pirandr
Xrandr panning in Raspbian
Mon Aug 05, 2013 5:11 pm
I'm running Raspbian and xrandr always gives me a single mode line. While I can change what resolution this line contains by altering config.txt, I can't get mutliple lines at the same time (so I can change resolution without reboot). Is there any way to do this?
What I actually want to do is get panning/virtual resolution working (a low resolution screen with a larger "virtual" desktop). This is a standard feature in X and on other machines, I'd just run something like
xrandr --fb 1920x1080 --mode 800x600 --panning 1920x1080
to get a 800x600 resolution with a 1920x1080 sized "virtual" desktop.
I just want to get something like this running. Of course, after that, it'd be nice if I could also change resolution without a reboot.
Thanks in advance for any help.
pirandr
Re: Xrandr panning in Raspbian
Tue Aug 06, 2013 5:20 pm
The closest thing I've found is this stack overflow question
http://unix.stackexchange.com/questions ... t-cannot-f
but unfortunately, this lead me to an error with some magic numbers I can't decipher.
pi@raspberrypi ~ $ xrandr
xrandr: Failed to get size of gamma for output default
Screen 0: minimum 720 x 480, current 720 x 480, maximum 720 x 480
default connected 720x480+0+0 0mm x 0mm
   720x480         0.0*
pi@raspberrypi ~ $ sudo xrandr --fb 1920x1080 --output default --mode 720x480 --panning 1920x1080
xrandr: screen cannot be larger than 720x480 (desired size 1920x1080)
pi@raspberrypi ~ $ gtf 1920 1200 60
  # 1920x1200 @ 60.00 Hz (GTF) hsync: 74.52 kHz; pclk: 193.16 MHz
  Modeline "1920x1200_60.00"  193.16  1920 2048 2256 2592  1200 1201 1204 1242  -HSync +Vsync
   720x480         0.0*
pi@raspberrypi ~ $ xrandr --newmode "1920x1200_60.00"  193.16  1920 2048 2256 2592  1200 1201 1204 1242  -HSync +Vsync
pi@raspberrypi ~ $ xrandr --addmode default "1920x1200_60.00"
   720x480         0.0*
   1920x1200_60.00   60.0
Unlike the Stackexchange question, I was able to add the modeline because my monitor does support 1920x1200 @ 60Hz. But then I got this error.
pi@raspberrypi ~ $ sudo xrandr --fb 1920x1200 --output default --mode 720x480 --panning 1920x1200
X Error of failed request:  BadRRCrtc (invalid Crtc parameter)
  Major opcode of failed request:  149 (RANDR)
  Minor opcode of failed request:  29 (RRSetPanning)
  Crtc id in failed request: 0x62
  Serial number of failed request:  22
  Current serial number in output stream:  22
I'm not even trying to use the new modeline (except into "tricking" xrandr into accepting 1920x1200 as my virtual resolution)!
So any and all ideas are still very welcome.
pirandr
Sun Aug 18, 2013 12:33 pm
Adventure in Xrandr land continues!
Some output removed for brevity.
What could BadRRCrtc (invalid Crtc parameter) mean? Which parameter is wrong? Looks like there's no choice. I have to dig deeper.
$ apt-get source x11-xserver-utils
$ cd x11-xserver-utils-7.7~3/xrandr/
$ mkdir build
$ cd build
$ ../configure
** Loads of missing packages, as expected. **
$ apt-get install xrandr xrender x11 xproto libxrandr-dev libxrender-dev
** Some finger twiddling later. **
$ ../configure
** Seems fine this time. **
$ make
$ ./xrandr
./xrandr: Failed to get size of gamma for output default
Screen 0: minimum 640 x 480, current 640 x 480, maximum 1024 x 800
default connected 640x480+0+0 0mm x 0mm
   640x480        60.0*
   1024x800_60.00   60.0
Now that it works, lets try one of the command we want to run.
$ ./xrandr --output default --mode 640x480 --panning 1024x800+0+0/640x480+0+0 --verbose
  Crtc id in failed request: 0x63
$ vi ../xrandr.c
** Add some printf statement here and there near the panning code. **
$ make
A few hours of editing and running later, it looks like the error happens on the line
                s = XRRSetPanning (dpy, res, crtc->crtc.xid, crtc->panning_info);
In fact, it exists with status code 1 and doesn't run any lines after this. But XRRSetPanning is not defined in xrandr.c (or anything within x11-xserver-utils-7.7~3). So, after some searching
$ cd
$ apt-get source libxrandr
$ cd libxrandr-1.3.2
$ mkdir build
$ cd build
$ ../configure && make
** After installing some missing packages. **
$ make
** I'm not sure how to make it use the new library. I guess I'll just install it, which is probably a bad idea. **
$ sudo make install
** It says the new library was installed in /usr/local/lib instead of /usr/lib. How do I make xrandr.c use that that new library? **
~/x11-xserver-utils-7.7~3/xrandr/build $ export LD_LIBRARY_PATH=/usr/local/lib
~/x11-xserver-utils-7.7~3/xrandr/build $ ldd xrandr
        libXrandr.so.2 => /usr/local/lib/libXrandr.so.2 (0xb6f44000)
Running this version does give the print statement I added to XrrCrtc.c (which is where XRRSetPanning is defined) but rebuilding every time is getting tiresome. Time to use something better than printf statement debugging.
$ gdb ./xrandr
** Luckily, the -g flag was included by default in the rebuilt library so extra information (symbols) is available to gdb. **
(gdb) r --output default --mode 640x480 --panning 1024x800+0+0/640x480+0+0 --verbose
** Same BadRRCrtc error. **
(gdb) break 1444
** After some examining and stepping. **
(gdb) c
And then the gdb just froze there. And the same thing happened many times (xrandr had to be killed via ssh).
Time passes.
It turns out that its a bad idea to send error messages (and console) to a display you are in the process of debugging. Now, instead I will ssh into the machine (while the xserver is on), export DISPLAY=:0.0 and then run gdb from the ssh session.
No more freezing. But eventually, I discover that the problem is contained in one line
    if (!_XReply (dpy, (xReply *) &rep, 0, xFalse))
_XReply looks like something pretty generic that is just passing along our request to ultimately call a panning function. But _XReply is also not defined anywhere in libxrandr.
It looks like I'll need the entire X11 library because some googling shows _XReply is defined in xcb_io.c.
$ apt-get source libx11
But I don't want to rebuild the entire X11 library just to add the debug flag -g everywhere. In the meantime, my drunken journey on the internets brought me here.
http://www.x.org/wiki/Development/Docum ... Debugging/
There are specific packages available with those flags set.
$ apt-get install libx11-6-dbg libx11-xcb1-dbg
All of this could have been done from the very start, of course.
Now I can step through the _XReply function. Although I'm starting to suspect all of this is just client-side work and I should really be looking that what the server is doing instead.
karsenault
Sat Jan 11, 2014 7:28 pm
Did you ever get this fixed? I get the same CRTC error when trying to change panning. I also have a tiny (4.3") screen that I obviously need to have bigger as I can't even see "Ok" in some windows.
STrRedWolf
Sat Jan 16, 2021 5:27 pm
7 years later, and it's working!
First, run xrandr to see what you have:
tygris@kitbash:~$ xrandr
Screen 0: minimum 320 x 200, current 800 x 480, maximum 7680 x 7680
DSI-1 connected primary 800x480+0+0 (normal left inverted right x axis y axis) 0mm x 0mm
   FIXED_MODE    60.05*+
Ahh, the output is named "DSI1". Thus, on that 7" offical screen:
xrandr --output DSI-1 --panning 1280x720
And it works! I now have a virtual screen that pans around.
