Akkiesoft
Question: How to use dtparam=hdmi option
Mon May 01, 2023 4:12 am
Hi.
I noticed that HDMI can be disabled with the dtparam=hdmi option.
https://github.com/raspberrypi/linux/pull/5181
So I wrote following lines into /boot/config.txt then reboot Pi.
dtparam=hdmi=off
# Pi4?
dtparam=hdmi0=off
dtparam=hdmi1=off
However, these options are not working and do not appear to be able to turn off HDMI.
I was expecting HDMI with the dtparam option, just as I could turn it off with tvservice -o when using fkms, is that not the case?
I tested with Raspberry Pi OS (32-bit) kernel 5.15.84-v7+ and 6.1.21-v8+, on Pi3B+ and Pi4.
Akkiesoft
Re: Question: How to use dtparam=hdmi option
Mon May 01, 2023 6:38 am
I forgot to write my purpose: I want to save power by disabling HDMI.
I saw this post.
viewtopic.php?p=2084904#p2084904
I tried this command and it seems to have saved about 100mA of power.
$ DISPLAY=:0.0 xrandr --output HDMI-1 --off
Am I correct in understanding that xrandr is an alternative to tvservice -o/-p for power saving?
But then what is dtparam for?
