bullen
Lightweight Java HTTP Async Server
Sun Apr 28, 2013 2:58 pm
Try this server: rupy
It's faster and uses less memory, also it has HTTP hot-deploy that is seamless for uninterrupted multiuser development and unnoticeable live deployments = no downtime.
It uses NIO, so it scales and can do real time comet long-poll chat and streaming!
Finally when you finished your app there's really cheap rpi cluster hosting: host.rupy.se
https://github.com/tinspin/rupy - A tiny Java async HTTP application server.
bullen
Re: Lightweight Java HTTP app server
Sun Jun 09, 2013 10:18 pm
Just released version 1.0
bullen
Tue Nov 25, 2014 10:26 am
Now you can build your own HTTP server cluster on many RPi's with this. It also has a cluster NoSQL database!
We have a cheap PaaS ready for deployment, but you can easily build your own too!
auron89
Tue Nov 25, 2014 2:00 pm
how can I install on raspberry and make a deploy?
bullen
Tue Dec 23, 2014 7:17 pm
Tutorial, if you have a problem I can answer your specific question.
clicky
Thu Dec 25, 2014 1:08 pm
I was a bit sceptical but it really seems very light and with small footprint. I'll try to use it for my next project (instead of built in server).
bullen
Sun Feb 08, 2015 10:24 am
Did a benchmark of the rupy cometstream and 6x it is. Almost the same performance as an old atom or a new NUC, but per watt it dominates!
Comet Stream
6.500 messages per joule!!! That might just be some kind of world record! ;)
Edit: I'm just blown away by this figure. The next best per watt is the Intel NUC, which costs 500$ (including memory and SSD) compared to the RPi2 which costs 45$ including SD card. So the RPi2 costs 1000% less to buy and 700% less to power for 70% of the performance. I was about to retire my RPi plans for an all Intel setup, but now I will use one passively cooled Intel NUC as loadbalancer for a cluster of RPi2 per node.
bullen
Sat Feb 14, 2015 10:52 am
Now I have added so that you can hot-deploy to your pi with rupy on projects that use a COM port integration to increase development speed of all your Java hardware projects.
Install RXTX on your pi:
sudo apt-get install librxtx-java
Example code:
public class Router extends Daemon.Com {
	static Daemon daemon;
	static Router router;
	private static InputStream in;
	private static OutputStream out;
	public Router(String tty) {
		try {
			System.setProperty("gnu.io.rxtx.SerialPorts", tty);
			CommPortIdentifier id = CommPortIdentifier.getPortIdentifier(tty);
			if(id.isCurrentlyOwned()) {
				System.out.println("Error: Port is currently in use.");
			} else {
				CommPort port = id.open("COM", 1000);
				if(port instanceof SerialPort) {
					SerialPort serial = (SerialPort) port;
					serial.setSerialPortParams(9600,
							SerialPort.DATABITS_8,
							SerialPort.STOPBITS_1,
							SerialPort.PARITY_NONE);
					in = serial.getInputStream();
					out = serial.getOutputStream();
					Thread thread = new Thread(new Reader(in));
					thread.start();
				else {
					System.out.println("Error: Only serial ports are handled by this example.");
		catch(Exception e) {
			e.printStackTrace();
	public static class Send extends Service {
		Receiver rec;
		public String path() { return "/"; }
		public void create(Daemon daemon) {
			rec = new Receiver(daemon);
			daemon.com().set(rec);
		public void filter(Event event) throws Event, Exception {
			System.out.println(event.query().header());
			if(event.query().method() == Query.POST) {
				event.query().parse();
				String message = event.query().string("message");
				event.daemon().com().write(message.getBytes());
	public static class Receiver implements Daemon.Listen {
		StringBuilder builder = new StringBuilder();
		Daemon daemon;
		public Receiver(Daemon daemon) {
			this.daemon = daemon;
		public void read(byte[] data, int length) throws Exception {
			String in = new String(data, 0, length);
			System.out.println(in);
	public void write(byte[] data) throws IOException {
		out.write(data);
	public static class Reader implements Runnable {
		InputStream in;
		public Reader(InputStream in) {
			this.in = in;
		public void run() {
			byte[] data = new byte[1024];
			int length = -1;
			try {
				while((length = this.in.read(data)) > -1) {
					try {
						router.listen.read(data, length);
			} catch(Exception e) {
	public static void main(String[] args) {
		daemon = Daemon.init(args);
		router = new Router("/dev/ttyAMA0");
		daemon.set(router);
		daemon.start();
Then you need to add the hot-deployed jar to the classpath and run Router instead of Daemon:
java -Djava.library.path=/usr/lib/jni -classpath /usr/share/java/RXTXcomm.jar:http.jar:app/your-app.jar Router -pass XXXXXX
bullen
Re: Lightweight Java HTTP Async Server
Fri May 29, 2015 8:03 am
Now the RPi 2 cluster is online on host.rupy.se:
http://monitor.rupy.se
Here you can insert database entries across the entire cluster: http://root.rupy.se
bullen
Sun Mar 27, 2016 6:50 pm
Now I have built a multiplayer engine on top of this:
https://github.com/tinspin/fuse
Has both Javascript HTML5 and Unity C# clients!
Also I built a forum module:
http://talk.binarytask.com
Return to “Java”
