My drive is formatted to FAT32, this is what I have been trying (sorry it's long!):
pi@raspberrypi / $ sudo mount /dev/sda /mnt/usb
mount: you must specify the filesystem type
pi@raspberrypi / $ df -h
Filesystem Size Used Avail Use% Mounted on
rootfs 15G 1.5G 13G 11% /
/dev/root 15G 1.5G 13G 11% /
devtmpfs 212M 0 212M 0% /dev
tmpfs 44M 400K 44M 1% /run
tmpfs 5.0M 0 5.0M 0% /run/lock
tmpfs 88M 0 88M 0% /run/shm
/dev/mmcblk0p1 56M 19M 38M 34% /boot
pi@raspberrypi / $ sudo mount -t vfat -o uid=pi,gid=pi /dev/sda /mnt/usb
mount: wrong fs type, bad option, bad superblock on /dev/sda,
missing codepage or helper program, or other error
In some cases useful info is found in syslog - try
dmesg | tail or so
pi@raspberrypi / $ dmesg | tail
[ 2422.633776] FAT-fs (sda): Can't find a valid FAT filesystem
[ 2469.060552] EXT4-fs (sda): VFS: Can't find ext4 filesystem
[ 2469.065678] EXT4-fs (sda): VFS: Can't find ext4 filesystem
[ 2469.075552] EXT4-fs (sda): VFS: Can't find ext4 filesystem
[ 2469.085564] FAT-fs (sda): invalid media value (0xb9)
[ 2469.085589] FAT-fs (sda): Can't find a valid FAT filesystem
[ 2469.095687] FAT-fs (sda): invalid media value (0xb9)
[ 2469.095713] FAT-fs (sda): Can't find a valid FAT filesystem
[ 2583.814281] FAT-fs (sda): invalid media value (0xb9)
[ 2583.814308] FAT-fs (sda): Can't find a valid FAT filesystem
pi@raspberrypi / $ sudo mount -t ntfs-3g -o uid=pi,gid=pi /dev/sda1 /media/USBDRIVE/
mount: mount point /media/USBDRIVE/ does not exist
pi@raspberrypi / $ sudo mount -t ntfs-3g -o uid=pi,gid=pi /dev/sda1 /mnt/usb
mount: unknown filesystem type 'ntfs-3g'
pi@raspberrypi / $ sudo mount -t ntfs -o uid=pi,gid=pi /dev/sda1 /mnt/usb
mount: special device /dev/sda1 does not exist
pi@raspberrypi / $ sudo mount -t ntfs -o uid=pi,gid=pi /dev/sda /mnt/usb
dmesg | tail or so
[ 0.000000] Booting Linux on physical CPU 0
[ 0.000000] Initializing cgroup subsys cpu
[ 0.000000] Linux version 3.6.11+ (dc4@dc4-arm-01) (gcc version 4.7.2 20120731 (prerelease) (crosstool-NG linaro-1.13.1+bzr2458 - Linaro GCC 2012.08) ) #371 PREEMPT Thu Feb 7 16:31:35 GMT 2013
[ 0.000000] CPU: ARMv6-compatible processor [410fb767] revision 7 (ARMv7), cr=00c5387d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT nonaliasing instruction cache
[ 0.000000] Machine: BCM2708
[ 0.000000] cma: CMA: reserved 16 MiB at 1b000000
[ 0.000000] Memory policy: ECC disabled, Data cache writeback
[ 0.000000] On node 0 totalpages: 114688
[ 0.000000] free_area_init_node: node 0, pgdat c053b834, node_mem_map c05e5000
[ 0.000000] Normal zone: 896 pages used for memmap
[ 0.000000] Normal zone: 0 pages reserved
[ 0.000000] Normal zone: 113792 pages, LIFO batch:31
[ 0.000000] pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768
[ 0.000000] pcpu-alloc: [0] 0
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 113792
[ 0.000000] Kernel command line: dma.dmachans=0x7f35 bcm2708_fb.fbwidth=656 bcm2708_fb.fbheight=416 bcm2708.boardrev=0xe bcm2708.serial=0x517f584e smsc95xx.macaddr=B8:27:EB:7F:58:4E sdhci-bcm2708.emmc_clock_freq=100000000 vc_mem.mem_base=0x1ec00000 vc_mem.mem_size=0x20000000 dwc_otg.lpm_enable=0 console=ttyAMA0,115200 kgdboc=ttyAMA0,115200 console=tty1 root=/dev/mmcblk0p2 rootfstype=ext4 elevator=deadline rootwait
[ 0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.000000] Memory: 448MB = 448MB total
[ 0.000000] Memory: 432264k/432264k available, 26488k reserved, 0K highmem
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
[ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
[ 0.000000] vmalloc : 0xdc800000 - 0xff000000 ( 552 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xdc000000 ( 448 MB)
[ 0.000000] modules : 0xbf000000 - 0xc0000000 ( 16 MB)
[ 0.000000] .text : 0xc0008000 - 0xc04e5470 (4982 kB)
[ 0.000000] .init : 0xc04e6000 - 0xc0506f24 ( 132 kB)
[ 0.000000] .data : 0xc0508000 - 0xc053c060 ( 209 kB)
[ 0.000000] .bss : 0xc053c084 - 0xc05e4738 ( 674 kB)
[ 0.000000] NR_IRQS:330
[ 0.000000] sched_clock: 32 bits at 1000kHz, resolution 1000ns, wraps every 4294967ms
[ 0.000000] Console: colour dummy device 80x30
[ 0.000000] console [tty1] enabled
[ 0.001010] Calibrating delay loop... 464.48 BogoMIPS (lpj=2322432)
[ 0.060062] pid_max: default: 32768 minimum: 301
[ 0.060418] Mount-cache hash table entries: 512
[ 0.061187] Initializing cgroup subsys cpuacct
[ 0.061241] Initializing cgroup subsys devices
[ 0.061275] Initializing cgroup subsys freezer
[ 0.061304] Initializing cgroup subsys blkio
[ 0.061398] CPU: Testing write buffer coherency: ok
[ 0.061734] hw perfevents: enabled with v6 PMU driver, 3 counters available
[ 0.061875] Setting up static identity map for 0x39d3f8 - 0x39d454
[ 0.063374] devtmpfs: initialized
[ 0.074125] NET: Registered protocol family 16
[ 0.080612] DMA: preallocated 4096 KiB pool for atomic coherent allocations
[ 0.081711] bcm2708.uart_clock = 0
[ 0.083077] hw-breakpoint: found 6 breakpoint and 1 watchpoint registers.
[ 0.083130] hw-breakpoint: maximum watchpoint size is 4 bytes.
[ 0.083167] mailbox: Broadcom VideoCore Mailbox driver
[ 0.083259] bcm2708_vcio: mailbox at f200b880
[ 0.083361] bcm_power: Broadcom power driver
[ 0.083399] bcm_power_open() -> 0
[ 0.083423] bcm_power_request(0, 8)
[ 0.584114] bcm_mailbox_read -> 00000080, 0
[ 0.584155] bcm_power_request -> 0
[ 0.584181] Serial: AMBA PL011 UART driver
[ 0.584325] dev:f1: ttyAMA0 at MMIO 0x20201000 (irq = 83) is a PL011 rev3
[ 0.908053] console [ttyAMA0] enabled
[ 0.931542] bio: create slab <bio-0> at 0
[ 0.936416] SCSI subsystem initialized
[ 0.940511] usbcore: registered new interface driver usbfs
[ 0.946092] usbcore: registered new interface driver hub
[ 0.951687] usbcore: registered new device driver usb
[ 0.958027] Switching to clocksource stc
[ 0.962273] FS-Cache: Loaded
[ 0.965413] CacheFiles: Loaded
[ 0.980210] NET: Registered protocol family 2
[ 0.985496] TCP established hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.993235] TCP bind hash table entries: 16384 (order: 4, 65536 bytes)
[ 1.000026] TCP: Hash tables configured (established 16384 bind 16384)
[ 1.006631] TCP: reno registered
[ 1.009883] UDP hash table entries: 256 (order: 0, 4096 bytes)
[ 1.015779] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[ 1.022355] NET: Registered protocol family 1
[ 1.027217] RPC: Registered named UNIX socket transport module.
[ 1.033262] RPC: Registered udp transport module.
[ 1.037985] RPC: Registered tcp transport module.
[ 1.042731] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 1.049842] bcm2708_dma: DMA manager at f2007000
[ 1.054622] bcm2708_gpio: bcm2708_gpio_probe c0515d98
[ 1.060087] vc-mem: phys_addr:0x00000000 mem_base=0x1ec00000 mem_size:0x20000000(512 MiB)
[ 1.069239] audit: initializing netlink socket (disabled)
[ 1.074835] type=2000 audit(0.930:1): initialized
[ 1.198041] VFS: Disk quotas dquot_6.5.2
[ 1.202076] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 1.209141] FS-Cache: Netfs 'nfs' registered for caching
[ 1.214890] NFS: Registering the id_resolver key type
[ 1.220051] Key type id_resolver registered
[ 1.224345] Key type id_legacy registered
[ 1.228705] msgmni has been set to 876
[ 1.234220] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)
[ 1.241936] io scheduler noop registered
[ 1.245982] io scheduler deadline registered (default)
[ 1.251164] io scheduler cfq registered
[ 1.276357] Console: switching to colour frame buffer device 82x26
[ 1.287784] kgdb: Registered I/O driver kgdboc.
[ 1.294964] vc-cma: Videocore CMA driver
[ 1.300767] vc-cma: vc_cma_base = 0x00000000
[ 1.307357] vc-cma: vc_cma_size = 0x00000000 (0 MiB)
[ 1.314554] vc-cma: vc_cma_initial = 0x00000000 (0 MiB)
[ 1.330482] brd: module loaded
[ 1.340173] loop: module loaded
[ 1.345393] vchiq: vchiq_init_state: slot_zero = 0xdb000000, is_master = 0
[ 1.354757] Loading iSCSI transport class v2.0-870.
[ 1.362425] usbcore: registered new interface driver smsc95xx
[ 1.369985] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ 1.582555] Core Release: 2.80a
[ 1.587395] Setting default values for core params
[ 1.593969] Finished setting default values for core params
[ 1.806340] Using Buffer DMA mode
[ 1.811342] Periodic Transfer Interrupt Enhancement - disabled
[ 1.818856] Multiprocessor Interrupt Enhancement - disabled
[ 1.826136] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 1.832199] Dedicated Tx FIFOs mode
[ 1.838334] dwc_otg: Microframe scheduler enabled
[ 1.838735] dwc_otg bcm2708_usb: DWC OTG Controller
[ 1.845457] dwc_otg bcm2708_usb: new USB bus registered, assigned bus number 1
[ 1.854597] dwc_otg bcm2708_usb: irq 32, io mem 0x00000000
[ 1.861844] Init: Port Power? op_state=1
[ 1.867477] Init: Power Port (0)
[ 1.872516] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.881135] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.890219] usb usb1: Product: DWC OTG Controller
[ 1.896788] usb usb1: Manufacturer: Linux 3.6.11+ dwc_otg_hcd
[ 1.904392] usb usb1: SerialNumber: bcm2708_usb
[ 1.911453] hub 1-0:1.0: USB hub found
[ 1.917076] hub 1-0:1.0: 1 port detected
[ 1.923073] dwc_otg: FIQ enabled
[ 1.923091] dwc_otg: NAK holdoff enabled
[ 1.923111] Module dwc_common_port init
[ 1.923328] Initializing USB Mass Storage driver...
[ 1.930134] usbcore: registered new interface driver usb-storage
[ 1.937983] USB Mass Storage support registered.
[ 1.944520] usbcore: registered new interface driver libusual
[ 1.952355] mousedev: PS/2 mouse device common for all mice
[ 1.960390] bcm2835-cpufreq: min=700000 max=700000 cur=700000
[ 1.966257] bcm2835-cpufreq: switching to governor powersavebcm2835-cpufreq: switching to governor powersave
[ 1.979676] cpuidle: using governor ladder
[ 1.987431] cpuidle: using governor menu
[ 1.993170] sdhci: Secure Digital Host Controller Interface driver
[ 2.001121] sdhci: Copyright(c) Pierre Ossman
[ 2.007331] sdhci: Enable low-latency mode
[ 2.052358] mmc0: SDHCI controller on BCM2708_Arasan [platform] using platform's DMA
[ 2.063929] mmc0: BCM2708 SDHC host at 0x20300000 DMA 2 IRQ 77
[ 2.073857] sdhci-pltfm: SDHCI platform and OF driver helper
[ 2.087176] usbcore: registered new interface driver usbhid
[ 2.094779] usbhid: USB HID core driver
[ 2.105276] TCP: cubic registered
[ 2.112635] Initializing XFRM netlink socket
[ 2.120972] NET: Registered protocol family 17
[ 2.127511] Indeed it is in host mode hprt0 = 00021501
[ 2.138039] Key type dns_resolver registered
[ 2.152511] VFP support v0.3: implementor 41 architecture 1 part 20 variant b rev 5
[ 2.174660] mmc0: could read SD Status register (SSR) at the 2th attempt
[ 2.184102] registered taskstats version 1
[ 2.202701] Waiting for root device /dev/mmcblk0p2...
[ 2.213660] mmc0: new high speed SDHC card at address b368
[ 2.232371] mmcblk0: mmc0:b368 SDC 15.0 GiB
[ 2.253601] mmcblk0: p1 p2
[ 2.382206] usb 1-1: new high-speed USB device number 2 using dwc_otg
[ 2.390903] Indeed it is in host mode hprt0 = 00001101
[ 2.428858] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 2.452225] VFS: Mounted root (ext4 filesystem) on device 179:2.
[ 2.481440] devtmpfs: mounted
[ 2.492560] Freeing init memory: 128K
[ 2.632502] usb 1-1: New USB device found, idVendor=0424, idProduct=9512
[ 2.641392] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 2.651382] hub 1-1:1.0: USB hub found
[ 2.658245] hub 1-1:1.0: 3 ports detected
[ 2.942380] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
[ 3.062876] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
[ 3.071890] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 3.097067] smsc95xx v1.0.4
[ 3.177216] smsc95xx 1-1.1:1.0: eth0: register 'smsc95xx' at usb-bcm2708_usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:7f:58:4e
[ 3.302409] usb 1-1.2: new high-speed USB device number 4 using dwc_otg
[ 3.424485] usb 1-1.2: New USB device found, idVendor=7392, idProduct=7811
[ 3.437302] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 3.446963] usb 1-1.2: Product: 802.11n WLAN Adapter
[ 3.454151] usb 1-1.2: Manufacturer: Realtek
[ 3.460442] usb 1-1.2: SerialNumber: 00e04c000001
[ 3.994249] udevd[142]: starting version 175
[ 5.173798] Registered led device: led0
[ 6.497588] usbcore: registered new interface driver rtl8192cu
[ 9.751260] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[ 10.200608] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[ 10.949552] bcm2835 ALSA card created!
[ 10.960987] bcm2835 ALSA chip created!
[ 10.975049] bcm2835 ALSA chip created!
[ 10.986560] bcm2835 ALSA chip created!
[ 10.995024] bcm2835 ALSA chip created!
[ 11.003768] bcm2835 ALSA chip created!
[ 11.013213] bcm2835 ALSA chip created!
[ 11.021737] bcm2835 ALSA chip created!
[ 24.161142] Adding 102396k swap on /var/swap. Priority:-1 extents:1 across:102396k SS
[ 1730.560325] usb 1-1.3: new high-speed USB device number 5 using dwc_otg
[ 1731.132742] usb 1-1.3: New USB device found, idVendor=058f, idProduct=6387
[ 1731.132773] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 1731.132790] usb 1-1.3: Product: Mass Storage
[ 1731.132804] usb 1-1.3: Manufacturer: Generic
[ 1731.132817] usb 1-1.3: SerialNumber: 967AB9B4
[ 1731.150278] scsi0 : usb-storage 1-1.3:1.0
[ 1732.153568] scsi 0:0:0:0: Direct-Access Generic Flash Disk 8.07 PQ: 0 ANSI: 4
[ 1732.156096] sd 0:0:0:0: [sda] 125304832 512-byte logical blocks: (64.1 GB/59.7 GiB)
[ 1732.157244] sd 0:0:0:0: [sda] Write Protect is off
[ 1732.157281] sd 0:0:0:0: [sda] Mode Sense: 23 00 00 00
[ 1732.158491] sd 0:0:0:0: [sda] Write cache: disabled, read cache: enabled, doesn't support DPO or FUA
[ 1732.950150] sda: sda2
[ 1732.955450] sd 0:0:0:0: [sda] Attached SCSI removable disk
[ 1978.171336] usb 1-1.3: USB disconnect, device number 5
[ 2096.436899] usb 1-1.3: new high-speed USB device number 6 using dwc_otg
[ 2097.009325] usb 1-1.3: New USB device found, idVendor=058f, idProduct=6387
[ 2097.009357] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 2097.009373] usb 1-1.3: Product: Mass Storage
[ 2097.009387] usb 1-1.3: Manufacturer: Generic
[ 2097.009400] usb 1-1.3: SerialNumber: 967AB9B4
[ 2097.026829] scsi1 : usb-storage 1-1.3:1.0
[ 2098.030141] scsi 1:0:0:0: Direct-Access Generic Flash Disk 8.07 PQ: 0 ANSI: 4
[ 2098.032677] sd 1:0:0:0: [sda] 125304832 512-byte logical blocks: (64.1 GB/59.7 GiB)
[ 2098.033857] sd 1:0:0:0: [sda] Write Protect is off
[ 2098.033894] sd 1:0:0:0: [sda] Mode Sense: 23 00 00 00
[ 2098.035088] sd 1:0:0:0: [sda] Write cache: disabled, read cache: enabled, doesn't support DPO or FUA
[ 2098.824853] sda: sda2
[ 2098.830039] sd 1:0:0:0: [sda] Attached SCSI removable disk
[ 2422.596112] EXT4-fs (sda): VFS: Can't find ext4 filesystem
[ 2422.603491] EXT4-fs (sda): VFS: Can't find ext4 filesystem
[ 2422.613515] EXT4-fs (sda): VFS: Can't find ext4 filesystem
[ 2422.623500] FAT-fs (sda): invalid media value (0xb9)
[ 2422.623526] FAT-fs (sda): Can't find a valid FAT filesystem
[ 2422.633751] FAT-fs (sda): invalid media value (0xb9)
[ 2648.288598] NTFS driver 2.1.30 [Flags: R/W MODULE].
[ 2654.856943] NTFS-fs warning (device sda): is_boot_sector_ntfs(): Invalid boot sector checksum.
[ 2654.856978] NTFS-fs error (device sda): read_ntfs_boot_sector(): Primary boot sector is invalid.
[ 2654.856996] NTFS-fs error (device sda): read_ntfs_boot_sector(): Mount option errors=recover not used. Aborting without trying to recover.
[ 2654.857010] NTFS-fs error (device sda): ntfs_fill_super(): Not an NTFS volume.
[ 2719.392040] usb 1-1.3: USB disconnect, device number 6
pi@raspberrypi / $ sudo mount -t msdos -o uid=pi,gid=pi /dev/sda /mnt/usb
dmesg | tail or so
dmesg | tail or so
pi@raspberrypi / $ mount -t vfat -o umask=000 /dev/sda /mnt/usb
mount: only root can do that
pi@raspberrypi / $ sudo mount -t vfat -o umask=000 /dev/sda /mnt/usb
dmesg | tail or so
pi@raspberrypi / $ sudo mount -t msdos -o umask=000 /dev/sda /mnt/usb
dmesg | tail or so
[ 2982.918596] sda: sda2
[ 2982.923026] sd 2:0:0:0: [sda] Attached SCSI removable disk
[ 3144.126778] FAT-fs (sda): invalid media value (0xb9)
[ 3144.126804] FAT-fs (sda): Can't find a valid FAT filesystem
[ 3157.446962] FAT-fs (sda): invalid media value (0xb9)
[ 3157.446988] FAT-fs (sda): Can't find a valid FAT filesystem
[ 3315.877355] FAT-fs (sda): invalid media value (0xb9)
[ 3315.877381] FAT-fs (sda): Can't find a valid FAT filesystem
[ 3327.096008] FAT-fs (sda): invalid media value (0xb9)
[ 3327.096033] FAT-fs (sda): Can't find a valid FAT filesystem
pi@raspberrypi / $ sudo mount -t fat-fs -o umask=000 /dev/sda /mnt/usb
mount: unknown filesystem type 'fat-fs'
mount: maybe you meant 'vfat'?
dmesg | tail or so
pi@raspberrypi / $
