hal8000
Why is the /boot partition a FAT filesystem?
Thu Oct 17, 2013 7:39 pm
Why on an embedded linux system is the /boot partition a FAT filesystem ?
I can only think this is for windows users so that /boot/config.txt may be
edited more easily.
Apart from fragmentation, FAT filesystems are weak and easily corrupted
if the partition is not cleanly unmounted, or power supply disconnects
suddenly.
Joe Schmoe
Re: Why is the /boot partition a FAT filesystem?
Thu Oct 17, 2013 7:40 pm
FAT is the only fs understood by the SOC's bootloader.
I.e., it has to be thus.
duberry
Location: standing on a planet that's evolving. And revolving at nine hundred miles an hour
Thu Oct 17, 2013 8:51 pm
afaik
problems may occur in the conditions you describe only if the fs is being modified somehow
lend me your arms, fast as thunderbolts, for a pillow on my journey.
If the environment was a bank, would it be too big to fail
so long; and thanks for all the pi
DavidS
Fri Oct 18, 2013 1:54 am
hal8000 wrote:Why on an embedded linux system is the /boot partition a FAT filesystem ?
edited more easily.
Unfortunately the FAT file system is very universaly supported. The SoCs built in loader only knows how to read from FAT, so it must at least load its firmware from FAT.
suddenly.
There is not much concern because: The only time that anything on the FAT partition is accessed in normal operation is to load the firmware, read the config.txt, and load the OS into SDRAM. These are read only operations (even in Linux).
The only write operations are: Modifying the config.txt, Updating the OS kernel or ROM image, or updating the firmware.
In Linux loading the OS means loading the kernel image into RAM at 0x8000, loading the Intrid RAM image into RAM at a known location, and then pass control to the kernel.
In RISC OS it means loading the RISC OS ROM image into RAM at 0x8000 and passing control to there. The RISC OS ROM will then relocate it self.
In other OSes the initial process is the same.
While Linux is the most used OS on the RPi it is not the only one, RISC OS is also quite popular, and there are others. And FAT is the only FS that all of the main OSes for the RPi natively support.
Do remember that at this time for non n*x OSes at this time on the RPi there is a native version of AROS, we have Plan9, as well as QNX (simi-n*x), and of cource RISC OS the original ARM based OS. So at this point if there were to be a change to the core loader (not possible as it is in ROM on the SoC) we would have to write drivers for many OSes.
More than 95% of posts made from RISC OS on RPi 1B/1B+ computers.
BluDragon
Fri Oct 18, 2013 7:53 am
DavidS wrote:we have Plan9...
what happened to the plans one through eight? ;)
"Whenever a separation is made between liberty and justice, neither, in my opinion, is safe." - Edmund Burke
"Men make counterfeit money; in many more cases, money makes counterfeit men." - Sydney J. Harris
Burngate
Fri Oct 18, 2013 9:33 am
DavidS wrote:... The only time that anything on the FAT partition is accessed in normal operation is to load the firmware, read the config.txt, and load the OS into SDRAM. These are read only operations (even in Linux).
...In RISC OS ...
To be pedantic, in RISC OS, the ROM image (kernel) is rewritten at shut-down.
But if you pull the power without shutting down, nothing in the FAT partition is rewritten
duberry
Fri Oct 18, 2013 9:52 am
Burngate wrote:To be pedantic, in RISC OS, the ROM image (kernel) is rewritten at shut-down.
realy ?!. i did not know ,..
any idea
why ROM image is rewritten
i would guess the R and O in ROM is Read-only , so it is not expected to change ..
Burngate
Fri Oct 18, 2013 4:52 pm
I'm no guru, but I believe it's like this.
In the original RISC OS computers - Archimedes etc. - there was a ROM for the OS and a CMOS RAM/clock chip to store some options. (Was that also true of the 8-bit BBC micro? I can't remember!)
On boot-up, the ROM resided at the bottom of memory, to provide the reset vector at 0x00000000, and then shoved up to the top by the MMU.
The CMOS RAM was then read, and at least one bit was written as a clean/dirty shutdown flag - and cleared on a clean shutdown
Obviously the Pi has neither, but the ROM is emulated by the kernel image, so a part of that is used to emulate the CMOS RAM. And to write the clean/dirty flag, the kernel has to be written
Fri Oct 18, 2013 6:53 pm
edited more easily.
suddenly.
A point that hasn't been mentioned, but the Raspi isn't really designed as an embedded Linux system.
Note that the boot partition is rarely written to - generally only when you want to make a config change.
W. H. Heydt
Fri Oct 18, 2013 10:50 pm
They weren't from outer space.
LemmeFatale
Sat Oct 19, 2013 12:20 pm
And seven ate nine. :P
Anyway, just wondering, since nobody else has mentioned this in relation to the claim about FAT filesystems being easily corrupted: Is my experience of FAT filesystems used in conjunction with SD Cards on Linux systems like the Raspberry Pi the exact opposite of everyone else's? I've found them to be considerably more hardy than ext ones, much more tolerant of the power suddenly being cut, and usually vastly easier to fix if something does befall them, too. (I use Linux exclusively, and have traditionally had nothing but problems with ext filesystems on SD Cards.)
Classic - Raspberry Pi Model B (512MB) with Motorola Atrix Lapdock
Lemcon-One - Raspberry Pi Model B (256MB) PiMAME TV-Box
Joe Schmoe
Sat Oct 19, 2013 12:41 pm
Totally agree. I think this is one of those "tribal fiction" situations, where the reality is the exact opposite of the Conventional Wisdom.
hal8000
Sat Oct 19, 2013 4:09 pm
LemmeFatale wrote:And seven ate nine. :P
The opposite experience for me. I've lost data in the past many times on FAT32 on USB memory sticks, although until now I didn't have any SD cards with FAT filesystems. All my memory sticks use ext3, as I don't use windows. I've never lost data on any journalled linux filesystem, even after a power cut.
Heater
Sat Oct 19, 2013 4:31 pm
LemmeFatale,
...and have traditionally had nothing but problems with ext filesystems on SD Cards...
Yes but you are not allowed to say that around here. You are clearly imagining it:)
For me it has been worse. Not only is the file system corrupted but the card becomes unusable.
Try to reformat it or re image it. No chance.
Do some experiments with dd and I find it is impossible to read back what I have written to the card.
OK in the bin with that one and continue with a new one. Until next time...
Slava Ukrayini.
Joe Schmoe
Sat Oct 19, 2013 4:49 pm
Well done, sir!
Man after my own heart.
LemmeFatale
Sat Oct 19, 2013 5:50 pm
Heater wrote:LemmeFatale,
I should note that I've never experienced this with the Raspberry Pi (I can only guess that things with ext on flash-media have improved in more recent times), but I do know what you mean, here - I quickly learned my lesson about using ext on removable storage with other ARM Linux systems some time ago, after it killed two SD Cards stone cold dead and beyond recovery just as a result of said cards being connected while the hardware was being *safely* shut down. Never again. :P
confuseling
Sat Oct 19, 2013 5:57 pm
I've had a few USB sticks / cards go 'dead', but I've always managed to bring them back with fdisk or some other low level tool.
In my experience it's worth trying a few different tools - things can appear to be dead to one, but respond to another.
http://forums.debian.net
LemmeFatale
Sat Oct 19, 2013 11:29 pm
confuseling wrote:I've had a few USB sticks / cards go 'dead', but I've always managed to bring them back with fdisk or some other low level tool.
Absolutely - seconded. I've brought back one this way, too, some time back. Sometimes they do seem to just get totally wrecked, though...
shneor
Sun Oct 20, 2013 4:11 am
[quote="DavidS"][quote="hal8000"]Why on an embedded linux system is the /boot partition a FAT filesystem ?
[quote]There is not much concern because: The only time that anything on the FAT partition is accessed in normal operation is to load the firmware, read the config.txt, and load the OS into SDRAM. These are read only operations (even in Linux).[quote]
This is not necessarily accurate. With a dual boot, the active config.txt file is in the /BOOT directory, not in the FAT partition.
mahjongg
Sun Oct 20, 2013 2:32 pm
shneor wrote: This is not necessarily accurate. With a dual boot, the active config.txt file is in the /BOOT directory, not in the FAT partition.
AFAIK it doesn't have anything to do with multiboot, but yes the booted OS has a /BOOT directory, which is simply the FAT partition mounted as /BOOT, or am I missing something?.
Also there is more than one version of the "ext" filesystem, and while it is true that ext2 is notoriously susceptible to file system corruption ext4 is not, and the PI uses ext4, not ext2.
Sun Oct 20, 2013 5:14 pm
Well done, sir!
S'funny, 'cos I believe he said exactly that.
mikroskeem
Sun Oct 27, 2013 10:36 am
Okay if you say FAT is only supported fs by SoC bootloader, then why it suddenly won't boot? Partition moved forward by some blocks? No, i'm not that noob who complains about their sd card is wrongly flashed, i complain about rpi random non-booting caused by FAT partition. I can acces it from any other computer, but no luck with rpi. If i make backup from my rootfs and reflash using latest image + flash rootfs back, then it's working. It usually happens when i run e2fsck(at lastly jfs_fsck, cuz i have jfs root now)
EDIT: If i inspect new-flashed sd card with (c)fdisk and gparted, it has empty ~1,2Mb before boot partition, and ~2mb after it(Atleast on ArchLinux-06-06-2013 image)
EDIT2: If somebody asks, linux filesystems are very easily corruptable, just short accidentally 3,3v and gnd, rootfs superblock wipes :P FAT resisted it and rpi loaded it's stuff and tried to boot :D
