KOWALSKI67
What is the full name of the new Raspberry Pi 5 model?
Fri Sep 29, 2023 3:33 pm
What exactly is the name of the new Raspberry Pi 5 model? I ask because, for example, Raspberry Pi 3 there are models "Raspberry Pi 3 model A+", "Raspberry Pi 3 model B". And the new Raspberry Pi 5 model what exactly is it called? On Wikipedia, at https://en.wikipedia.org/wiki/Raspberry_Pi I read that there is only one model of Raspberry Pi 5 - "Raspberry Pi 5 Model B", while in online stores this model of Raspberry Pi was labeled only as "Raspberry Pi 5" without the addition of "Model B" What kind of model is this? What is the full name of the new Raspberry Pi 5 model?
kerry_s
Re: What is the full name of the new Raspberry Pi 5 model?
Fri Sep 29, 2023 4:34 pm
the other models have different variants.
there is only 1 model of rpi5
W. H. Heydt
Fri Sep 29, 2023 4:41 pm
With two variants, 4GB or 8GB DRAM. That said, the Pi5 uses the "B" form factor so calling it a Pi5B is not unreasonable.
bjtheone
Fri Sep 29, 2023 4:45 pm
I am calling mine Bitbucket...
HermannSW
Fri Sep 29, 2023 4:48 pm
"Raspberry Pi 5":
https://www.raspberrypi.com/products/ra ... cification
(if you want with a square around the 5)
hippy
Fri Sep 29, 2023 5:46 pm
I have found it quite hard not to call it a 5B and suspect many will because "B" is the form factor, regardless of whether any other sized variant exists or doesn't. It will balance out the number of people who always referred to the Pi 4.
Fri Sep 29, 2023 5:52 pm
If I get one I will call it Johnny.
Unreadable squiggle
ame
Fri Sep 29, 2023 8:22 pm
Don't disassemble it!
Oh no, not again.
kip_the_elder
Sun Oct 01, 2023 8:33 am
Here in France; my usual supplier seems to have renamed it the "épuisé"
..already.... :roll:
Always be kind to beginner geeks. They will be the ones programming your ventilator. :)
Gavinmc42
Sun Oct 01, 2023 10:20 am
Ah, just calling it the Pi5 and not Pi5B dodges that annoying question, "When is the PI5A coming out?"
Have seen people demanding the Pi4A for years.
Brilliant way to misdirect attention, like saying the 2 in RP2040 means 2 cores :lol:
So could a Pi5A format be made, get rid of the Ethernet jack/chip and leave one USB3.
Not going to save much money but a 1GB or 2GB version could be useful.
I'm dancing on Rainbows.
Sun Oct 01, 2023 10:42 am
You know the 2 in RP2040 means two cores, right?
andrum99
Sun Oct 01, 2023 12:09 pm
Yeah I suspect this generation will be the one to drop the B suffix, given there wasn't a Pi 4A and it has been announced as Raspberry Pi 5.
Sun Oct 01, 2023 12:38 pm
AFAIK, the full name is "Raspberry Pi 5 Model B"
Gavinmc42
Sun Oct 01, 2023 1:32 pm
So Pi5A in 2024? :lol:
hippy
Sun Oct 01, 2023 3:00 pm
Has anyone mentioned Pi 6 yet or am I the first ? :D
DirkS
Sun Oct 01, 2023 3:48 pm
search.php?keywords=pi6
bensimmo
Sun Oct 01, 2023 3:55 pm
Dp
bensimmo
Sun Oct 01, 2023 3:57 pm
First I've read so far for Pi6, congrats.
Pi4A was in the first posts of the Pi4
Pi5A will have a single USBC at new USB3 speeds. (Excl. poser one)
WiFi/BT, dual uHDMI, and open up the PCIe and the other now free lanes.
Keeping the new dual Cam setup too.
Shrunk and compact for robotics and info displays.
The Pi5π model* is a new model and scraps the hdmi and usb sockets, (excl power) to with a new to Pi compact ethernet with integrated PoE.
Making the headless users dream.
WiFi/BT not scrapped to keep a wider headless user base and allow BT keyboard mouse to still be used if really needed.
*Secret codename if you search Pi GitHub enough is ἀκέφαλοι
liz
Sun Oct 01, 2023 5:36 pm
Actually no Model B in this one, James: the times, they are a changin'!
paul433
Sun Oct 01, 2023 8:34 pm
Guess this needs changed then. https://github.com/raspberrypi/linux/bl ... pi-5-b.dts so there is no confusion
W. H. Heydt
Sun Oct 01, 2023 8:43 pm
My best guess is that the feature set for the Pi6 is already decided (i.e. no point in "I want XXX on the Pi6; it's too late for that). I wouldn't be totally shocked if there are already Pi6 prototypes in the pipeline. Pi6 should be released some time in the 2026-28 time range.
Gavinmc42
Mon Oct 02, 2023 12:05 am
I would suspect sooner rather than later.
By using the RP1 "south bridge" it allows for PC motherboard type option of the CPU/GPU swapping.
The pathway to future Pi's got so much simpler and cheaper.
The features of the Pi5 are now full, ie PCIe that works and has connector, 4K60 HDMI, non shared USB3.
But that's not the important thing, it is how it was implemented.
Basically 3 custom CPU/GPU, IO and Power chips, redesigning any of those is much easier to do now.
Each one has different silicon processes, tech levels and different manufacturers.
The design of the Pi5 was frozen years ago, tech has moved on quite a lot since then.
Most importantly is the direction of that tech, CV, NN, ML etc
No longer is CPU or GPU grunt seen as the path forward.
Smarter, lower power methods are being explored.
How that tech will end up in Pi6+ is speculation but we will get it sooner or later.
I am just saying sooner after seeing how the Pi5 was done.
It could be via the PCIe with working Coral, via a Sony sensor with NN on chip or Micron DRAM with AI block.
USB Coral should work full speed now?
That $45M spent is a good investment in the future of Pi SBCs.
It also throws down the challenge to other SBC makers.
Pi6, 7 could happen so much faster because RP1 exists.
Not sure what improvements could be done on the Pi5 to bring out a better Pi6.
I suspect the RP1 and Power chip will stay and BCM2712 swapped for ?
Faster Ethernet to make Jeff Geerling happy?
Faster WiFi?
Mind you, RPi Ltd don't just make SBC's, they do other stuff too :D
Expect more stuff :lol:
6by9
Mon Oct 02, 2023 10:27 am
Er, not quite James. As per the MagPi article:
RP1 is the first silicon we designed.
RP2 (RP2040) is the second silicon we designed.
RP3 (Pi02) is the third silicon we designed.
gordon77
Mon Oct 02, 2023 10:37 am
Milliways
Mon Oct 02, 2023 10:46 am
I will just wait until it is available and see what it thinks it is called.
/proc/device-tree/model
My Pi4 thinks it is a Raspberry Pi 4 Model B Rev 1.1
