framboise_314
Noobs screenshots howto ?
Sun Nov 03, 2013 5:28 pm
Hello
on the blog http://www.framboise314.fr, I offer articles on the Raspberry Pi for French RaspiNautes.
These translations are made for users who cannot read the original documentation in English.
I would like to write an article about Noobs installation with screenshots but I do not see how to take those screenshots.
I took pictures of the screen with a camera but they do not give very good results.
Has someone made real screenshots in Noobs and if so, how ?
Thanks in advance
Friendly regards
François
rdb
Re: Noobs screenshots howto ?
Mon Nov 04, 2013 5:16 pm
You can use VNC to take screenshots of the NOOBS interface.
See https://github.com/raspberrypi/noobs/issues/116 for details.
framboise_314
Tue Nov 05, 2013 6:07 pm
Thank you !
I try it ASAP
François
framboise_314
Wed Nov 06, 2013 10:37 am
rdb wrote:You can use VNC to take screenshots of the NOOBS interface.
Hello
I just try to add vncinstall in recovery.cmdline
When booting, Noobs screen is black with this message in the upper left corner :
ip: SIOCGIFFLAGS error: No such device
Then nothing happens for about 10 seconds and after the time out OpenElec boots as usually
I tried to remove the
quiet
in the recovery.cmdline
but I see nothing about the error
Any idea?
friendly regards
Francois
Joe Schmoe
Wed Nov 06, 2013 10:45 am
If I am reading this right, it means that you could run NOOBS headless (and install an OS onto a Pi w/o hooking up k/v/m to the Pi).
framboise_314
Wed Nov 06, 2013 1:57 pm
yes it's what I would like to do : use the Raspberry headless
and make screenshots on my PC in the VNC session...
but how?
I was using the "lite" version of Noobs
I just install the "full" version on a 8Gb SD card
added vncinstall in the recovery.cmdline file
now Noobs displays on the screen and waits that I chose a system to install.
No error writen on the screen during boot
I found my OpenELEC RasPi IP address in the DHCP server
ping RasPi is ok
but when lounch VNC viewer on py PC
with 10.25.100.27:1 (it's openelec IP@)
and try to connect I see an error window with
connect : Connection refused (10061)
going on searching
friendly
Francois
Joe Schmoe
Wed Nov 06, 2013 2:59 pm
Why :1?
Try :0
that's the default (port 5900).
Or just leave the :0 off entirely, since it is the default.
framboise_314
Wed Nov 06, 2013 3:02 pm
thank you for your help !
I try 10.25.100.27:0 and 10.25.100.27 (alone)
it's the same result (error window)
fiewwwww
nmap says :
root@debian7-origine:/home/user# nmap 10.25.100.27 -A
Starting Nmap 6.00 ( http://nmap.org ) at 2013-11-06 16:05 CET
Nmap scan report for 10.25.100.27
Host is up (0.0011s latency).
All 1000 scanned ports on 10.25.100.27 are closed
MAC Address: B8:27:EB:00:88:02 (Raspberry Pi Foundation)
Too many fingerprints match this host to give specific OS details
Network Distance: 1 hop
TRACEROUTE
HOP RTT ADDRESS
1 1.07 ms 10.25.100.27
OS and Service detection performed. Please report any incorrect results at http://nmap.org/submit/ .
Nmap done: 1 IP address (1 host up) scanned in 1.96 seconds
I ask myself if VNC is launched on the Pi...
In the tty2 logged as root ps => no vnc running...
continue search...
r4049zt
Wed Nov 06, 2013 5:29 pm
I recall there being some one-way write to GPU in an early draft specification which would rule out using the usual linux screenshot mechanism in raspian. I don't know Noobs. Pidora uses part of normal memory for screen X-display so that has a screenshooter application. Guessing that you cannot give permission for VNC during the earliest stage of first boot, your best bet may be to get a smartphone or other external camera to photograph your monitor.
>>>>>>>>>> machine translation follows >>>>>>>>>
Je me souviens qu'il y ait quelqu'un voies écrire à GPU dans un projet de spécification précoce ce qui exclut l'utilisation du mécanisme d'écran linux habitude dans raspian. Je ne sais pas Noobs. Pidora utilise une partie de la mémoire normale pour écran X-affichage de sorte que possède une application screenshooter. Devinant que vous ne pouvez pas donner la permission pour VNC au cours de la première étape du premier démarrage, votre meilleur pari peut être d'obtenir un appareil externe smartphone ou autre pour photographier votre moniteur.
framboise_314
Thu Nov 07, 2013 7:30 am
I tried to photograph the screen but it's not very good.
The Noobs Team published some screenshots
that's why I think it should be possible...
Return to “Teaching and learning resources”
