Bronto
Auto login and start a script
Sun Nov 03, 2013 6:45 pm
Hi all,
I am able to run a script, called hello.py without the need for a monitor as it boots into command prompt. So, using a keyboard I log in, And then type ./hello.py
Here's what I do:
Login PI
Password raspberry
Then I wait about ten seconds for the raspberrypi$ to appear then I type ./hello.py
So, my question is how can I do all this automatically, so I don't need to use a keyboard?
I want to auto login, then when the command prompt appears, type ./hello.py
Thanks in advance
Bronto
Takenover83
Re: Auto login and start a script
Sun Nov 03, 2013 6:48 pm
First do this to setup your auto login.
http://elinux.org/RPi_Debian_Auto_Login
Then edit .bashrc. Just add your command to the bottom. It will be run after login.
nano ~/.bashrc
Bronto
Mon Nov 04, 2013 12:02 am
Thanks for that.
So here's where I'm at:
Made all the changes as instructed and after reboot the script which is supposed to play an audio file, doesn't.
So, I remote connected into it. Then, I simply double clicked on lax terminal and the script started to play straight away.
So, the way I need it to work is that it will log in and open that file automatically without the need for me to remote in.
Thanks for the help
Hove
Mon Nov 04, 2013 9:15 am
If you want it to run without a user logging in, you could add an init.d boot time script:
I used this as my starting point and tweaked it to use my python script instead - the changes to use your bash script will be similar.
http://www.stuffaboutcode.com/2012/06/r ... rt-up.html
www.pistuffing.co.uk - Raspberry Pi and other stuffing!
Bronto
Tue Nov 05, 2013 10:46 pm
The problem here though is it just doesn't run the script for me. You see if the script runs successfully it will play an audio file.
However, connecting it to a monitor it is logged into the desktop. So, I double click on the terminal and the script starts automatically. I don't end to type in ./hello.py or anything it just starts.
I just want this to happen from the get go, without me needing to log in and do anything other than turn it on.
MrCartas
Wed Nov 06, 2013 11:36 pm
Check this link. It's exactly what you want to do: http://raspberrywebserver.com/serveradm ... rt-up.html
malyon2001
Fri Jan 03, 2014 6:24 pm
This seems to have bricked my pi. On startup it now says
Cannot open /Dev/ttyl: no such file
Re spawning too fast: disabled for 5 minutes
How do I now unlock my pi again? I can't get to the start options to login.
wangdino
Thu Jan 30, 2014 3:20 am
I guess it should be tty1 (number 1 instead of letter l), plus it should be /dev instead of /Dev
Anyway you can't literally "brick" your RPi because you always have the SD card. You can mount it somewhere else and try to re-modify the files or you can simply dd a fresh image into it.
Rapheal2k14
Thu Feb 20, 2014 1:37 pm
Hello Everyone,
I am trying to run a python script on autostart but the script has dependencies. I tried editing rc.local with the script path but how do I add the path for the other dependencies so it works correctly.
Thanks a lot.
Raph
marlosdamasceno
Sun Oct 25, 2015 9:52 pm
Hi Bronto,
I think that you are looking for this http://www.opentechguides.com/how-to/ar ... start.html
Best regards
Lefteris
Thu Mar 03, 2016 5:52 pm
Hello, what is the way for autologin in console . For CLI not GUI. I want autologin to different user than "pi" in command line console.
The file "/etc/inittab" is missing.
Return to “Raspberry Pi OS”
