drhitchcock
fswebcam - gd-jpeg: JPEG library reports unrecoverable error
Tue Nov 05, 2013 12:06 am
Howdy Raspbians,
I recently set-up my Raspberry Pi running Raspbian to work as a time-lapse camera taking images of my tomatoe plant :P I followed the instructions here: http://www.makeuseof.com/tag/how-to-cap ... sb-webcam/
It's been working fine for about 4 or 5 days and then after a recent reboot I started getting this error:
gd-jpeg: JPEG library reports unrecoverable error: Not a JPEG file: starts with 0xff 0x80
All that appears in the image is a black box.
I've updated all packages and drivers, unplugged any unnecessary peripherals and I have also tried using the web cam via a powered hub. It was working via the same USB hub before I started having problems.
Any help with this would be super!
Cheers,
Dr Hitchcock
rajbadri
Re: fswebcam - gd-jpeg: JPEG library reports unrecoverable e
Tue Nov 05, 2013 8:37 am
same problem here please help
rajbadri
Wed Nov 06, 2013 1:44 am
it seems that the webcam was not recieving enough power. so probably a powered hub would do the trick. I plugged another webcam and it's working fine..
djevrek
Sat Dec 07, 2013 2:34 pm
Try this command, for my camera i need to change -p parametar its logitech c170 and works only with -p YUYV
fswebcam -p YUYV -d /dev/video0 -r 640x480 $DIR/$filename
arti0504
Fri Jan 17, 2014 11:05 pm
I have Creative Live! Cam Notebook VF0470, which I have connected to HUB with external power supply. I have also problem. I took picture and I have it black.
This code doesn't work:
I have message stat: No such file or directory
I have installed also in Raspberry Pi guvcview for webcam grafic configuration. But all the time I have black window. I have installed guvcview in Ubuntu 12.04 and VF0470 work good.
Any help with this would be great!
tisnickske
Sat Feb 08, 2014 2:57 pm
I got rid of the 'gd-jpeg: JPEG library reports unrecoverable error' by adding a -S 2
This lets fswebcam skip two frames.
Seems that my camera generates faulty frames?
topkings
Sat Sep 27, 2014 1:16 pm
sudo fswebcam -d /dev/video0 -r 320x240 -S 2
Fixed
BlueBlood
Fri Nov 21, 2014 8:13 am
I had the same problem, I found that it was actually a problem with the module and when i used zbar to scan an image the input came through fine,
Hope this helps
hegylako1594
Mon Aug 17, 2015 7:33 pm
I have the same problem too. Mjpg-streamer, fswebcam don't run well. I think, it is a encoding problem.
Gary498750
Mon Dec 28, 2015 3:18 pm
Hey everyone,
I think I got the solution!
i found the instructions:
sudo apt-get install libjpeg8-dev
sudo apt-get install imagemagick
and the problem was fixed.
amer
Thu Apr 28, 2016 2:15 pm
Is it possible to save 2 image.jpg when running fswebcam? as example, when running fswebcam once, i want image1.jpg and image2.jpg saved in a folder (of course both are the same image).
>>>import os
>>> import datetime
>>> os.system ("sudo fswebcam /var/image1.jpg")
>>>os.system("exit")
jobfreder
Mon Sep 19, 2016 8:05 pm
above fswebcam -p YUYV and fswebcam -S 3 kind of worked for initial question, error went away but had saturated (white) picture. Increasing the -S solved the saturation problem, finally using: fswebcam -d /dev/video0 -S 30 -F 5 tst.jpg
GauravMahna
Mon Apr 24, 2017 6:47 pm
Below command worked for me :
fswebcam -d /dev/video0 -r 1920x1080 -S 30 -F 5 image10.jpg
Refer Documentation : https://man.cx/fswebcam(1) for more details.
