sandraqu
How to refresh Chromium web page from command line?
Mon Aug 12, 2013 8:01 pm
We have setup a web page that autoloads in Chromium kiosk mode when the raspberry is turned on. We now want to refresh the webpage from SSH.
I have the following script
WID=$(xdotool search --onlyvisible --class chromium|head -1)
xdotool windowactivate ${WID}
xdotool key ctrl+F5
running this script through SSH
ssh -X 192.x.x.x -l pi 'echo raspberry|./scripts/refresh.sh'
produces this err
Error: Can't open display: (null)
Failed creating new xdo instance
these are my refs
http://www.codepug.com/wiki/raspberry-pi-browser-kiosk
http://peter-hoffmann.com/2010/refresh- ... otool.html
http://icyrock.com/blog/tag/xdotool/ -- got getwindowactive command not found err. xdotool version 2.20100701.2961
smithg400
Re: How to refresh Chromium web page from command line?
Mon Aug 12, 2013 9:17 pm
When you SSH into the PI the DISPLAY environment isn't set. You may get away with simply adding the line
export DISPLAY=":0"
to the start of your script, though you are likely to also have to use xauth to authenticate the remote session.
sandraqu
Tue Aug 13, 2013 5:50 pm
Thank you. That worked. I also did the xauth aunthenticaction
ref
http://raspberrypi.stackexchange.com/qu ... entication
wanderer
Mon Dec 02, 2013 6:02 pm
In my case I needed to set the display variable on my crontab command:
*/5 * * * * DISPLAY=:0 /home/pi/scripts/refresh.sh # refresh webpage every 5 minutes
Make sure to create crontab when logged in as kiosk user (not root!) via:
crontab -e
arti0504
Wed Apr 23, 2014 6:38 pm
Could you write once again all script for refresh Chromium web page?
