Hi Guys, here's to my first attempts with a pi... I tried to mount my externally powerd 2TB WD hdd, but the raspberry won't let me do that. it gives an error every time that says:
Error mounting: mount: unknown filesystem type 'exfat'
I tried several googlesearches for exfat support, but none of them seem to work.
Did anyone of you expierence this? And were you able to fix the issue?
Cheers,
Re: ExFat disk wont mount
exFat is a Microsoft file system, for which they don't release the specification and hold a number of Patents (pending). It is not supported by the Linux Kernel, although there seems to be a work round (see Wikipedia - exfat) but I know very little about it. You could try adding new partitions on the HDD and formatting those with a more friendly file system that does work across different operating systems. exFat seems to be designed for low capacity flash drives
Please do the following to mount exFAT disk -
sudo apt-get update
sudo apt-get install exfat-fuse exfat-utils
sudo mkdir /media/exfat
sudo mount -t auto /dev/sda1 /media/USBHDD1
In the above command sda1 is the name of the exFAT disk. You can checkout the names of various disks attached to your system by running sudo fdisk -l
Now your exFAT disk will be available at /media
sudo apt-get update
You were right.
Now easily solvable by loading the utils for this FS:
Now mount as normal. Good luck!
eastpole
https://en.wikipedia.org/wiki/ExFATexFAT was proprietary until 28 August 2019, when Microsoft published its specification.
sudo apt install exfat-fuse exfat-utils
eastpole
