Courage2000
External LCD display Standby
Fri Sep 22, 2023 9:26 pm
Hello!
I have a RPI 3b+ computer with Buster and an external touchscreen.
I want to be able to put that LCD in standby mode, but to be able to wake up on touch.
Now I use the blanking method via xscreenaver, but in this case, the LCD is not really closed, is blank - I can see the hallo.
I want the display part to be closed.
It's possible and how?
The display is connected via a ribbon cable, not HDMI.
Thank you
kerry_s
Re: External LCD display Standby
Fri Sep 22, 2023 9:34 pm
if it's off there is no touch.
can you touch the screen on your phone to wake it up ?
Courage2000
Fri Sep 22, 2023 10:27 pm
Actually, it seems to work If I run manually those commands. The display is OFF, not only blanked.
export DISPLAY=:0
xset dpms force off
If I put the same lines inside this file, it does not work :(
sudo nano /etc/xdg/lxsession/LXDE-pi/autostart
xset dpms force off
xset s 120
Courage2000
Fri Sep 22, 2023 11:18 pm
The problem was fixed via xscreensaver settings!
Edit autorestart file
add this to the end o the file an reboot
@xset dpms
sudo reboot[/b]
[attachment=1]1.jpg[/attachment] [attachment=0]2.jpg[/attachment]
All working now. After 2 minutes the LCD is OFF.
I waited 10 minutes and with a touch, the screen wake up immediately.
blanking
power management
