Pi 5 L1 cache size
I keep seeing mention of the Pi5 having 64 KB L1 cache per core, but then I see the specs for the Cortex A76 showing separate L1 data and instruction caches, each of 64 KB. I tried using tools like lscpu which worked on the Pi4 but the cache info is missing for the Pi5. So 64 KB combined D and I L1 cache per core or 64 KB D + 64 KB I?
Re: Pi 5 L1 cache size
I think it is 64kB data + 64kB instructions. Install package cpuinfo:
$ cache-info
Max cache size (upper bound): 4194304 bytes
L1 instruction cache: 4 x 64 KB, 4-way set associative (256 sets), 64 byte lines, shared by 1 processors
L1 data cache: 4 x 64 KB, 4-way set associative (256 sets), 64 byte lines, shared by 1 processors
L2 data cache: 4 x 256 KB (inclusive), 8-way set associative (512 sets), 64 byte lines, shared by 1 processors
L3 data cache: 1 MB (exclusive), 16-way set associative (1024 sets), 64 byte lines, shared by 4 processorsRe: Pi 5 L1 cache size
Thanks for the reply. I wasn't aware of the cache-info command but there seems to be something strange going on. For the Pi 4 the info provided seems spot on.
This agrees with data given for the BCM2711 SoC used in the Pi 4 to be found at https://www.raspberrypi.com/documentati ... ssors.html
However for the Pi 5 the cache-info command output looks a bit strange.
Whereas this shows the separate 64 KB data and instruction caches (which I believe to be the case), the L2 and L3 values disagree with the data provided for the BCM2712 used in the Pi 5 in the same document which gives figures that double the sizes of both cache levels.
The reason I asked the question in the first place is because there seems to be a lot of conflicting information out there such as that given in this review https://www.pcmag.com/reviews/raspberry-pi-5.
pi4$ cache-info
L1 instruction cache: 4 x 48 KB, 3-way set associative (256 sets), 64 byte lines, shared by 1 processors
L1 data cache: 4 x 32 KB, 2-way set associative (256 sets), 64 byte lines, shared by 1 processors
L2 data cache: 1 MB (inclusive), 16-way set associative (1024 sets), 64 byte lines, shared by 4 processors
Caches: 32kB data + 48kB instruction L1 cache per core. 1MB L2 cache.
pi5$ cache-info
512KB L2 per core, 2MB shared L3
I was also under the impression the L3 cache size is 2MB. The cache-info output seems to disagree with the published specifications.Serifini wrote: ↑Sat Jan 13, 2024 3:50 pmThanks for the reply. I wasn't aware of the cache-info command but there seems to be something strange going on. For the Pi 4 the info provided seems spot on.This agrees with data given for the BCM2711 SoC used in the Pi 4 to be found at https://www.raspberrypi.com/documentati ... ssors.htmlCode: Select all
pi4$ cache-info L1 instruction cache: 4 x 48 KB, 3-way set associative (256 sets), 64 byte lines, shared by 1 processors L1 data cache: 4 x 32 KB, 2-way set associative (256 sets), 64 byte lines, shared by 1 processors L2 data cache: 1 MB (inclusive), 16-way set associative (1024 sets), 64 byte lines, shared by 4 processorsHowever for the Pi 5 the cache-info command output looks a bit strange.Code: Select all
Caches: 32kB data + 48kB instruction L1 cache per core. 1MB L2 cache.Whereas this shows the separate 64 KB data and instruction caches (which I believe to be the case), the L2 and L3 values disagree with the data provided for the BCM2712 used in the Pi 5 in the same document which gives figures that double the sizes of both cache levels.Code: Select all
pi5$ cache-info L1 instruction cache: 4 x 64 KB, 4-way set associative (256 sets), 64 byte lines, shared by 1 processors L1 data cache: 4 x 64 KB, 4-way set associative (256 sets), 64 byte lines, shared by 1 processors L2 data cache: 4 x 256 KB (inclusive), 8-way set associative (512 sets), 64 byte lines, shared by 1 processors L3 data cache: 1 MB (exclusive), 16-way set associative (1024 sets), 64 byte lines, shared by 4 processorsThe reason I asked the question in the first place is because there seems to be a lot of conflicting information out there such as that given in this review https://www.pcmag.com/reviews/raspberry-pi-5.Code: Select all
In the end performance is what's important. I wonder if Chips and Cheese
https://chipsandcheese.com/
has a test that could confirm L3 cache size.
cache-info is only accurate for specific SoC models. It doesn't probe the hardware and uses the CPU part number shown in /proc/cpuinfo to look it up in an internal database. The data for Cortex-A76 is incomplete as it assumes L2 is always 256K and L3 is always 1M. There is a special case handler for Kirin 980 to adjust those values. Everything else including BCM2712 gets the default values.
There are cache description registers but I don't know how to access them under Linux. cleverca22 has got code to display it but its bare metal.
It looks like cache-info is used to tune Pytorch for various processors. In that case, it is better to error with too small than too large.trejan wrote: ↑Sat Jan 13, 2024 6:20 pmcache-info is only accurate for specific SoC models. It doesn't probe the hardware and uses the CPU part number shown in /proc/cpuinfo to look it up in an internal database. The data for Cortex-A76 is incomplete as it assumes L2 is always 256K and L3 is always 1M. There is a special case handler for Kirin 980 to adjust those values. Everything else including BCM2712 gets the default values.
It looks more like it is incomplete to me than intentionally aiming low. Cortex-A76 L2 is 128kB-512kB and L3 is 0kB-4MB yet it picks 256kB and 1MB.
cleverca22
viewtopic.php?p=2130828&hilit=MIDR#p2130828Unfortunately these OS commands can return hardcoded values for compatibility purposes.
You can check CPU by direct reading it's registers. Here is example program that reads some ID registers:
when i run that on my pi5, i get:
MIDR_EL1: 0x414fd0b1
Implementer: 0x41
Variant: 0x4
Architecture: 0xf
PartNum: 0xd0b
Revision: 0x1
[Reserved]: 0x0
VPIDR_EL2: SIGILL
REVIDR_EL1: 0
ID_AA64ISAR0_EL1: 0x100010211120
ID_AA64ISAR1_EL1: 0x100001
MVFR0_EL1: 0x200
MVFR1_EL1: 0x10011100
MVFR2_EL1: 0
and attempting to read CCSIDR_EL1 results in SIGILL
this would likely have to be moved into the kernel to function?
CCSIDR_EL1 got taken out of the kernel. That is why sysfs no longer reports size.
I kludged together a kernel module to read it. Arm notes that it may not resemble the real cache config but it looks okay to me.
L1 data cache 64 kB, 4-way set associative (256 sets), 64 byte lines. Attributes=WriteBack ReadAllocate WriteAllocate
L1 instruction cache 64 kB, 4-way set associative (256 sets), 64 byte lines. Attributes=ReadAllocate
L2 unified cache 512 kB, 8-way set associative (1024 sets), 64 byte lines. Attributes=WriteBack ReadAllocate WriteAllocate
L3 unified cache 2048 kB, 16-way set associative (2048 sets), 64 byte lines. Attributes=WriteBack ReadAllocate WriteAllocate
