WB4WTN
Newbie Question
Thu May 18, 2023 9:03 pm
I thought I might like to use the Sense Hat with my Pi 4, but in what I have read so far, one needs to be a Python programmer to get real use of the hat. Is there any pre-build software for the Hat?
GTR2Fan
Re: Newbie Question
Thu May 18, 2023 9:08 pm
Pi4B 2GB Rev1.4 Mini-PC/Media Centre: ARM=2.25GHz @1.1v, Core=600MHz, GPU=850MHz. Raspberry Pi OS with KODI on 128GB Sandisk Extreme Pro A2 microSD card in Integral card reader in USB3.0 port (138MB/s read). Geekworm P173 case with copper shim on SOC.
WB4WTN
Re: Newbie Question
Thu May 18, 2023 9:14 pm
Thanks, but as I read this, I still see that I need to be either a C++ or Python programmer. I'm not interested in programming, I want to gather data.
GTR2Fan
Re: Newbie Question
Thu May 18, 2023 9:46 pm
I don't see how you're going to gather data without using software to access the hardware. That software will most likely be Python.
This weather sensor guide should give you some useful pointers...
https://maker.pro/raspberry-pi/projects ... ensor-data
WB4WTN
Re: Newbie Question
Thu May 18, 2023 9:51 pm
I understand that I will need software to gather data. If all I want is pressure readings why do I have to reinvent the wheel? Thanks for the reply.
ame
Re: Newbie Question
Thu May 18, 2023 10:07 pm
You don't have to reinvent the wheel. The software is already written:
from sense_hat import SenseHat
sense = SenseHat()
pressure = sense.get_pressure()
print("Pressure: %s Millibars" % pressure)
# alternatives
print(sense.pressure)
This information is included in the Fine Manual:
https://pythonhosted.org/sense-hat/api/
Oh no, not again.
Return to “Astro Pi”
