All four of the above statements are true
"Raspberry Pi 400 Rev 1.0" for me/proc/device-tree/model
Not sure I entirely agree with that. The general idea is certainly sound, but there's room to die shrink and improvements to the RP1. There are a number of possible improvements. Faster PCIe (it is spec'd for gen 2 and can--mostly--do gen 3, so a full gen 3 or gen 4), faster USB bus to support USB 3.1 (and--eventually--3.2) are both obvious paths. Could also steal ideas from the RP2 and add some number of use-accessible PIOs. Whether or not the chip gets renamed...that's up to the folks at RPT.
Indeed they do. The new PSU has tremendous potential for uses well beyond powering Pi5s. Perhaps at long last, Eben will be able to work on the long ago proposed 10" RPF display. With 4 lanes at 1.5Gb/s, it might even have FHD resolution. And, of course, there are the dead obvious products in the form of CM5 and Pi500. One might even suggest a "Pi500+" that incorporates an access hatch in the bottom to install the RTC battery and an M.2 slot--and, perhaps, more DRAM--so the whole is completely self-contained. (I'm thinking the Pi500, when it happens will be as near identical to the Pi400, except for the processor, power, and DRAM, as makes no difference. Could probably even use the same case.) However, I"m sure that the good folks at RPT have thought of all those possibilities already...and more besides.Mind you, RPi Ltd don't just make SBC's, they do other stuff too![]()
Expect more stuff![]()
A big reason for RP1 was ESD protection from kids fingers on the GPIO pins, a die shrink reduces that protection.The general idea is certainly sound, but there's room to die shrink and improvements to the RP1
Yep and CM5 and Pi500......For now, the Pi5 is a mighty fine looking piece of kit and I can think of uses for at least 4 of them right off.
https://gist.github.com/cleverca22/97e4 ... 27c0cd034a
compatible = "raspberrypi,5-model-b", "brcm,bcm2712";
model = "Raspberry Pi 5 Model B";
But it's from England, so the full name is something like Raspberry Sextus Denys Oswolf Fraudatifilius Tollemache-Tollemache de Orellana Plantagenet Pi 5
Considering they're made in Wales, I'd've expected "Tudor" in there somewhere, rather than Plantagenet.scruss wrote: ↑Mon Oct 09, 2023 1:52 amBut it's from England, so the full name is something like Raspberry Sextus Denys Oswolf Fraudatifilius Tollemache-Tollemache de Orellana Plantagenet Pi 5
Raspberry McPiface.W. H. Heydt wrote: ↑Mon Oct 09, 2023 2:00 amConsidering they're made in Wales, I'd've expected "Tudor" in there somewhere, rather than Plantagenet.scruss wrote: ↑Mon Oct 09, 2023 1:52 amBut it's from England, so the full name is something like Raspberry Sextus Denys Oswolf Fraudatifilius Tollemache-Tollemache de Orellana Plantagenet Pi 5
