Mariossos
Raspberry Pi5 - two DSI LCD
Wed Dec 27, 2023 2:08 pm
I have two DSI LCD 4.3inch:
https://www.waveshare.com/wiki/4.3inch_DSI_LCD
Displays connected using:
https://www.waveshare.com/cm-dsi-adapter.htm
Loaded the latest Raspberry Pi OS (64 bit) onto the SD card.
What do I need to change in the /boot/firmware/config.txt file? After starting the Raspberry Pi5 with two displays connected, the red diode is constantly lit and the system does not start.
6by9
Re: Raspberry Pi5 - two DSI LCD
Wed Dec 27, 2023 3:12 pm
Does it work with one display connected? Does it matter which port it is connected to?
It's a third party product that clones the Raspberry Pi display - support should come from Waveshare (I do love Waveshare's anti-piracy and "Beware of knock-offs" sections in the wiki seeing as they copied the Pi design).
As an outside guess, it looks like they're powering the whole display off the 3V3 rail that is present on the DSI FFC connector. That's quite a load, so it's quite possible that it exceeds the current the Pi can provide at 3V3.
The wiki sort of confirms that with
Question: What is the working current of 4.3inch DSI LCD?
Answer:
The normal working current of Raspberry PI 4B alone with a 5V power supply is 450mA-500mA;
Using 5V power supply raspberry PI 4B+4.3inch DSI LCD maximum brightness normal operating current is 700mA-750mA;
So it's adding an extra ~300mA per display, so around 600mA for two displays (ignoring the step down in voltage and conversion losses).
Mariossos
Wed Dec 27, 2023 3:17 pm
If I have a display connected to the CAM/DISP0 port, everything works. Same for the CAM/DISP1 port. Both ports work fine separately.
Everything is powered by the original USB C 5.1V / 5A power supply.
aBUGSworstnightmare
Wed Dec 27, 2023 4:40 pm
What is in your config.txt?
Autodetect of two DSI displays might not work ...
Mariossos
Wed Dec 27, 2023 4:45 pm
Default file:
# http://rptl.io/configtxt
#dtparam=i2c_arm=on
#dtparam=i2s=on
#dtparam=spi=on
dtparam=audio=on
# Additional overlays and parameters are documented
# /boot/firmware/overlays/README
# Automatically load overlays for detected cameras
camera_auto_detect=1
# Automatically load overlays for detected DSI displays
display_auto_detect=1
# Automatically load initramfs files, if found
auto_initramfs=1
# Enable DRM VC4 V3D driver
dtoverlay=vc4-kms-v3d
max_framebuffers=2
# Don't have the firmware create an initial video= setting in cmdline.txt.
# Use the kernel's default instead.
disable_fw_kms_setup=1
# Run in 64-bit mode
arm_64bit=1
# Disable compensation for displays with overscan
disable_overscan=1
# Run as fast as firmware / board allows
arm_boost=1
[cm4]
# Enable host mode on the 2711 built-in XHCI USB controller.
# This line should be removed if the legacy DWC2 controller is required
# (e.g. for USB device mode) or if USB support is not required.
otg_mode=1
[all]
gordon77
Wed Dec 27, 2023 4:53 pm
Does it need something like ..
#display_auto_detect=1
dtoverlay=vc4-kms-dsi-7inch,dsi0
dtoverlay=vc4-kms-dsi-7inch,dsi1
Mariossos
Wed Dec 27, 2023 5:02 pm
Unfortunately it does not work. Earlier, I tried commenting auto_detect and adding these two lines.
6by9
Wed Dec 27, 2023 5:16 pm
In which case it does sound like 2 displays take more current at 3.3V than the Pi5 can supply.
Nothing is going to fix that other than providing some alternative powering mechanism (and do NOT back 3.3V back from your display into the Pi).
aBUGSworstnightmare
Wed Dec 27, 2023 6:35 pm
+1
As the two displays in question run on 3.3V only (from the DSI interface) incl their backlights. The 3.3V rail of the Pi is not designed for such!
So it's waveshare you need to complain at!
cleverca22
Wed Dec 27, 2023 6:37 pm
it may also be possible to modify that flat-flex adapter board
cut the 3.3v trace, and then add your own 3.3v source to the display side
you could also fab up some custom ones with that change
Mariossos
Wed Dec 27, 2023 7:11 pm
I checked the voltages. 5.1V and ... 0V on 3V3.
Amarantos
Thu Jan 04, 2024 12:48 pm
Red LED indicates system is not booting/shutdown. Maybe you can try turning it on manually by pressing the start button?
aBUGSworstnightmare
Thu Jan 04, 2024 7:32 pm
that's a good one, but sorry! Of no help at all as the 3.3V rails is overloaded (and thats stopping the Pi from booting).
Amarantos
Fri Jan 05, 2024 10:53 am
It seems that dual DSI touch screens can be used simultaneously.
6by9
Fri Jan 05, 2024 11:42 am
Yes you can use 2 DSI panels simultaneously, but it depends on the powering arrangements for those panels.
If they have external power supplies or take 5V from the Pi then they will be fine. If they use the Pi's 3.3V rail, then it will depend on the panel.
aBUGSworstnightmare
Fri Jan 05, 2024 2:33 pm
how do you power them as that's not visible?
Amarantos
Sat Jan 06, 2024 2:17 am
I contacted Waveshare technical support a month ago and they have updated it to be compatible with the pi5 version.
Currently using their 5inch DSI LCD and 4.3inch DSI LCD (maybe Rev2.1/Rev2.2), which are completely powered by the Pi5's mipi DSI interface. No additional power supply is used.
aBUGSworstnightmare
Sat Jan 06, 2024 9:17 am
so let's keep fingers crossed the also tested two of each at full brightness (if the brightness can be controlled). This method will stop working once people add more electronics to the Pi's 3.3V rail or when they try to power bigger screens like that (TFT inrush current).
No info on the max current that can be drawn from the 3.3V rail known to me.
Think we can conclude that such questions now should be answered exclusively by waveshare (or any other third party) technical support, because nobody here on the form knows which display HW revision will be/is compatible.
steveiliop56
Sun Jan 07, 2024 5:31 pm
Wait how did you get the display to work? I currently have a 4.3 inch that I bought now same problem. Is that a different screen or did you find a way to make it work?
Amarantos
Mon Jan 08, 2024 2:06 am
Compared with the previous version of the latest version of DSI I have, you can clearly see that several large capacitors are not soldered. Maybe you can try removing the 2-3 large capacitors on the DSI LCD to successfully pass the pi5 power test.
But I only recommend it for personal try and agree with aBUGSworstnightmare, you can contact waveshare technical support https://service.waveshare.com/ to get the most suitable solution.
steveiliop56
Mon Jan 08, 2024 5:46 am
Well waveshare is stupid! I sent them an email some time ago before buying the screen and they confirmed it works with the pi 5! Now I have to go through the refund process and send it back because of them.
Amarantos
Mon Jan 08, 2024 8:06 am
It can be seen from the picture that the DSI LCD I have is indeed compatible with pi5. What you need to ask is why the version you received is not compatible. Maybe there are some usage details that we didn't notice. Good luck!
steveiliop56
Mon Jan 08, 2024 1:00 pm
Is it possible for you to show me a picture of the back of the screen? So I can compare with my version?
steveiliop56
Tue Jan 09, 2024 12:23 pm
Umm are you still here?
rasmeanttobe
Tue Jan 09, 2024 7:53 pm
I am having exactly the same problem and it does not matter where I search, I cannot find a solution.
Submitted tickets for both the seller and waveshare - although I am very keen on knowing the display model of who made it work and how they made it work, if possible along with the config.txt just to see the lines and try to copy it!
Thanks!!
Return to “Official Display”
