Today while updating my Raspberry Pi 4B computer I got the following error. Any guidance on how to fix this error will be very helpful. Kindly let me know if you need any further inputs from my side on this context. Thanks in advance.
ganeshp@aga-rpi4bsvr:~ $ sudo apt-get update && sudo apt-get upgrade
Get:1 http://security.debian.org/debian-security bookworm-security InRelease [48.0 kB]
Hit:2 http://deb.debian.org/debian bookworm InRelease
Get:3 http://deb.debian.org/debian bookworm-updates InRelease [52.1 kB]
Get:4 http://security.debian.org/debian-security bookworm-security/main armhf Packages [96.0 kB]
Get:5 http://security.debian.org/debian-security bookworm-security/main arm64 Packages [98.5 kB]
Get:6 http://security.debian.org/debian-security bookworm-security/main Translation-en [58.7 kB]
Ign:7 https://download.webmin.com/download/newkey/repository stable InRelease
Get:8 http://archive.raspberrypi.org/debian bookworm InRelease [23.6 kB]
Hit:9 https://download.webmin.com/download/newkey/repository stable Release
Get:11 http://archive.raspberrypi.org/debian bookworm/main arm64 Packages [338 kB]
Get:12 http://archive.raspberrypi.org/debian bookworm/main armhf Packages [346 kB]
Fetched 1,061 kB in 3s (386 kB/s)
Reading package lists... Done
Building dependency tree... Done
1 package can be upgraded. Run 'apt list --upgradable' to see it.
Calculating upgrade... Done
The following packages will be upgraded:
raspi-firmware
1 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
2 not fully installed or removed.
Need to get 4,551 kB of archives.
After this operation, 1,024 B of additional disk space will be used.
Do you want to continue? [Y/n] y
Get:1 http://archive.raspberrypi.org/debian bookworm/main arm64 raspi-firmware all 1:1.20231024+ds-1+rpt2 [4,551 kB]
Fetched 4,551 kB in 2s (2,736 kB/s)
Reading changelogs... Done
(Reading database ... 90014 files and directories currently installed.)
Preparing to unpack .../raspi-firmware_1%3a1.20231024+ds-1+rpt2_all.deb ...
Unpacking raspi-firmware (1:1.20231024+ds-1+rpt2) over (1:1.20231024+ds-1+rpt1) ...
Setting up raspi-firmware (1:1.20231024+ds-1+rpt2) ...
Installing new version of config file /etc/kernel/postinst.d/z50-raspi-firmware ...
stat: cannot read file system information for '/boot/firmware': No such file or directory
Error: missing /boot/firmware, did you forget to mount it?
dpkg: error processing package raspi-firmware (--configure):
installed raspi-firmware package post-installation script subprocess returned error exit status 1
dpkg: dependency problems prevent configuration of rpi-eeprom:
rpi-eeprom depends on raspi-firmware; however:
Package raspi-firmware is not configured yet.
dpkg: error processing package rpi-eeprom (--configure):
dependency problems - leaving unconfigured
Processing triggers for initramfs-tools (0.142) ...
raspi-firmware
rpi-eeprom
E: Sub-process /usr/bin/dpkg returned an error code (1)
Cleaning up residual residual files, if any from apt.
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
After this operation, 0 B of additional disk space will be used.
raspi-firmware
rpi-eeprom
Package refresh completed.
Ganesh
