AlexanderMan
Re: GPIO Permission Denied
Tue Apr 24, 2012 2:56 pm
Hi Raspberry Pi Forum!
I've managed to get one in the first batch of raspberry pi's and have been enjoying making python scripts. I've also been a bit adventurous trying to interact with the GPIO that the pi offers but I'm failing to talk to it.
I attempted to do a simple bash call 'echo "1" > /sys/class/gpio/export' (following the example at http://elinux.org/Rpi_Low-leve....._script.29) to set up GPIO1, however I receive an error message "/sys/class/gpio/export: Permission denied".
Is there a was to enable permission for GPIO? Thanks in advance
RaTTuS
Contact: Twitter YouTube
Tue Apr 24, 2012 3:07 pm
run elevated
i.e.
sudo echo "1" > /sys/class/gpio/export'
or
sudo ./bashscript
Covfefe
Gert van Loo
Tue Apr 24, 2012 3:33 pm
I found that you can not "sudo echo ...."
I had to start a shell using sudo and then use "echo ...."
So your first example won't work.
RaTTuS
Tue Apr 24, 2012 3:50 pm
ah
sudo the script then
in the script have
#!/bin/bash
as the 1st line
and change to permissions to be 777
chmod 777 script
then you can
sudo ./script
otherise it would have to be
sudo sh ./script
Covfefe
jojopi
Tue Apr 24, 2012 4:13 pm
You can sudo echo, but you can not sudo ">".  That is because redirections are set up by your shell before sudo is even started.  Common workarounds are:echo "1" |sudo tee /sys/class/gpio/export
sudo sh -c 'echo "1" > /sys/class/gpio/export'
The first has the slight disadvantage of also printing to the terminal.  The second quickly gets very hairy if the command needs multiple types of quotes.
You can also put the echo in a script and sudo the whole script.  But arguably the best thing is to try to change the permissions so that you do not need to be superuser to access gpio:sudo chgrp -R pi /sys/class/gpio
sudo chmod -R g+rw /sys/class/gpio
(I am not able to test this.)
(Please never "chmod 777" anything.  Those are literally never the right permissions for any file or directory on a correctly-configured system.)
Gert van Loo
Tue Apr 24, 2012 4:49 pm
Thank you. Now I understand why you can't do "sudo ...>" which make it easier to remember and apply to other situations.
(With hindsight: yes it is logical that the > is not part of the sudo especially if you know how tasks are started in Unix.)
AlexanderMan
Tue Apr 24, 2012 5:09 pm
Thanks for the discussion, I've managed to find a topic posted about a week ago discussing how to read/write to GPIOs (http://www.raspberrypi.org/for.....ke-im-five) and was able to read a button press (hello world for digital input) successfully.
naicheben
Tue Apr 24, 2012 5:14 pm
I don't realy understand the userpermissions jet. But wouldn't you add user pi to the group witch has permission to the GPIO? Of course not to root, but maybe add a group "gpio", then "chown -R gpio:gpio /sys/class/gpio"and add pi and later other users to the group so they can access the GPIOs?
croston
Tue Apr 24, 2012 5:23 pm
I"ve started looking into the possibility of creating a GPIO group that a user could be added to. I have never played with udev before but this looks like it controls this type of thing for hardware permissions. Are there any udev experts out there that could give me some pointers?
alias_neo
Tue Aug 28, 2012 8:49 pm
croston wrote:I"ve started looking into the possibility of creating a GPIO group that a user could be added to. I have never played with udev before but this looks like it controls this type of thing for hardware permissions. Are there any udev experts out there that could give me some pointers?
Doesn't look like anyone has replied here in a while, but I'v been playing with this for a little project I just started and basically, you can great a group called gpio, add the user to it, export the gpio etc as follows:
sudo groupadd gpio
sudo usermod -aG gpio <myusername>
su <myusername>
sudo chgrp gpio /sys/class/gpio/export
sudo chgrp gpio /sys/class/gpio/unexport
sudo chmod 775 /sys/class/gpio/export
sudo chmod 775 /sys/class/gpio/unexport
This gives your user the ability to export and un-export.
Once you export the pins you can chgrp and chmod them as well (don't forget their contents) and use them as usual.
echo "18" > /sys/class/gpio/export
chgrp -HR /sys/class/gpio/gpio18
chmod -R 775 /sys/class/gpio/gpio18
Now your user has access to the first GPIO pin 18.
echo "out" > /sys/class/gpio/gpio18/direction
echo "1" > /sys/class/gpio/gpio18/value
This turns it on.
echo "0" > /sys/class/gpio18/value
This turns it off
echo "18" > /sys/class/gpio/unexport
and finally this un-exports it.
https://2byt.es - Just my two bytes - RPi - Android - Arduino - Blog
