Peterau
[Kali Linux] HDMI problem
Mon Sep 23, 2013 1:01 am
Hi everyone, I installed the kali Linux on raspberry pi recently.
But I got a problem after installed. When I connect raspberry pi to 27" monitor and start kali , the display resolution only have 1824x984.
It is no /boot/config.txt in kali Linux. So how can I fix it to 1920x1080 display resolution?
Plz!!
W. H. Heydt
Re: Kali Linux for raspberry pi hdmi problem
Mon Sep 23, 2013 1:59 am
Have you adjusted the overscan parameters in config.txt? Such as turning overscan off?
Peterau
Mon Sep 23, 2013 2:16 am
W. H. Heydt wrote:Have you adjusted the overscan parameters in config.txt? Such as turning overscan off?
I forget to say that it is no config.txt on Kali Linux, and i have also tried to add the config.txt file in /boot/ directly, but still not work...any idea, bro?
cyrano
Re: [Kali Linux] HDMI problem
Mon Sep 23, 2013 10:38 am
Have you tried the following:
1. Click on Applications --> System Tools --> Preferences --> System Settings
2. Click on Display
3. Click Drop down box, next to Resolution to adjust resolution of the monitor
4. Click on Apply to take effect
I have a similar strange problem with Kali and the Pi. When I install a new SD card with Kali, I have a black screen. No HDMI output, until I put the card in an older Pi (256 MB, no fuse). When I return the card to another (512 MB Pi), it just works. And keeps working. Could be my wonky Beetronics screen, tho...
Peterau
Mon Sep 23, 2013 11:47 am
cyrano wrote:Have you tried the following:
2. Click on Display
thanks bro, I have tried your suggest. But it is only one resolution in Display of setting (1824x984), how can I change it?
Oakham
Mon Sep 23, 2013 12:52 pm
As it is distro which many people here may not be aware of, did you ask in the Kali Forums ?
http://forums.kali.org
Searching is easy, most questions have been asked before !
hamedtaha
Tue Mar 28, 2017 9:57 pm
Hello
here is how I fixed the Overscan option on kali Linux
:arrow: https://www.youtube.com/watch?v=LvLoS0H ... EihXKmkC52
kxj99
Wed Sep 11, 2019 9:24 pm
in config.txt
uncomment
disable_overscan=1
that's it.
