownunder wrote:temp=64.3'C Is that a bit high? Ambient is 44C here
I think that is reasonable. Is your Raspberry Pi working hard? It is around 30°C in my house at the moment and my Raspberry Pis are idle and running at 55.1°C and 55.6°C. It is going to 44°C today (again) looking forward to a cool change tonight after 5 very hot days.
