Joseph_f2
Making the windows key open the start menu?
Mon Sep 16, 2013 3:29 pm
Joe Schmoe
Re: Making the windows key open the start menu?
Mon Sep 16, 2013 4:05 pm
Joseph_f2 wrote:Making the windows key open the start menu?
It works for me. I think it has worked ever since Windows 98.
(I'm running XP here)
Joseph_f2
Tue Sep 17, 2013 4:11 pm
it's for raspberry pi not for windows.
dave j
Tue Sep 17, 2013 5:23 pm
LXDE treats the Windows key as a modifier, like Ctrl or Alt, and uses it for some existing shortcuts so it's not possible to detect when just that key has been pressed. It is possible to detect the Menu key on it's own and I've mapped that to open the 'Start' menu as a reasonable alternative.
Edit the file /home/<username>/.config/openbox/ldxe-rc.xml
In there you'll find a section with lots of <keybind> tags, add the following:
    <keybind key="Menu">
      <action name="Execute">
        <command>lxpanelctl menu</command>
      </action>
    </keybind>
You could use "W-M" instead of "Menu" above if you preferred Windows+M to open the 'Start' menu.
To activate the changes restart your desktop session or type openbox --reconfigure into a command line.
I've also added some other key bindings such as Windows+B to open a browser, Windows+C to bring up a command line/terminal window, etc., which is handy for frequently used apps.
rholyoak
Mon Apr 07, 2014 5:41 pm
There is a typo in the filename, it should be: /home/<username>/.config/openbox/lxde-rc.xml
