Chrunchstick
Audio in terminal - Debian
Tue May 15, 2012 8:07 pm
Hello all,
I have been trying to get audio to work in my Pi. In the GUI everything works now by using:
1. Boot
2. Login
3. run "sudo modprobe snd_bcm2835"
4. startx
I can play music files and sound just works great.
Now my problem. I want to play a music file from the terminal without starting X. I've tried multiple terminal music players (xmms2, mplayer, etc.) and it does not work even when I executed "sudo modprobe snd_bcm2835" right on boot.
On Mplayer i get the following error:
christiaan@raspberrypi:~$ mplayer Desktop/Hit\ the\ Floor.mp3
MPlayer 1.0rc3-4.4.4 (C) 2000-2009 MPlayer Team
mplayer: could not connect to socket
mplayer: No such file or directory
Failed to open LIRC support. You will not be able to use your remote control.
Playing Desktop/Hit the Floor.mp3.
Audio only file format detected.
Clip info:
 Title: Hit the Floor
 Artist: Linkin Park
 Album: Meteora
 Year: 2003
 Comment:
 Track: 5
 Genre: Other
Opening audio decoder: [mp3lib] MPEG layer-2, layer-3
AUDIO: 44100 Hz, 2 ch, s16le, 320.0 kbit/22.68% (ratio: 40000->176400)
Selected audio codec: [mp3] afm: mp3lib (mp3lib MPEG layer-2, layer-3)
socket(): Address family not supported by protocol
waitpid(): No child processes
AO: [pulse] Init failed: Internal error
Failed to initialize audio driver 'pulse'
[AO_ALSA] alsa-lib: confmisc.c:768:(parse_card) cannot find card '0'
[AO_ALSA] alsa-lib: conf.c:4170:(_snd_config_evaluate) function snd_func_card_driver returned error: No such file or directory
[AO_ALSA] alsa-lib: confmisc.c:392:(snd_func_concat) error evaluating strings
[AO_ALSA] alsa-lib: conf.c:4170:(_snd_config_evaluate) function snd_func_concat returned error: No such file or directory
[AO_ALSA] alsa-lib: confmisc.c:1251:(snd_func_refer) error evaluating name
[AO_ALSA] alsa-lib: conf.c:4170:(_snd_config_evaluate) function snd_func_refer returned error: No such file or directory
[AO_ALSA] alsa-lib: conf.c:4649:(snd_config_expand) Evaluate error: No such file or directory
[AO_ALSA] alsa-lib: pcm.c:2190:(snd_pcm_open_noupdate) Unknown PCM default
[AO_ALSA] Playback open error: No such file or directory
Failed to initialize audio driver 'alsa'
[AO SDL] Samplerate: 44100Hz Channels: Stereo Format s16le
[AO SDL] using aalib audio driver.
[AO SDL] Unable to open audio: No available audio device
Failed to initialize audio driver 'sdl:aalib'
Could not open/initialize audio device -> no sound.
Audio: no sound
Video: no video
Exiting... (End of file)
It does not matter if I try to play a other music format.
Is there any way I CAN play music files directly form terminal?
Thank you in advance.
Chrunchstick
marcelh18
Re: Audio in terminal - Debian
Sun May 20, 2012 5:31 pm
Hi :)
For playing music in console you should install a console audio player. I am currently using MOP.
Also keep in mind that sound driver should be loaded before you start the player.
For that, just type "sudo modprobe snd_bcm2835".
Best Regards,
Marcel
Chrunchstick
Sun May 20, 2012 6:53 pm
marcelh18 wrote:Hi :)
Mplayer is also a console player. I have tried about 6 console players. They all do not work.
bredman
Sun May 20, 2012 7:10 pm
Have you tried the tests in the troubleshooting wiki?
http://elinux.org/R-Pi_Troubleshooting#Sound
marcelh18
Sun May 20, 2012 7:49 pm
From your error log, it seems that the sound driver is not loaded. Try "lsmod" and reply the result here.
P.S. The player i use is MOC, not MOP. I misstyped in the previous post.
peteshew
Mon May 21, 2012 8:59 am
I have added snd_bcm2835 to the file /etc/modules so that the module gets loaded automatically. I rarely use anything other than SSH at the moment.
I have found mplayer plays for a short while (from a second to up to half a minute) and then stops playing although mplayer is still going.
I installed MPD and MPC which seems to work more reliably e.g. for streaming internet radio.
I installed shairport to act as a remote 'speaker' for iTunes. This runs for maybe ten minutes before sound stops coming out with no error or failure messages.
Chrunchstick
Mon May 21, 2012 4:32 pm
christiaan@raspberrypi:~$ lsmod
bnep                    7912  2
rfcomm                 25240  0
bluetooth             118996  10 bnep,rfcomm
fuse                   49036  1
snd_bcm2835            15388  0
snd_pcm                49240  1 snd_bcm2835
snd_seq                35080  0
snd_timer              13560  2 snd_pcm,snd_seq
snd_seq_device          3684  1 snd_seq
snd                    31624  5 snd_bcm2835,snd_pcm,snd_seq,snd_timer,snd_seq_device
snd_page_alloc          2660  1 snd_pcm
snd_bcm2835 seems to be loaded.
paaland
Tue May 22, 2012 6:23 am
omxplayer will play both music and videos accelerated via OpenMax and use the GPU. Prefered player to use both in console and X.
mpd and mpc also works for audio. I use it for webradio myself. There is an excellent iPhone app for controlling it as well.
Dragon 32>BBC Model B>PC>PC>PC>PC>Raspberry PI (circle complete)
Chrunchstick
Tue May 22, 2012 9:23 am
paaland wrote:omxplayer will play both music and videos accelerated via OpenMax and use the GPU. Prefered player to use both in console and X.
As I said, the problem is not mplayer because non of the players works.
So omxplayer also would not work.
Steady_Bear
Tue May 22, 2012 5:50 pm
What are you using to play music under X?
Does mplayer work under X and not the terminal?
What happens when you run alsamixer (assuming it's installed - not sure what mixer kids use these days ;) )? Both under X and a pre-X terminal.
What is the last block of output from dmesg after modprobeing the sound driver?
Run dmesg (have a quick read to spot anything looking wrong), note the number of the last entry, modprobe your driver, run dmesg again and note all the new comments.
Dendennis
Thu May 24, 2012 2:25 am
omxplayer plays mp3's perfectly well for me, mplayer only plays a few seconds no matter what.
maggocnx
Thu Jun 07, 2012 1:45 pm
I also had the problem with
for audio playback. After some time i figured out that sound wasn't working cause i was connected with SSH.
Solved the problem with
sudo chmod 777 /dev/snd/*
Now mpd and shairport are working quite ok.
boogiefer
Thu Aug 09, 2012 1:11 pm
@Chrunchstick
Did you fixed this problem?
boogiefer
Thu Aug 09, 2012 1:45 pm
hi Chrunchstick,
I have the proble same to you,
I found this http://linuxindetails.wordpress.com/201 ... processes/
it's realy useful.
Denex
Thu Sep 19, 2013 11:09 am
Instead of calling
on every boot you can write following udev rule
KERNEL=="controlC0", SUBSYSTEM=="sound", MODE="0666"
KERNEL=="pcmC0D0p", SUBSYSTEM=="sound", MODE="0666"
And place it in file /etc/udev/rules.d/99-my_sound.rules
Now udev would apply 0666 permissions
lordvlad
Tue Sep 09, 2014 8:36 am
I had the same issue of
issue because i tried to play something from a who wasn't on the 'audio' group.
usermod -a -G audio <usr>
and an logout - login solved it for me without messing with the system.
